Need Help with IR sensors — Parallax Forums
marrienmarrien Posts: 3
edited 2011-04-10 19:35 in General Discussion
Attached the IR sensors to BOE BOT. Wrote the following program to test. Once the sensors detect an object, the 2 irDetect values remain at 0 regardless of where I placed the BOT.
irDetectLeft VAR Bit ' Variable Declarations..
irDetectRight VAR Bit
counter VAR Bit
FREQOUT 4, 2000, 3000
DO ' Main Routine..
FREQOUT 8, 1, 38500 ' Check IR Detectors..
irDetectLeft = IN9
FREQOUT 2, 1, 38500
irDetectRight = IN0
DEBUG CLS
IF (irDetectLeft = 0) AND (irDetectRight = 0) THEN 'Interference found
DEBUG CRSRXY, 2, 3, BIN1 irDetectLeft,
CRSRXY, 9, 3, BIN1 irDetectRight
ELSE 'No interference
DEBUG CR, "i am here"
ENDIF
PAUSE 1000
LOOP
    edited 2011-04-10 14:28
    What do you mean by "once the sensors detect an object"? How do you have things connected?
  • marrienmarrien Posts: 3
    edited 2011-04-10 15:31
    I followed the book - Chapter 7 to connect the IRs. I placed my finger in front of the IRs. I get values "0". When I removed my finger, the values remain at "0".
    edited 2011-04-10 15:38
    If that's the behavior you're seeing, you've wired something wrong. How do you have things connected? ... actually connected, not what you think it's supposed to be. It's a common error. You've followed the book and it doesn't work. When you very carefully trace out what's actually connected to what, you find that it's different from what the book shows.
    edited 2011-04-10 15:49
    Are you able to see if there's anything wrong with the wiring? Thanks for your help.
    730 x 548 - 102K
    1024 x 768 - 114K
    edited 2011-04-10 18:06
    The resistor (red-red-brn) from P9 - is that going to the IR_Det right?
    Looks like that R is going to Det's middle terminal?
    [Should be in the 3rd row down from the V_ss header.]
    The leads of the resistors in P0 and P2 look very close (touching?).
    PE - There's also a note on p243 about sensitivity and experimenting with resistor values for the IREDs (IRLEDs).
    edited 2011-04-10 18:20
    I can't tell looking at the photo. You're really going to have to carefully check this out yourself. Make sure there are no shorts and trace each wire, maybe recreate the schematic from the wiring itself forgetting what's in the book, then check the two diagrams agains each other.
