Revision Request - Propeller protoboards - more silkscreen marking on bottom of board — Parallax Forums
RobotWorkshopRobotWorkshop Posts: 2,307
edited 2011-04-19 09:25 in Propeller 1
If there is ever going to be another revision of the Propeller proto boards I have a request for a couple minor changes. I think they would be easy to incorporate without adding any cost to the boards.
- On the top side of the board the silkscreen has small dashes that show which pads are connected: 3.3v, 5V, GND, and the propeller output pins. Since the bottom of the board already has a silkscreen could those same dashed lines and legends for the pins also be printed on the bottom?? This would only be a change to the silkscreen. It would help when doing wiring on the bottom of the board.
- Add a spot (two pads) that go to ground and the other to the reset line. That would make it easy for someone to add a two pin header for a remote reset switch.
These are great boards to work with and I think these minor changes would make them even better.
Robert
    edited 2011-04-16 08:18
    To that I'd like to add a request for some larger changes:
    1. Move the Prop chip from the center of the proto area off to one side. The current position of the Prop chip limits the usability of the available proto acreage by chopping it into rather narrow strips. Having the Prop chip off to one side would increase one's options for doing prototyping. The available Prop pins should be brought out to a row of pads facing the proto area.
    2. Add some surface mount pads near a couple Prop pins suitable for configuring a sigma-delta ADC.
    3. Use a lower-profile electrolytic cap or one with axial leads. The one that's there is the tallest thing on the board by far and severely limits one's options for an enclosure or for stacking boards. Plus, in a single, bareboard situation, it's just sitting there asking to get bumped or broken off.
    edited 2011-04-16 08:31
    I'm not sure I would want them to move the prop and change the pad layout for the current boards. There are already quite a few projects that expect the prop pins to be where they are. I just wanted to suggest a couple things that could easily enhance the current version.
    For larger changes that could end up being a separate prop protoboard. Maybe that would warrant a new thread about what features should be in the ultimate protoboard if there is a whole new one created.
    Robert
    Robert
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2011-04-16 09:56
    I second the requests by Robert. I would add that in the documentation the licensing for commercial applications be made clearer, as I still am not clear on this (I do not see any where it says it is open, or the contrary), and beings that I will be doing a low volume product that is subject to frequent revisions (as I am sure is true for others), this would be a useful component. I still need to write Parallax about this issue.
  • SRLMSRLM Posts: 5,045
    edited 2011-04-17 18:23
    My input:
    1. Add a VIN through hole, in case somebody doesn't want to use the barrel jack (maybe an area where you could add a 3 pin servo header connection or a place for a terminal block.
    2. Add power connections to the side of the board furthest away from the regulators.
    3. Add the PCB traces image to the documentation: it's helpful when drilling on the board to know what you are cutting.
    4. Add in a jumper to allow for separate input power supplies to the 5 v and 3.3 v regulators.
    5. On the USB version of the board, break out the 5v power line so that it can be easily accessed (and four holes for a prop plug of you destroy the USB portion, like I have...).
    edited 2011-04-17 20:46
    Robert
    Hello Robert,
    We are planning a revision to the two Prop Proto Boards. I concur with all of your requests and I will see that they are accommodated in our revision. The power supply also needs some design improvement.
    This will take some time. First, we need to finish the WiFi Module, PropBOE, and another unnamed PCB that you will learn more about in May. The manufacturing lead time is also long. I'm hoping you could wait until September before we actually have the revised board in stock.
    Consider the request "booked". We'll also get to your other one sooner or later (the 12V MMWK Position Controller).
    edited 2011-04-17 20:52
    Hey Phil,
    1. We'll look into this request. We may have introduced some other dependencies elsewhere that have frozen the location of the Propeller chip. I've also had some challenges putting a joystick and XBee adaper on this PCB for the reasons you cited. Consider this item "under consideration".
    2. Can do. Would be particularly useful because it would of course accompany a pending AppNote we will release in May.
    3. Right, and we agree. That capacitor almost looks like Taipei 101 the way it stands out among the other "buildings".
    How come nobody suggested that we free ourselves from the Norcomp VGA/PS2 connector? We've made a very costly commitment to that part to save real estate. One problem with substituting a single VGA connector next to a single PS2 port is that we're now manufacturing enclosures that fit the Norcomp VGA/PS2 connector. Would probably be best not to replace this part.
