Catalina 3.0 - Page 2 — Parallax Forums
Catalina 3.0
2456717
    edited 2011-04-07 16:12
    Okay, thanks for the suggestion. That will work for now. I think it would be better to allow the declaration decorations though since your approach depends on the fact that Catalina currently puts the stack and hence local variables in hub memory. If a new memory layout were to be defined that placed the stack in external memory this technique wouldn't work any more. Seems like it would be better to be explicit about where variables are to be allocated.
    I found I kept forgetting the rules, so I solved the problem by always adding a comment after an array declaration. Declare an array at the beginning? Then add a comment "// this array is in external memory".
    Declare an array in the "main" or in a function? Add a comment "// this array is in hub memory".
    This has worked so far for my ailing memory!
    Re the RTC, I've got cogjects working in C for a graphics driver and for serial. I like this approach because the C is standard looking C, with no tricks. The pasm part can be loaded, run, and for a RTC, this is where the pasm part could be overwritten with something else once it has run and you have read/changed the time.
    Then you just need some C code to replicate the Spin code. I might take a look at this when I get home.
    I'm finding it more flexible to do things this way rather than asking Ross to add code 'internally' to catalina.
  • RossHRossH Posts: 5,642
    edited 2011-04-07 16:19
    lonesock wrote: »
    +-/*sqrt all match and are faster. ATan, ATan2, ACos, ASin are more accurate and faster (uses CORDIC now; original used a 5th order polynomial approximation with 2 sqrts!! Aslo, the original Atan2 performed a division, then called ATan.) I also added Exp2 and Log2, as well as the other functions from Float32A. (the original also had issues with the Exp & Log functions for very large and very small values). All that to say, I'm done testing against Excel, and haven't uncovered any corner cases where it fails, though I'm sure they exist. F32 has at least fixed a bunch of corner cases that existed in the original code.
    Jonathan
    Thanks Jonathan. I'll look at integrating it for the next release.
    Ross.
    edited 2011-04-07 16:25
    ... maybe this really belong to the 2.9 thread, it's untested on 3.0.
    No worries - I'll try and get time this weekend to come up with a 3.0 equivalent. Also, if you are considering creating a new target directory, consider starting from the "custom" target directory (i.e. C:\Program Files\Catalina\custom) - that is intended to be a "minimal" target directory. It is probably a lot less intimidating to start from that and add stuff rather than starting from the "target" directory and removing stuff!
    Ross.
    edited 2011-04-07 16:31
    Dr_Acula wrote: »
    Hi Dr_A.
    I keep hoping that Catalina is advanced and mature enough that it is no longer necessary for me to do all the work (not that I don't want to - more that I don't always have the the time!).
    I think the work that you're doing is good evidence that this may finally be coming true!
    Ross.
    edited 2011-04-10 02:06
    Yes, I think we are flying solo now!
    I managed to take some quite obfuscated Spin code and convert it into C, and I didn't have to ask once for help:
      xPixel := ((xPixel <# (320 - 1)) #> 0)  ' 320 = horizontal pixels
      screen += (((20 * ((yPixel <# (240 - 1)) #> 0)) + (xPixel >> (5 - bitsPerPixel))) << 2) ' 20 is horizontal longs, 240 = vertical pixels
      xPixel := ((xPixel & ($1F >> bitsPerPixel)) << bitsPerPixel)
      yPixel := (!((1 + (bitsPerPixel << 1)) << xPixel))
      long[screen] := ((long[screen] & yPixel) | (((pixelValue <# (1 + (bitsPerPixel << 1))) #> 0) << xPixel))
    More specifically, this is part of another cogject, and these can be loaded and run independent of the catalina system.
    This demo program loads up a 64 color demo, draws some boxes and pixels, then unloads that and loads in a 4 color grayscale demo at higher resolution. See attached photo. I think this has the potential to be the beginnings of a GUI for the propeller.
    See the attached cog files - unzip these and put them on the sd card. The nice thing about these .cog files is that they are the same ones I'm using for the Spin demonstration. Potentially this could be done in Propbasic as well.
    Next step is to create some font libraries. Almost at the "Hello World" stage!
