servo and two pushbuttons
hello guys am new to this am learing parallax in my programing class one of the mini projects is to make a a servo go Clockwise and Counterwise with two push buttons. one button for ClockWise and another button for counter clockwise.
i was told i can modify this but i cant see to fish out the problem
this example id from what a microcontroler
' What's a Microcontroller - ServoControlWithPushbuttons.bs2
' Press and hold P4 pushbutton to rotate the servo counterclockwise,
' or press the pushbutton connected to P3 to rotate the servo clockwise.
' {$STAMP BS2}
' {$PBASIC 2.5}
duration VAR Word
duration = 750
PAUSE 1000
DO
IF IN3 = 1 THEN
IF duration > 500 THEN
duration = duration - 25
ENDIF
ENDIF
IF IN4 = 1 THEN
IF duration < 1000 THEN
duration = duration + 25
ENDIF
ENDIF
PULSOUT 14, duration
PAUSE 10
DEBUG HOME, DEC4 duration, " = duration"
LOOP
' {$STAMP BS2}
' {$PBASIC 2.5}
duration VAR Word
duration = 750
PAUSE 1000
DO
IF IN3 = 1 THEN
ENDIF
ENDIF
IF IN4 = 1 THEN
ENDIF
ENDIF
PAUSE 10
LOOP
It's all done for you. What's not to love?
Check the wiring on your switches. Are you using pulldown resistors? P3 and P4 each need a ~10K resistor going to ground (Vdd), in addition to the switch that connects them to Vcc (5V).
Two Led recation timer with two push buttons so to start i used this program wich is from the hand out but only one is working. i need to be able to push both of the push buttons down and when i relese one of the push buttons it sends a time but i am only geting one to work any help on programing would be helpfull
' What's a Microcontroller - PushbuttonControlOfTwoLeds.bs2
' Blink P14 LED if P3 pushbutton is pressed, and blink P15 LED if
' P4 pushbutton is pressed.
' {$STAMP BS2}
' {$PBASIC 2.5}
PAUSE 1000
DO
DEBUG HOME
DEBUG ? IN4
DEBUG ? IN3
IF (IN3 = 1) AND (IN4 = 1) THEN
HIGH 14
HIGH 15
PAUSE 50
ELSEIF (IN3 = 1) THEN
HIGH 14
PAUSE 50
ELSEIF (IN4 = 1) THEN
HIGH 15
PAUSE 50
ELSE
PAUSE 50
ENDIF
LOW 14
LOW 15
PAUSE 50
LOOP
Thanks Ax
' What's a Microcontroller - ReactionTimer.bs2[/SIZE][/FONT] [FONT=Calibri][SIZE=3]' Test reaction time with a pushbutton and a bicolor LED.[/SIZE][/FONT] [FONT=Calibri][SIZE=3]' {$STAMP BS2}[/SIZE][/FONT] [FONT=Calibri][SIZE=3]' {$PBASIC 2.5}[/SIZE][/FONT] [FONT=Calibri][SIZE=3]PAUSE 1000[/SIZE][/FONT] [FONT=Calibri][SIZE=3]timeCounter VAR Word[/SIZE][/FONT] [FONT=Calibri][SIZE=3]DEBUG"Press andhold both pushbutton", CR,[/SIZE][/FONT] [FONT=Calibri][SIZE=3]"to makelight turn red.", CR, CR,[/SIZE][/FONT] [FONT=Calibri][SIZE=3]"Whenlight turns green, let", CR,[/SIZE][/FONT] [FONT=Calibri][SIZE=3]"go asfast as you can.", CR, CR[/SIZE][/FONT] [FONT=Calibri][SIZE=3]DEBUG HOME, CR[/SIZE][/FONT] [FONT=Calibri][SIZE=3]DEBUG IN3, CR[/SIZE][/FONT] [FONT=Calibri][SIZE=3]DEBUG IN4, CR[/SIZE][/FONT] [FONT=Calibri][SIZE=3]DO[/SIZE][/FONT] [FONT=Calibri][SIZE=3]DO[/SIZE][/FONT] [FONT=Calibri][SIZE=3]LOOP UNTIL IN3 = 1AND IN4 = 1[/SIZE][/FONT] [FONT=Calibri][SIZE=3]HIGH 14[/SIZE][/FONT] [FONT=Calibri][SIZE=3]LOW 15[/SIZE][/FONT] [FONT=Calibri][SIZE=3]PAUSE 1000[/SIZE][/FONT] [FONT=Calibri][SIZE=3]LOW 14[/SIZE][/FONT] [FONT=Calibri][SIZE=3]HIGH 15[/SIZE][/FONT] [FONT=Calibri][SIZE=3]timeCounter = 0[/SIZE][/FONT] [FONT=Calibri][SIZE=3]timeCounter = 0[/SIZE][/FONT] [FONT=Calibri][SIZE=3]DO[/SIZE][/FONT] [FONT=Calibri][SIZE=3]PAUSE 1[/SIZE][/FONT] [FONT=Calibri][SIZE=3]timeCounter =timeCounter + 1[/SIZE][/FONT] [FONT=Calibri][SIZE=3]LOOP UNTIL IN3 = 0OR IN4 = 0[/SIZE][/FONT] [FONT=Calibri][SIZE=3]LOW 15[/SIZE][/FONT] [FONT=Calibri][SIZE=3]DEBUG "Yourtime was ", DEC timeCounter,[/SIZE][/FONT] [FONT=Calibri][SIZE=3]" ms.",CR, CR,[/SIZE][/FONT] [FONT=Calibri][SIZE=3]"To play again,hold the ", CR,[/SIZE][/FONT] [FONT=Calibri][SIZE=3]"button downagain.", CR, CR[/SIZE][/FONT] [SIZE=3][FONT=Calibri]LOOP[/FONT][/SIZE] [FONT=Calibri][SIZE=3]
