What is the cheapest Android tablet (preferred 2.2, 7") availible?
Hi,
My brother is looking into the ever popular Android tablets, but he has have a very low budget. I was wondering what the best deal on a tablet of this type would be, and where I could get it. I found this one here: http://www.sinadeal.com/item/VIA-WM-8650-7---Tablet-PC-Android-2-2-Camera-WIFI-3G-Flash-10-1-MID-epad-134180/
but I don't know if that is the cheapest or even if the site is legit. Any information would be helpful.
Microcontrolled
Microcontrolled
There must be cheaper available, but these are the "standard"
You might like to check out Sparkfun's IOIO as well (in development)
http://bit.ly/fKYMkc
Another smart option is the Barnes & Noble Nook Color which is around $200 or less which CAN be hacked to run android. A link for a good overview of that process is:
http://www.nookdevs.com/Softroot
First of all, they generally use a resistive touch screen instead of the capacitive type. That might be ok when all you need to do is simple taps, but swiping gestures like you would use for scrolling is quite tedious, and is significantly more prone to user input errors as contacts might not be registered if you're not pushing down hard enough. Trust me, that can be frustrating.
Secondly, most of these aren't Google approved devices, and therefore aren't supposed to be loaded with Google software (such as maps, and market). The tablet you posted claims to have Market installed, but I learned that unless they have a certain wireless carrier emulator hack, the full contents of the Market will not be displayed. It *might* be possible to install said patch on this device, but there's no certainty.
Customer support.. It'll be unlikely that you'll be able to get any from the manufacturer. And I don't mean just in the case of warranty repairs, but also software support. I have a feeling you won't be getting upgrades to the newer releases of Android (Gingerbread [2.3], Honeycomb[3.0]). This one also appears to have a custom UI instead of something more standard such as ADW. Find a few youtube videos of these devices in action, and you'll see how crummy they generally perform. Theoretically, you should be able to change this, but it's hard to say how easy or difficult it would be. Since you won't likely be getting any significant manufacturer support, the next place to turn to would be community support. However, there isn't much community interest in these devices either. So you get what you get - and that isn't very comforting.
More on this particular unit - It doesn't say what processor it uses, but it's most likely an ARM11 which would leave a lot to be desired in terms of performance. Also, 256MB of ram for Android 2.2 is quite low. Looking at the available ram on my device which totals 512 shows only 300MB free despite only have 3 services and a couple of applications running. 256MB would be gobbled up in no time, especially with what seems to be a poorly coded UI. Unfortunately, these devices probably serve better as paperweights than functional tablets.
So what's a good choice? If you really have to stay in the sub $100 range, you'll probably be stuck with something that has similar specs to the one you posted, but you can have one that is from more reputable brands such as Pandigital or Archos - which at least shows some signs of life in the hacker community (check http://forum.xda-developers.com/). I personally have a 7" Barnes&Noble Nook Color which is normally priced at $240, though they recently had them on sale for $200(!).. Build quality is good, screen is excellent (higher pixel density than an iPad), specs that are comparable to >$400 units. It also has a HUGE hacker following, and was the first device to run the preview build of Android 3.0.. Do a quick search, and you'll find just how popular this device is. If you can afford it, you'll find that it's the biggest bang for your buck, and you won't be disappointed. There are builds of all Android versions from 2.1 and up. "Hacking" it is as simple as loading up images onto a microSD and booting from it, which can then be copied to internal storage, or simply run off the SD at the expense of some performance. Viewsonic also dropped the price of their 10" recently to $280 - I can't really comment on it, but I'm assuming it'll become quite popular with that price.
Hopefully that'll help with your purchasing decision a little bit.
I really like it. Only wish it had a camera, but for $250 I'm not complaining.
Bean
I use it all the time for reading comics, and the resolution is absolutely amazing. Just wish Marvel would support Android with their mobile comics app. Email and web surfing is pretty nice too. The keyboard could be better (wish you could stick with the original Nook one) and sometimes auto-correct doesn't work, but that's really just a minor inconvenience.
I will put another vote in for the Nook Color. I just got one for my birthday and absolutely love it. I will also be doing the Honeycomb (Android 3) root soon when I have a chance to give me a few more apps that are missing from the stock Barnes and Noble Android version.
"A-Pad", around $110 incl s/h... resistive touch screen, Android 1.5, I updated it to 1.9... worked fine for months, then the battery stopped taking a charge. About 2h of web browsing
"Cruz T301", bought locally for $170+tax, capacitative touch screen, Android 2.0. Excellent battery life, about 10 hours of mixed use browsing the web, reading e-books, wife playing Soduko; significantly faster than the Flytouch (real name of "A-Pad" I have)
I just wish that it had physical "Back" and "Home" buttons, Laputa reader is a pain without them.
The A-Pad had a better default PDF reader, I am still looking for a fast one so I can carry reference PDFs with me. I find a tablet handy even near my large computers for PDFs.