    /* PASM cogject demonstration, see also cogject example in spin*/
    #include <stdio.h>
    #include <string.h>
    	unsigned long cogarray[512];					// external memory common cog array
    	unsigned long screen_external[4800]	;			// external memory for a screen buffer
    // start of C functions
    void clearscreen()                                                   // white text on dark blue background
           int i;
           for (i=0;i<40;i++)
                   t_setpos(0,0,i);                                      // move cursor to next line
                   t_color(0,0x08FC);                                    // RRGGBBxx eg dark blue background 00001000 white text 11111100
    void sleep(int milliseconds)                                         // sleep function
           _waitcnt(_cnt()+(milliseconds*(_clockfreq()/1000))-4296);
    char peek(int address)                                               // function implementation of peek
           return *((char *)address);
    void poke(int address, char value)                                   // function implementation of poke
           *((char *)address) = value;
    void external_memory_cog_load(int cognumber, unsigned long cogdata[], unsigned long parameters_array[])    	//  load a cog from external memory
    	unsigned long hubcog[511];						// create a local array, this is in hub ram, not external ram
    	int i;
    	for(i=0;i<512;i++)
    		hubcog[i]=cogdata[i];					// move from external memory to a local array in hub
     	_coginit((int)parameters_array>>2, (int)hubcog>>2, cognumber);		// load the cog
    int EoF (FILE* stream)
      	register int c, status = ((c = fgetc(stream)) == EOF);
      	ungetc(c,stream);
      	return status;
    void readcog(char *filename,unsigned long external_cog[])		// read in a .cog file into external memory array
    	int i;
    	FILE *FP1;
    	i = 0;
    	if((FP1=fopen(filename,"rb"))==0)					// open the file
      		fprintf(stderr,"Can't open file %s\n",filename);
    		exit(1);
      	fseek(FP1,0,0);
    	for(i=0;i<24;i++)
    		getc(FP1);							// read in the first 24 bytes and discard
    	i = 0;
      	while(!EoF(FP1) & (i<505))						// run until end of file or 511-6
    		external_cog[i] = getc(FP1) | (getc(FP1)<<8) | (getc(FP1)<<16) | (getc(FP1)<<24);	// get the long
    		i+=1;
    	if(FP1)
         		fclose(FP1);							// close the file
         		FP1=NULL;
    	printf("external array cog first long = 0x%x \n",external_cog[0]);	// hex value
    void pix_clearscreen(unsigned long screen[])
    	int i;
    	for (i=0;i<4800;i++)
    		screen[i] = 0x00000000;		// fill with black, use longs rather than bytes so 4 pixels per loop
    void pix_pixel(unsigned long screen[], int x, int y, char color)
    	poke((y*160+x+(unsigned long)&screen[0]),color);
    void pix_readscreen(char *filename, unsigned long screen[])		// read a full screen 19200 byte file into the screen
    	int i;
    	FILE *FP1;
    	i = 0;
    	FP1=fopen(filename,"rb");					// open the file
      	fseek(FP1,0,0);
    	for(i=0;i<=4800;i++)
    		screen[i] = getc(FP1) | (getc(FP1)<<8) | (getc(FP1)<<16) | (getc(FP1)<<24);	// get the long
         	FP1=NULL;
    char pix_color(char red,char green,char blue)				// pass red,green,blue 0-3, returns a combined value
    	return ((red & 0x3) << 6 ) | ((green & 0x3) << 4) | ((blue & 0x3) << 2);
    void pixenginestart(int cognumber, unsigned long cogarray[], unsigned long screen[], unsigned long pingroup, char color_parameters[])
    	int i;
    	unsigned long frequencystate;
    	screen[2] = (0xff << (8*pingroup));
    	screen[3] = (0x300000ff | (pingroup << 9));
    	frequencystate = ((25175000 + 1600) / 4);
    	screen[4] = 1;
    	for(i=0;i<32;i++)
    		frequencystate = frequencystate << 1;
    		screen[4] = (screen[4] << 1) | (screen[4] >> 31);
    		if (frequencystate >= _clockfreq())
