So, you like wood robots eh?
Here's one that's in my garage right now. It's even got quite a bit of spruce in it!
The entire arm will be going to the FRC Championship in St Louis to replace the other wooden arm that is currently on our competition robot.
Rich H
Mentor, FRC team 1899
Rich H
Amanda
The arm in action;
A few pictures;
http://modelstation.smugmug.com/SaintsRobotics/2011-Build-Season/15830617_QRgEg#1186371375_MM8Lj
Is that You in the second vid, with the red Mohawk?
So what happens in that competition? are all those bots remote controlled?
The robots are both autonomous and remote controlled. In the second video, the yellow tube was hung entirely in autonomous mode. The robots that are not capable of autonomous operation are motionless for the first 20 seconds of the match.
The goal is to hang the inflated game pieces in the proper order. The higher they are hung, the more points they are worth. At the end of the match a small autonomous robot (minibot) is deployed onto a pole. You can see in the second video where we tried to deploy but the minibot failed to climb the pole. We now have a much better minibot.
You can read more about it here;
http://www.saintsrobotics.com/first/current-competition-logomotion/
Rich H