    I'll use this forum thread as our engineering task list for revisions to this product.
    edited 2011-04-17 20:55
    Hey David,
    We can also supplement the documentation with our open-source approval. At the same time we would provide the design in DipTrace so you could easily build your own. Like all of our boards, this one is freely open for your own use. The only issue is that you need to be able to work with PADS files in this case, as it was pre-Altium, which exports nicely to DipTrace. There is no need to write us - this forum post is your approval to use the design freely, for personal or commercial use without restrictions.
    edited 2011-04-17 21:00
    SRLM wrote: »
    My input:
    Hey SRLM,
    Long time, no see. You are always welcome to camp out at UPEW this May should you decide to join us. Let's go through your points:
    1. OK. This could be accommodated with the power supply revision.
    2. If space permits.
    3. Agreed.
    4. The pads are present for a 3-pin connector and jumper, though we don't include the header and jumper. What you're asking is that we populate the 3.3/5V "selector" with a jumper block, right?
    5. Hmm. This would require a real estate commitment, albeit small. We will discuss, but first thoughts are that we'd rather replace boards for USB destroyers like yourself instead of make this change. This is the first time I've heard of such damage.
    Great input. Thank you,
    edited 2011-04-17 21:08
    Ken Gracey wrote: »
    Hello Ken,
    I'm doing pretty good with the Propeller boards as they are now. No hurry on the protoboard changes. I just wanted to mention it to get them on the list to see if they could be incorporated as well. I seem to do as much wiring on the bottom of the boards as on the top and having the legends for the pins replicated on the bottom would help. It came up when working on my latest project. I may a silly wiring mistake when working from the backside of the board and instead of picking an isolated pad ended up using the of the 2nd pins over that was tied to a prop pin. It was my mistake and made me think that if the dashed lines where there showing what pads were connected I may have avoided it. Didn't damage anything and once I corrected it the whole board is acting just as I hoped it would. Below is a picture that shows how it is turning out.
    Robert
    1024 x 768 - 220K
    edited 2011-04-17 21:31
    @Robert, I've had the same problem. I often find myself identifying a certain pin number from the top of the PCB, then turning it over and trying to verify the location on the bottom. Not too efficent and has plenty of opportunity for trouble. Once I wired up a dual seven-segment display nearly backwards because of the lack of silkscreen.
    Ken
    edited 2011-04-17 21:42
    My ProtoBoard (both USB and non-USB) suggestions:
    1. Use the same pcb for both versions by just omitting the USB/FTDI circuitry on certain builds.
    2. Make the USB section with a 1x4 Propplug header and the 1x4 Propplug header to the prop immediately beside the first connector 0.1" apart. This means that you can separate the PropPlug and Prop, which is a great feature. Now, to join them just place 4 shunts to link these 2 headers.
    3. Provide 2 links for 5V & Gnd so that the USB may supply the 5V, or the 5V regulator. This also permits an external 5V supply direct to the header.
    I have a few other problems but am not sure of the best solutions...
    4. The VGA and dual PS2 connector. It is an expensive connector and not easily obtained. Here are some ideas...
    I would like to see two PS2/USB-A footprints (either a PS2 or USB-A connector can be fitted in each position). This permits modern keyboards with USB connectors working in PS2 mode to be connected. I would like to see the pullup resistors able to be linked as pulldown so that we could try USB devices such as Bluetooth and the drivers done by scanlime (cannot just think of his name).
    I would prefer to ditch the VGA connector, and instead provide a 6pin header so the user can make a cable to a panel mount or backshell type VGA connector. Likewise, I would like to see a 2pin header and provision for the resistors for a TV connection.
    I think there would now be enough room for a resistor and LED (uncommitted each end) so that a user could place them and a connect to any prop pin to test it.
    5. Placement of the prop. I too have seen the problem where there is insufficient room whereas if it were moved more room could be gained. However, I am usnure where to move it to, and indeed if this would make the pcb any better. As a result, my thoughts are that it should remain where it is.
    FWIW I agree with:
    6. Adding the silkscreen legends to the underside of the pcb.
    7. Adding a 2pin reset header (much better than using the power switch and easy to get an old pc reset switch on a 2pin header).
    I hope this makes sense.