    			frequencystate -= _clockfreq();
    			screen[4] += 1;
    	color_parameters[0] = 1;			// displayindicator
    	color_parameters[1] = 0;			// syncindicator
    	screen[0] = (unsigned long) &color_parameters[0]; // pointer to displayindicator
    	screen[1] = (unsigned long) &color_parameters[1]; // pointer to syncindicator
    	//_cogstop(0); // not video
    	_cogstop(1); // video shut down this driver
    	// cog 2 is catalina
    	_cogstop(3); //  video shut down this driver
    	//_cogstop(4); // not sure what this does, hangs prop when add this
    	//_cogstop(5); // not video
    	//_cogstop(6); // not video
    	external_memory_cog_load(7,cogarray,screen);		// load from external ram, pass some values in screen[]
    	pix_clearscreen(screen);					// clear the screen to black
    void pix_colorbar(unsigned long screen[])
    	int x;
    	int c;
    	x = 0;
    	for (c=0;c<64;c++)
    		pix_pixel(screen,x+10,6,(c<<2));			// print all the colors in a bar
    		x++;
    void pix_line(unsigned long screen[], int startx, int starty, int endx, int endy, char color)
    	int row;								// also does an unfilled box
    	int col;
    	for(col=startx;col <= endx ;col++)
    		pix_pixel(screen,col,starty,color);			// horizontal lines
    		pix_pixel(screen,col,endy,color);
    	for(row=starty;row <= endy;row++)
    		pix_pixel(screen,startx,row,color);
    		pix_pixel(screen,endx,row,color);
    void pix_box_fill(unsigned long screen[], int startx, int starty, int endx, int endy, char color)
    	int row;
    	int col;
    	for(row =starty;row <= endy; row++)
    		for(col=startx;col <=endx; col++)
    			pix_pixel(screen,col,row,color);			// horizontal line
    void copyscreen(unsigned long source[],unsigned long destination[])
    	memcpy(destination,source,19200);					// a strings.h function
    void pix_screengray(unsigned long screen[])				// whole screen gray
    	int i;
    	for(i=0;i<4800;i++)
    		screen[i] = 0xa8a8a8a8;					// same as pix_color(2,2,2)
    void color_demo(unsigned long screen[],char color_parameters[])					// kye graphics demo
    	clearscreen();							// white on blue vga
           printf("Clock speed %u \n",_clockfreq());                     // see page 28 of the propeller manual for other useful commands
           printf("Catalina running in cog number %i \n",_cogid());      // integer
    	printf("Kye graphics demonstration \n");
    	//sleep(2000);								// 2 sec delay
    	readcog("vgagraph.cog",cogarray);					// read in kye's graphics driver
           pixenginestart(7,cogarray,screen,2,color_parameters);				// start the driver
           pix_pixel(screen,3,3,0x44);
    	pix_pixel(screen,4,4,0xFF);
    	pix_pixel(screen,5,5,pix_color(1,2,3));				// rgb each 0,1,2 or 3
    	pix_line(screen,0,0,159,119,pix_color(3,0,0));			// red border for screen
    	pix_colorbar(screen);						// a color bar
    	pix_line(screen,10,10,30,30,pix_color(3,3,0));		// a yellow box
    	pix_box_fill(screen,10,50,40,60,pix_color(3,0,3));		// magenta filled rectangle
    	//pix_readscreen("wallaby.vga",screen);				// display whole screen image
    	//copyscreen(screen,screen_external);				// copy to external ram
    	//pix_readscreen("Giraffe.vga",screen);				// display whole screen image
    	//copyscreen(screen_external,screen);				// copy back to hub
    	//pix_readscreen("prop160.vga",screen);				// display whole screen image
    	//pix_box_fill(screen, 0, 0, 159,119,pix_color(2,2,2));		// whole screen gray
    // ****************** end color screen code *********************************
    // ****************** begin gray screen code ********************************
    void gray_pixel(unsigned long screen[], unsigned long x, unsigned long y, unsigned long color)
    	// unsigned long bitsperpixel = gray_parameters[3];
    	unsigned long bitsperpixel = 1;		// always is 1
