remove and re-solder Prop QFP?
Hiya
My prop QFP IC seems to have issues. In a previous post it was identified that cog6 has bad ram and I think other issues are there too.
So I ideally need to replace the IC - its on a PCB with other £££ components (GPS, etc) so I can't afford to distroy the PCB pads etc in the process.
So I guess what I asking is either:
(1) Is there a company in the UK that could remove and replace for sensible money, not keen on individual due to cost of board
(2) Any good tips on removing IC? I have soldering iron and hot air station.
Help??
James
Help??
James
It's pretty easy with a hot air gun, just heat it up until it's free...
I have some old board's that I can practice on I suppose.
http://www.chipquikinc.com/
What it does is hidden in one of the links - it is a low melting point alloy that makes the solder melt at a much lower temperature. Then it is possible to get all the pads molten at the same time and at a temperature well below cooking the chip.
http://www.youtube.com/watch?v=jaarYY2Lxiw
It's basically Wood's metal (a bismouth alloy), supplied in a kit with jelly flux and cleaning pads. Just apply flux to the leads, lay the stuff on them, and heat with a soldering iron to melt it. The chip will come off in a few seconds. If the soldering iron is adjustable, a low temperature can be used.
I usually set mine to 600..700F, but since the chip is bad anyway, it doesn't really matter...
PS: When you're done use solder wick with an iron to clean up the pads for the new chip.
Or, you could just use the hot air gun at the ~600F range to put in the new chip without cleaning the pads...
Thanks all.
As with all repairs it is imprtant to decide what is the valuable bit if the kit, if the chip is being harvested for other projects then the board is the sacrificial part and if the board is to be maintained the the chip can be written off. Hot air is ok as long as it is directed at the solder joints fairly evenly, usually the correct four sided air nozzle but even then any components nearby will become unstuck if left open to the air blast. There are gums for this that set to a rubber like protection layer.
The air re-work stations are very expensive, if the chip is fairly exposed then a domestic paint stripper could be tried (with caution). Bring the whole board up to near temperature, frontand back and then give the part around the chip just that little bit more. That is what a lot of the high end IR stations do.
You could thread some very fine wire, from some stripped back flex, around some diagonaly opposite pins, so that the instant that the solder become liquid then it could be gently lifted. I used to practice on old PCBs just so that mistakes didn't matter.
Putting the new chip back is just a case of getting the chip into the correct position and the fixing down a couple of pins in opposite corners and the going around the rest. liquid flux helps a lot here.
I have a re-work hot air station (£85) so will try that on 150c and see whata happens.
I have some test boards to play with from previous versions.
Graham
So I tried the chip-quik method, and its really good. Got the old IC off no problems, but screwed up soldering of the new one. Removed it too and now waiting for another IC....
http://javalins.wordpress.com/2011/04/12/prop-ic-removal-part-1/
James
This is the method I used when building the modules here:
http://forums.parallax.com/showthread.php?92127-NEW-40-pin-Propeller-prototype-module-Most-hackable-yet&highlight=bs2p40
Robert
and solder wick to remove the remaining leads from the board. The goal here is to protect the PC Board at all costs.
10 / 10 for the chip-quick though.
J
I've run into issues with some off-brand solder wick. As long as you get a good quality solder wick the stuff works great. I'll see if I can get the brand/model of one I use now if that would help. I'm sure there are many good ones out there but there some out there that just don't work.
Robert
Ordered : http://uk.farnell.com/jsp/search/productdetail.jsp?SKU=4754256 and http://uk.farnell.com/jsp/search/productdetail.jsp?SKU=860670
have also seen this from Sparkfun : http://www.sparkfun.com/products/8775
James
has a clean small point. I usually blob a bunch of solder on all the pads on one side to clean off
the remaining leads then clean off the pads with the solder wick for the next chip.
I have used lots of the Chemtronics version (second, blue cased sort that you showed from Farnell) , mostly because an ex-workmate fell for the "I'll order 50 of those" and got 50 of the 10 packs. But they are running out now. The flux pens are useful with ordanary solder (full leaded of course).
I have never got on with solder paste but then I found out that it has a shelf life, even whilst kept in ideal conditions.
NTE # SW02-25 No-Clean Wick.
Seems to work well.
