dotsidplayer - a failed attempt. (For now...)
Hello.
Thought I might share something, even though it didn't quite work out the way I thought it might. I know it's something of some interest to some folks here, and maybe it generates some interesting discussion or maybe someone finds it's a bug I missed vs. a fail, or can re-use bits in a more successful attempt. So I'll post it and see where it goes, as I probably wouldn't spend much more time on it otherwise, and it'll do no good rotting on my hard drive.
It was supposed to be a sidplayer that directly plays .sid files. It's built on a cog for the C3 called c3io I have been playing with, and uses Ahle2's awesome SIDcog.
I took the the 6502 core from the pacman NES sources, and bits of the memory access for a port of zog that c3io has, glued SIDcog to the 6502, and wrote a loader based on what I saw in the C sources for tinysid. The 6502 core also gets some spin routines that let you "JSR" into some code and have that return back to spin, which lets one implement the "glue" in SPIN. This is the technique tinysid (and probably most other) "dot" sidplayers use, as it really involves calling an init
function, and then calling the sound routine @ 50/100 Hz.
Awesome, right? Well... not so much yet. It plays... something.. but it's not quite right. It makes noise depending on what sid file you throw at it. I put a couple in the archive. "Sweet.sid" look to run close to fast enough, but generates clicks. "Dawn.sid" probably runs too slow, but generate a wild soundscape that you'll probably want to turn down.
Confirmed problems are:
- It's just not quite fast enough. The problem is probably less the 6502 emulation and more the VM/serial ram on the C3. Maybe a bigger/smarter cache?
- the above is also why the delay loop is commented out between calls. putting it in often results in the deadline passing sending the prop into the "53 second pause".
Suspected problems are:
- the 6502 core I have has bugs the pacman game never triggered? (IE: it implemented just enough?)
- this probably is why Sweet.sid doesn't make much sound despite running fast enough
- there is some subtlety of how I've glued SIGcog that isn't quite right...
- I've made bugs I haven't yet uncovered.
So anyway... Have a look if you've got a C3 handy and this sort of thing interests you, or you feel like porting it over to your platform of choice. (boards with more direct memory attachment might do better here...)
6502 asm looks like it would be fun to code in. It must have been
enjoyable to program for the old Apple computer in 6502 asm.
I think that old computer only had like 1mips or so, amazing
they could do much of anything.
However, I'm pretty sure the problem has to do with the "dummy byte" that I put between each SID channels registers to "long align". This was made to optimize SIDcog to be able to run at 31 kHz. Otherwise it would have been running at 15 kHz, and that's not an option. Have a look at the VAR section to see where those "dummy bytes" are. The "updateRegisters" method takes care of the alignment issue when playing register dumps.
Btw, download the latest version of SIDcog in the OBEX.
/Ahle2
Btw, I can see if I can finish my C3 spi ram driver (with the help of kuroneko??) that does 20 Mbit/sec using the video generator.
Then the memory bandwidth certainly isn't an issue anymore.
I can manage to get it to work like 90% of the time I launch it in a cog. It's an issue with the PLL phase, and I think kuroneko is the man to talk to.
/Ahle2
Yes it was fun. The Apple, of the different computers, actually shipped to be programed on and hacked on. In the ROM was a mini line assembler (you compute your own branches), and memory monitor. That's where my first assembly language programs were done. SPIN runs somewhere in the range of where a 6502 does in assembly. I've written a few basic test programs and SPIN holds up well against a old 6502!
If you want to have a play there are plenty of emulators. Should you do that, be sure and check out a 6809 machine. That's the most elegant and powerful 8 bitter ever made, IMHO. Addictive, be warned.
@jhh: Nice project. I hope you see some success!
wrsid mov addr, _AB and addr, sid_mask ' mask $FC00 cmp addr, sid_base_addr wz ' check for $D400 if_nz jmp #wrsid_ret mov addr, _AB and addr, #$1F ' mask lower 5 bits cmp addr, #6 wc, wz ' munge it into nice longs for sidcog if_a add addr, #1 cmp addr, #14 wc, wz if_a add addr, #1 cmp addr, #22 wc, wz if_a add addr, #1 add addr, sidReg ' use as offset to sid registers wrbyte _DB,addr wrsid_ret retIt might be something about the JSRs as you say, but when I compare the 6502 code from tinysid to that of the cog, it looks like there might be some differences in addressing mode handling that might cause incorrect interpretations. The 6502 cog does all addressing handling before the opcode, where tinysid sets a "mode" and calls the opcode, which may take different paths in get/set memory routines depending on the mode. I actually started to rework the 6502 cog to look more like that but it looked like it would get too big to fit and shelved it.
I just came across another 6502 core called 'q6502.spin' which seems more complete, but uses LMM. I am just trying to wrap my head around what LMM is all about... but my understanding is speed is less than non-LMM assembly, so I'm not sure it's a good candidate to work with for this project.
That routine you're talking about for SPI sounds awesome. I'm sure I could increase my speed 3-4x too by just ditching the 'bidirectional SPI' I have in c3io right now and went with something using the hardware timers. (IE: as in Kye's SD card driver)
Thanks for having a look.
Here is the output:
Your offset handling seems to be correct as far I can see, but I don't understand the "add addr, sidReg"; It's set to 0 anyway?!
I'm not sure what you mean by how the "6502 cog" vs tinysid handles addressing modes.
In the 6502 emulator I wrote for the SID dumper, opcodes are handled like:
- First the address is "calculated" using the selected addressing mode.
- Then the actual instruction is interpreted.
sidReg is set on init of the 6502 cog to the pointer returned when starting SIDCog (IE: the ch1 frequency low byte value passed as PAR to the cog). So sid register offset (0-27) + the base to get the right address for SIDcog to read.
The way you describe your dump utility seems right along the lines of how the 6502 cog is implemented, and I've heard the results of that, so maybe the approach isn't the issue (although the cog might still be missing something the utility does.)
Was the dump tool you wrote something for which source is available? Perhaps I could compare the two.
Off topic, I think the name of the player should be "El SID" Probably already taken, but still...[8^)
Jonathan
Might be some other problem too, like a bug in the sd init code of c3io triggered by a card I haven't come across yet. (c3io uses code inspired by, but not the same as, Kye's).
My experience is that FSRW always works on any card. The same card that didn't work with your player works flawlessly on the same C3 with my chiptune player using FSRW.
On the other hand I have seen some cards that doesn't work with Kye's fatengine.
Question: Ahle2, do you typically use BST or the official tools? (Trying to figure out what might be different....only thing I can think of...)
* SD / SDHC / MMC support
* multi-block mode
* read-ahead
* write-behind
* SPI output at 20 Mb/s
* SPI input was slowed down to 10 Mb/s.
That slowdown was to work around some cog<=>pin issues that show up when using some combinations (only at PLL16X).
I do have a slightly newer version of the block driver if you want to test it out. The code is a bit smaller, the Spin calling routines were reordered and optimized a bit, and the initialization routines seem to handle coming out of the certain weird states better (like the prop reset in the middle of a multi-block transfer to the SD card).
Jonathan
Is the official 2.6 FSRW in OBEX?
c3io is meant to be a "replacement cog" specific to the C3's shared-SPI bus to allow safe concurrency, interleaving operations using the SPI bus. Unfortunately it means mucking about in the low levels of everything, and I'm a bit of a noob to the platform to boot, so I am most certainly breaking things.
Spinning.
I especially like the 'hub_cog_transfer' bit. I may have to evict some things to make room for such a thing.
/ Ahle2
Anyone else get further while I was away?