    Since the VGA connector now has no room, What Ab
    edited 2011-04-17 23:59
    Since everyone else is chiming in, here's my take on the ProtoBoard: The Prop placement in the center does somewhat limit the usability of the real estate, but to a lesser degree than the VSS rail down the right side, and the "linked" pins along the edges. I'm always trying to put DIP chips along there, and putting the right edge of a narrow DIP along the right edge of the board drops the left edge right on the VSS rail. I like the power and VSS rails along the top, I have yet to add PS2 or VGA connectors to any of my ProtoBoards, never use the reset button, and I've soldered directly to the barrel connector a few times to get access to the 6-9V coming in.
    edited 2011-04-18 08:28
    It still amazes me that users can ask for product changes and get a response from the person responsible for product decisions. I seldom see this in other environments. Further, to have the requests evaluated and acted on is unheard of. Perhaps its because I have a greater interaction with the community through this forum, in any case, Parallax is the most customer focused outfit I encounter. Thanks for the extra effort.
    edited 2011-04-18 18:56
    Well said prof_braino!
    I have never encountered such great interaction with a supplier in my entire design life (almost 40 years). I have been privy to new designs from Motorola, Rockwell, SSI, AMD, Apple and the like, all under NDA of course. I have first pass engineering samples of the Motorola 88100 RISC CPU.
    I only wish that more companies were like this, but then again, that is Parallax's advantage. And not only do they have this great attitude, they also have fantastic product !!!
    edited 2011-04-18 19:05
    Most other companies don't get this kind of feedback because they are either not open to it or already feel they have all the answers and what their customers should want. For the companies that may want it they might be so big that no one where hardly know where to go to make suggestions.
    Parallax is different (in a really, really good way) and they certainly listen to their customers. They already offer some great products and do care about suggestions to make them even better. Doesn't mean they will incorporate every request but at least they listen and consider them. More often they go well beyond that!
    edited 2011-04-18 19:17
    Thank you much. I do think that it would be helpful to others to include this in the future documentation revisions.
    edited 2011-04-18 22:00
    4. It would be nice if I could easily disable either (or both) the 5v and 3.3v regulators. Specifically, there are certain situations where I use USB power or a 5v out boost converter, and I "disable" the 5v regulator by unsoldering it. But it would be handy if I didn't have to remove it (a minor inconvenience), or even better use the regulator to provide 5v from a different power source to something like servos. Ultimately, just more power options and flexibility would be nice.
    5. Replacing a board is a pain. Usually, a board for me takes maybe 5-10 hours total time to solder up, and unsoldering is unlikely. I broke the board by accidentally lifting a robot by the USB connector, and I snapped it right off. I looked into fixing it, but I when I broke the USB I tore up the pads so I just had to wire up a prop plug setup instead (and scrape off the old FTDI chip...).
    Another one:
    6. Add in dedicated through holes to the board and notes to the documentation about adding capacitors to overclock the board.
    edited 2011-04-18 22:20
    I'd like to leave the 3 pads (used to select Vin or 5V) which power the four 3-pin header locations as they are. If I want a jumper I can easily add a three pin header connector. For something more permanent I can just solder a jumper wire. On a couple recent boards I add an extra 5V regulator to power the set of 3-pin headers and just take the VIN as the input to my regulator and put the output back to the center pin. I pickup the ground near where the regulator is mounted. I've included a picture that shows one way it can be done. I added the extra 5V regulator to handle a couple servos, PING, and I/R sensor. The on-board 5V powers a few IC's and some LED lighting.
    To pickup the /RESET line I just soldered to the side of the on-board reset switch but I'd prefer to have a pad to go to which is one of the reasons I suggested it. (And also reuse some old PC reset switches with the 2-pin header)
    Robert
    1024 x 770 - 158K
    edited 2011-04-19 07:04
    It may be nice if the VGA connections could be easily disconnected, leaving the adapter in tact so that a custom VGA circuit could be used. I am looking at a Prop ProtoBoard and I am hesitant to try to modify it by hand, as I do not wish to sacrifice other connections by a slip of hand, or an unknown berried conductor.
  • RDL2004RDL2004 Posts: 2,554
    edited 2011-04-19 07:08
    I know this is pretty frivolous, but I'd like to see the power LED changed to some other color - anything but green or yellow. Blue would be nice as long as it's not too bright. I often use a deep orange in my projects because it reminds me of those old school neon pilot lights.
    edited 2011-04-19 07:26
    Slightly off topic:
    Can any one suggest a safe way to disconnect the VGA connector leaving it intact? Would removing the surface mount resistors going to it be enough? If so does any one know a simple way to remove surface mount resistors (I always have difficulty with those tiny things)?
    We'll let this thread evolve for a few more days before we compile the master list of changes under consideration. I think we've collected about 90% of the suggestions, but a few more days would provide that guarantee.
    We will provide our compilation of changes on this thread.
    Thanks, Ken Gracey
