Question about LDO regulators
I'm working on a new design using the propeller chip and I plan to use an LDO 5V regular to power some componets in the design.
My question is this: Lets say I have 5V applied to the VOUT pin of the LDO regulator and leave the VIN pin unconnected. Will I have a problem? The VIN pin is also connected to a 33uF to capacitor to ground but nothing else.
Thanks for your help,
EDIT: I mean VOUT instead of VIN.
Your actual question is not specific enough to understand precisely what you mean. Do you mean when unplugging the power source?
You have to be careful with some regulators as if the voltage remains on the output (such as feeding from another supply, or in the case of extra large output capacitance vs input capacitance) the regulators may self destruct by backfeeding the power into the vout pin. If the regulator is not protected then a diode feeding back from Vo to Vin should protect this case.
Most regulators (All that I have seen) have a reverse biased diode from their Vreg to their Vsupply, so an input voltage at the VOUT shouldn't harm the regulator. However if the voltage is negative at VOUT, then the regulator will be active in it's forward conducting mode, still this may be ok with the regulator, but I would be more concerned with the device(s) that are powered from the regulator in this scenario.
Can you offer a circuit diagram? (partial would be ok) ... also how negative is the voltage and what is the source of it?
Presuming you mean that the input can be reversed. To prevent this, the diode needs to be in from your input connector. If it is isolated ground, you could place it in series with the ground lead.
Another method is to use a 3pin connector, with the outside pins connected together. Then it does not matter which way it is connected. I am not sure if there is a common way, perhaps center +ve and gnd outside.
Another simple method my be to use a 3pin connector where a shunt is used on 2 pins to pass the 5V regulated output to the 3v3 Vin. Remove the shunt and use the common pin and the other pin on the 3pin header to feed the ne input voltage to the 3v3 regulator Vin.
I'm working on a board designed to be sold to hobbyists... basic stamp/aurdino lovers etc. Keeping the cost low is the most important factor.
The solutions presented above will not work in my sitautation since I need to have 5V come in and out of the connector I highlighted above.
Thanks for all the help.
I'm with Phil -- we do that (PTC fuse) in all new EFX-TEK products.
Go to digikey.com, search "PTC", then click on "PTC Resettable Fuses". There's a huge variety, which you can narrow down parametrically. Your choice will mainly depend on the needed trip point, working current, and response time. Also, make sure the diode you choose is able to withstand the momentary current spike before the fuse "opens".
Erm...how about using bridge rectifier?
