Need help on simple xBee to xBee communications.
I have the all the latest XBee books including "Getting Started with XB RF Modules" and all the hardware needed for the projects in the books, and have understood most of the projects. I plan to continue working with those projects to further educate myself in the use of the XBee units.
However, in the mean time I have been working on, for most of the last 6 months, a favorite project of assembling propeller software and hardware for my large Robot Base Full kit. Now, I seem to be stumped on what I thought was a simple little XBee project.
I need to send a variable data set from one OBJ method to another and I am having trouble knowing where to start since all the complicated demos in the books seem to include the PC for part of the communications. I need to send from one XBee to another XBee, and nothing else.
Here is where I am: I have working well, a hardwired Joystick to a Motor Control OBJ, and now want to add xbee's to remote the Joystick.
OBJ
WCtrl : "Wheel_Controller"
PUB MAIN
WCtrl.JoyStick (CH1percent, CH0percent) ' I want to send the two variables to Wheel_Controller OBJ via XBee.
Would appreciate any help in getting started with the XBee progs.
Robert
OBJ
PUB MAIN
Robert
Robert
On the transmit side, use similar configuration code, but send data using something like this:
XB.Tx("!") ' start delimiter
XB.DEC(value1) ' first value
XB.TX(",") ' comma separator
XB.DEC(value2) ' 2nd value
XB.Tx(13) ' carriage return
It will send a string such as !10,20 (with CR)
-Martin
Martin, I followed the creation of your book on the forum, and should have had taken more time researching my problem before asking for help on such a simplistic problem. As I am celebrating my 81st next month I'm finding my technical aspirations are becoming harder to accomplish. I've been working on the autonomous part of my robot for months and doing pretty good on its development. Its equipt with two way cameras and all ten of the sensors, even though I don't think the ten are necessary but look good, and rudimentary conversational speech. My wife of 60 years and I am hoping we end up with a servant around the house -- like sending the bot to the other room with a tray of goodies, etc..
Thanks again,
Robert
I hope I'm still active in explore new areas at 81!. And yes, There should have been some simple uC to uC examples in the book.
-Martin