    	unsigned long i;
    	i = (x >>4) + (20 * y);		// i = the long that contains our pixel
           x = ((x & (0x1f >> bitsperpixel)) << bitsperpixel);
    	//mask = (0x3 << xpixel); 	// xpixel holds the number of bits to shift to the left, and invert this
    	//mask = ~mask;				// invert this
    	screen[i] = (( screen[i] & ~(0x3 << x)) | (color << x)); // do the and with a mask and the or in one line
    void gray_line(unsigned long screen[], int startx, int starty, int endx, int endy, char color)
    	int col;
    		gray_pixel(screen,col,starty,color);			// horizontal lines
    		gray_pixel(screen,col,endy,color);
    		gray_pixel(screen,startx,row,color);
    		gray_pixel(screen,endx,row,color);
    void gray_box_fill(unsigned long screen[], int startx, int starty, int endx, int endy, char color)
    	int row;
    	int col;
    			gray_pixel(screen,col,row,color);			// horizontal line
    void gray_button(unsigned long screen[],int startx, int starty, int sizex, int sizey, char *lineoftext)
    	gray_line(screen, startx, starty, startx, starty+sizey, 0x3);					// white vertical line
    	gray_line(screen, startx, starty, startx+sizex, starty, 0x3);					// white horizontal line
    	gray_line(screen, startx+sizex, starty+1, startx+sizex, starty+sizey-1, 0x1); 		// vertical dark gray line
    	gray_line(screen, startx+1, starty+sizey, startx+sizex, starty+sizey, 0x1); 		// horizontal dark gray line
    	gray_line(screen, startx+sizex+1, starty, startx+sizex+1, starty+sizey+1, 0x0); 		// vertical black line
    	gray_line(screen, startx, starty+sizey+1, startx+sizex+1, starty+sizey+1, 0x0); 		// horizontal black line
    	// add in the text
    void gray_text(unsigned long screen[], int startx, int starty, int sizex, int sizey, char *lineoftext)
    	gray_box_fill(screen, startx+1, starty+1, startx+sizex-1, starty+sizey-1,0x3);		// white centre
    	gray_line(screen, startx, starty, startx, starty+sizey-1, 0x0);				// black vertical line
    	gray_line(screen, startx, starty, startx+sizex-1, starty, 0x0);				// black horizontal line
    	gray_line(screen, startx+sizex, starty, startx+sizex, starty+sizey,0x2); // vertical light gray line
    	gray_line(screen, startx, starty+sizey, startx+sizex, starty+sizey, 0x2); // horizontal light gray line
    	gray_line(screen, startx-1, starty-1, startx-1, starty+sizey+1, 0x1);		// dark gray vertical line
    	gray_line(screen, startx-1, starty-1, startx+sizex, starty-1, 0x1);		// dark gray horizontal line
    	gray_line(screen, startx+sizex+1, starty-1, startx+sizex+1, starty+sizey+1, 0x3); // vertical whiteline
    	gray_line(screen, startx-1, starty+sizey+1, startx+sizex, starty+sizey+1, 0x3); // horizontal whiteline
    void gray_radio(unsigned long screen[], int startx, int starty, char check)
    	char radio[144] = {				// black = 0x0, dark gray = 0x1, light gray = 0x2, white = 0x3
    	0x2,0x2,0x2,0x2,0x1,0x1,0x1,0x1,0x2,0x2,0x2,0x2,	// a radio button
    	0x2,0x2,0x1,0x1,0x0,0x0,0x0,0x0,0x1,0x1,0x2,0x2,
    	0x2,0x1,0x0,0x0,0x3,0x3,0x3,0x3,0x0,0x0,0x3,0x2,
    	0x2,0x1,0x0,0x3,0x3,0x3,0x3,0x3,0x3,0x2,0x3,0x2,
    	0x1,0x0,0x3,0x3,0x3,0x3,0x3,0x3,0x3,0x3,0x2,0x3,
    	0x2,0x1,0x2,0x2,0x3,0x3,0x3,0x3,0x2,0x2,0x3,0x2,
    	0x2,0x2,0x3,0x3,0x2,0x2,0x2,0x2,0x3,0x3,0x2,0x2,
    	0x2,0x2,0x2,0x2,0x3,0x3,0x3,0x3,0x2,0x2,0x2,0x2
    	int x;
    	int y;
    	int i = 0;
    	if(check !=0)
    		radio[53]=radio[54]=0x00;
    		radio[64]=radio[65]=radio[66]=radio[67]=0x00;		// draw the circle in the middle
    		radio[76]=radio[77]=radio[78]=radio[79]=0x00;
    		radio[89]=radio[90]=0x00;
    	for(y=0;y<12;y++)
    		for(x=0;x<12;x++)
    			gray_pixel(screen,startx+x, starty+y, radio[i]);	// draw a radio button, white centre
    			i++;
    void gray_letter(unsigned long screen[], int startx, int starty)	// draw a letter A on the screen in black with white background - for testing
