Automated House
I've been working on the Basic Stamp PDB schematics for a home control panel, but my end result was never exactly correct. I tried thinking about it, and it hit me, I couldn't use a Basic Stamp PDB for a whole home control panel that connects to every electrical appliance and expect it to automate them, I needed the multicore processing power of the propeller chip, so I started working on another schematic with a P8X32A-M44 chip (also used in the propstick) and added an optical system, 7 segment LCD display, LEDs, pushbuttons, IR reciever, phototransistor, potentiometer, Op-amp and A/D converter ICs. I made sure to add an infrared reciever, with a 220 ohm resistor for a 3 function universal remote, for easy manual control. But that is beside the point, if I tried to install it, how would I be able to directly connect all of the appliances in my home to actually make an operational Propeller PDB home control panel?
You could still use a Propeller and there is an object for X-10 control, but this is certainly a task that a Stamp could handle.
