wire limits
So I have tried to look up (Google) a formula to calculate the correct gage wire for my application. I keep coming up empty. Either I get charts or good guesses. Here is the data sheet http://www.assmann.us/specs/AK322-2-R.pdf
I want to use a VGA cable to run 5V at up to 8Amps on my device. How many strands of wire could I use and be safe. The total distance is 6 feet. I am thinking 4 conductors will do but want to be sure. Any ideas?
That leaves you with 5 extra lines.
http://en.wikipedia.org/wiki/American_wire_gauge
http://www.belden.com/pdfs/03Belden_Master_Catalog/22Technical%20Information_Glossary/22Technical_Information.pdf
edit: Okay, now I see it, the cable's wires are 28 gauge.
A 6 foot length would result in 0.39 Ohms (6 * 0.065). Multiply that by 8A, and you encounter an approximate 3V drop across the wire.
Putting 6 28AWG wires in parallel would result in a combined 0.065 Ohms (back to single wire resistance).
Multiply that by 8A and you'll have about a 0.5V drop.
And yes, you'll need the same number of "return wires".
Moral of the story? Run as many 28 gauge wires as you can if you're determined to use that size. Using a larger gauge would be reduce the number of wires involved for source and return.
Peter
It is a lot larger than the wires. :-)
I have wondered why it is possible for a wire to handle more
power at a high voltage than at a low voltage? I say this because
it seems like an awful lot of power is carried by relatively small
wires on those big high voltage transmission towers. The wires
look small and yet can power an entire town. I was speculating
on another thread the other day about sending power and data
up a very long twisted pair of wires to a quad copter and use it
as a sort of radio tower. The wires would need to be very small and
lightweight but would still need to handle several amps. So I assumed
that sending up high voltage ac and converting it on the copter to
low voltage DC would probably work. Was my reasoning sound or was the idea
just silly?
Power Transmitted = Voltage * Current. This is the familiar power equation P = VI.
You want to maximize power transmitted, so in theory you would like Voltage and Current to be as high as you can make them.
But another thing you must think about, Power Dissipated = (Current)2*(Line Resistance), so in order to reduce wasted energy, you need to minimize Current.
Problem is, you have no control over Line Resistance. And because Power DIssipated goes up with the square of the Current, it's best to jack up the Voltage.
Of course, once the wires get too small, then you run up against simple problems of Voltage Drop = Current*(Line Resistance), so running power over very small wires does have a practical limit.
"Voltage drop". The voltage will be less at the end of a long wire. Plug in a long 100 ft. extension cord to an outlet, measure the voltage at the plug, then at the end of the cord. Place a load on the end of the cord, measure again.
Using a larger gauge wire will reduce voltage drop.
"Stepping up" a voltage to very high voltage will allow it to be carried for very long distances. (Like 500,000 volts.)
AC (Alternating Current) has the advantage that is can easily be stepped up in voltage, then stepped down using transformers -> Thus allowing for distribution over very long distances.
The decision to use AC for electric companies...
http://en.wikipedia.org/wiki/War_of_Currents
Voltage Drop Calculator...
http://www.csgnetwork.com/voltagedropcalc.html
Wire gauge sizes for 12 volt DC automotive (LARGE!)...
http://www.offroaders.com/tech/12-volt-wire-gauge-amps.htm
AC Wire size calculator...
http://www.csgnetwork.com/wiresizecalc.html
That is the current or amperage a wire carries determines the size of wire required. And when you step up a voltage with a transformer, the voltage on the wire increases whereas the current carried decreases.
So lower current/amperage and a smaller wire can be used.
The general idea is that a wire is the correct size if it is not warm or hot when in use.
At least VGA is analoug so the worst is you will have a noisy Picture ..
Got to love transients ..
Peter
250 V is just high enough to run some serious power But low enough to use COTS gear
Use 250VDC and a off the shelf SMPS to get 5V or 12 or what not .. .
to get 250 V DC use a inverter and a cascade to up it .
Peter
It wouldn't be too hard to figure out the size of the wire and the weight of the wire for a given height. But bear in mind that there will be wind resistance on the wire, too. And that ~sideways force will affect what sort of loads your copter will experience. Any sideways vector will detract from your vertical lifting capability and will therefore limit your altitude. Also, if you plan on using very high voltages, bear in mind your wire might then need better insulation, and that will add weight, too. The trick, I suppose, would be to find a "sweet spot" amid all of these competing requirements.
As for more power at high voltages, yeah it's voltage drop -- three volts is insignificant at 220V but it's a real potential problem at 12V and kit absolutely kills you at 3V3.
Just don't smoke - or spark. Also, just to avoid the confusion: natural gas is NOT propane. Propane is heavier than air. And it is dangerous, too.
I decided to use a heaver gauge wire selected from the beldin link RDL2004 posted up there.
