CMUCAM to Arduino — Parallax Forums
CMUCAM to Arduino
rajeev.piyarerajeev.piyare Posts: 5
edited 2011-04-26 16:14 in Accessories
I have connected my BOEBOT CMUCAM to arduino as shown in the figure.
Transmit pin from cmucam to receive pin on arduino & vise verser.
Could anyone verify if this will work or there is some error in the connection. The red led turns on when the power from 5V is connected.
Please advice. I would really apprecite since this version of cmucam is fully striped.
rajeev.piyare@fnu.ac.fj
    edited 2011-04-25 19:12
    The serial pins you have on the cam are rs232 level shifted and would not go directly to a pin on the Arduino. You might see if there is any helpful advice on the Arduino website. You could also post your code over there and people would understand what you were talking about.
  • rajeev.piyarerajeev.piyare Posts: 5
    hi, the pins shown are TTL serial pins as shown below, and according to the data sheet it can be used with micocontroller.
    576 x 595 - 61K