    	char letter[63] = {
    	0x3,0x3,0x3,0x0,0x3,0x3,0x3,
    	0x3,0x3,0x0,0x3,0x0,0x3,0x3,
    	0x3,0x0,0x3,0x3,0x3,0x0,0x3,
    	0x3,0x0,0x0,0x0,0x0,0x0,0x3,
    	0x0,0x3,0x3,0x3,0x3,0x3,0x0,
    	int x,y;
    	int i =0;
    	for(y=0;y<9;y++)
    		for(x=0;x<7;x++)
    			gray_pixel(screen,startx+x, starty+y, letter[i]);	// draw a letter
    			i++;
    void gray_clearscreen(unsigned long screen[])
    	int i;
    		screen[i] = 0xaaaaaaaa;		// fill with light gray, use longs rather than bytes so 4 pixels per loop
    void gray_engine_start(int cognumber, unsigned long cogarray[], unsigned long screen[], unsigned long gray_parameters[])
    	unsigned long pingroup = 2;						// pins 16 to 23
    	int i;
    	gray_parameters[0] = 0xfca85400;				// pixelcolors in reverse order
    	gray_parameters[1] = 1;					// displayindicator
    	gray_parameters[2] = 0;					// syncindicator
    	gray_parameters[3] = 2;					// bitsperpixel, starts at 2 but gets changed later to 1
    	screen[0] = (unsigned long) &screen[0];			// the first long in the screen array now points to the location of itself
    	screen[1] = (unsigned long) &gray_parameters[1];	// pointer to displayindicator
    	screen[2] = (unsigned long) &gray_parameters[2];	// pointer to syncindicator
    	screen[3] = (0xff << (8*pingroup));
    	screen[4] = (0x200000ff | (pingroup << 9) | ((gray_parameters[3] -1) << 28));   // (0x200000ff | (pingroup << 9) | ((bitsperpixel-1) << 28)); this one not working
    	gray_parameters[3] = gray_parameters[3]  - 1;             // bitsperpixel now equal to 1, used below
    	frequencystate = ((25175000 + 1600) / 4);					// calculate frequencystate
    	screen[5] = 1;
    	for(i=0;i<32;i++)
    		screen[5] = (screen[5] << 1) | (screen[5] >> 31);
    			screen[5] += 1;
    	screen[6] = 2;						// horizontal scaling
    	screen[7] = 2;						// vertical scaling
    	screen[8] = 320;						// horizontal pixels
    	screen[9] = 240;						// vertical pixels
           screen[10] = ((screen[6] << 12) + (((640 * 32) >> gray_parameters[3] ) / screen[8])); // visible scale
    	screen[11] = (((8 << gray_parameters[3] ) << 12) + 160);	// invisible scale
           screen[12] = (screen[8] / (32 >> gray_parameters[3] ));	// horizongal longs
    	screen[13] = screen[12] * 4;				// horizontal loops
    	screen[14] = (unsigned long) &gray_parameters[0];	// pixel colors
    	_cogstop(1);							// stop graphics cog
    	_cogstop(3);							// stop graphics cog
    	gray_clearscreen(screen);
    void gray_demo(unsigned long screen[], unsigned long gray_parameters[])
    	printf("Gray scale 320x240 graphics demonstration \n");
    	readcog("vga320.cog",cogarray);
    	gray_engine_start(7,cogarray,screen,gray_parameters);
    	gray_button(screen, 50,50,40,20,"Button1");			// a button
    	gray_text(screen, 200,80, 40, 20, "Text1");			// a text box
    	gray_letter(screen,210,87);						// print a letter A in the text box
    	gray_radio(screen, 10,10,1);						// a checked radio button
    	gray_radio(screen, 10,30,0);						// an unchecked radio button
    void main ()
    	char color_parameters[1];						// displayindicator and syncindicater are permanent hub variables
    	unsigned long screen[160*120/4];					// graphics and text video buffer in hub - eg 19200 bytes
    	unsigned long gray_parameters[4];					// permanent hub variables for the gray 320x240 driver
    	color_demo(screen,color_parameters);
    	gray_demo(screen, gray_parameters);				// gray screen demo
    	while (1); 								// endless loop as prop reboots on exit from main()
    915 x 801 - 94K
    edited 2011-04-11 03:13
    Hi Ross
    I was thinking of a standardized configuration, like DemoBoard+RamBlade or ProtoBoard in strict "DemoBoard wannabe mode" i.e. with VGA/PS2 kit and RamBlade, using 3 fixed pins from P0..P7 range.
