Serving files from SD Card
I am trying to write my own code for the spinneret using this code ==>Archive.zip. I need to incorporate an SD Card driver but I don't know how write the code for the SD Card driver. What code do I use and how do I incorporate it into my code? I want to have the server pull all of the files off of the card.
FinnCA
FinnCA
Here are a few posts. There are more if you look around a bit.
http://forums.parallax.com/showthread.php?127340-Basic-GET-and-POST-Object-Updated-1-1-2011
http://forums.parallax.com/showthread.php?130481-Using-SD3.01FATDEMO.spin-on-Spinneret-not-sure-of-the-Propeller-pinout
http://forums.parallax.com/showthread.php?129127-DEMO-Easy-HTML-with-the-Spinneret
Code bases
http://forums.parallax.com/showthread.php?128520-Google-Code-repository-for-open-source-Spinneret-Web-Server-firmware
http://www.agaverobotics.com/spinneret/source/
