Spruce Deuce
I can't put my finger on it, but there's something I really like about this robot: http://current.com/entertainment/comedy/92553624_plywood-robot-drummer.htm
JAFPRO: just another friggin' plywood robot: http://www.scientificsonline.com/robomech-wooden-kit.html
And now for something completely different in "plywood robots": http://www.youtube.com/watch?v=tYrf9YO4zM8
I really like the drummer. I wonder what model of servos he is using? The arms look like they’re made from 3/8 ply so I suspect they have a little bit of weight to them. They must be some high torque servos.
I could use the plywood destacker in my shop when I'm trying to move around a 4x8 sheet of 3/4 MDF.
Tony
doggiedoc - stay true...
erco. a pox upon you ;-)
Actually, the plywood stacker really does put it into perspective: The plywood is at the mercy of a metal and plastic robot. This is as it should be...
-Matt
Matt: I completely agree that the plywood stacker puts the whole master/slave/who's carrying who issue to rest. But I came to a dramatically different conclusion that you, as the attached photo attests. Don't worry, I'll always make a place for your plastic robots!
Why is this thread so winded, and bowed??
You're all warped.
Ironically, at some point in this machines life, some Millwright will need to wedge a piece of wood,
Into some part of it, in order for it to continue the rest of the shift...
erco, et. al. I too, believed in the power of cellulose - (I've built eleven custom homes). I think my aversion to your plywood affection is related to the proportion of splinters I've received over the years.
What then shall I do? I shall continue to stay true to non-splinter-producing plastics, if for no other reason than to irritate others on these Forums, an in particular erco ;-)
-Matt
Long before plastic, wood was king. Check these vidz... at least #1 and 3. First up: the 19th century wooden robo-Geisha writing a Kanji character is mighty fine! And the third video of the wooden robot arm (even though manually operated) is just fabulous.
http://www.build-robot.com/tag/wooden+robot