    Hi Alesandro,
    I have attached a skeleton to show how I would implement such dual-cpu support in Catalina 3.0. I have defined a new platform called DEMOBLADE - which also requires you to specify either CPU_1 or CPU_2.
    CPU_1 looks like a DEMO board but without TV support, and CPU_2 looks like a RAMBLADE with XMM support. I have included amended versions of Catalina_Common.spin as well as HMI.inc and XMM.inc (which are the most complex files you would probably need to modify).
    Of course, I have not actually tested any of it!
    Let me know if you have any questions.
    Ross.
  • AntoineDoinelAntoineDoinel Posts: 312
    edited 2011-04-11 16:23
    Ross
    thanks so much for spending some time on this.
    I'm sorry I didn't post the inc files too, I made that thing on 2.9 some weeks ago, and completely forgot about having to modify those too.
    Now I'm getting there again, translating the build_morpheus_xxx files to build_demoblade_xxx, they are close enough and compilation goes well. I seem to recall I had to tweak the VGA frequencies for my stupid LCD panel, and after that most proxy demos were working fine (using a fixed proxy, loaded in eeprom on the demo/proto side.
    When I get the build files done I'll upload them here, Cluso had a similar configuration pictured in the RamBlade thread, so maybe he'll want to give it a try.
    Thanks again
    Alessandro
    edited 2011-04-13 06:59
    The PropGUI is starting to take shape, see photo at the bottom. We have a font now and external memory is the perfect place for this - doesn't take up precious hub ram but is faster than putting it on an SD card.
    Textbox, Button, Radio, Menu, Label and Groupbox all working. Easy to use in C:
    	gray_printf(screen, 8,8,"File      Edit       Program");	// print menu text on the screen
    	gray_button(screen, 10, 40,50,19,"Button1");			// a button
    	gray_button(screen, 100,40,50,19,"Button2");			// a button
    	gray_text(screen, 10, 70, 70,16, "Textbox1");			// a text box
    	gray_text(screen, 100,70, 70,16, "Textbox2");			// a text box
    	gray_radio(screen, 10,100,1,"Radio1");				// a checked radio button
    	gray_radio(screen, 10,120,0,"Radio2");				// an unchecked radio button
    	gray_groupbox(screen,140,110,100,85,"GroupBox1");		// draw groupbox
           gray_printf(screen, 150,125,"Label1");				// print text on the screen
    	gray_printf(screen, 150,145,"Label2");				// print text on the screen
    	gray_printf(screen, 150,165,"Label3");				// print text on the screen
    (everything starts with "gray" to distinguish from the chunkier color version).
    Full code below including the font array:
    #include <stdio.h>
    #include <string.h>
    // 128 rows, one for each ascii character 0 to 127
    // first long is 0000HHWW where HH is the height in hex and WW is the width in hex
           unsigned long sans_serif_font[1664] =
                  0x00000c00,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000000, 0x00000007, 0x00000005, 0x00000005, 0x00000005, 0x00000005, 0x00000005, 0x00000005, 0x00000007, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000000, 0x00000002, 0x00000000, 0x00000000,
                  0x00000c05,0x00000000, 0x00000009, 0x00000009, 0x00000009, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x00000012, 0x00000012, 0x0000003f, 0x00000012, 0x00000012, 0x00000012, 0x0000003f, 0x00000012, 0x00000012, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000004, 0x0000000e, 0x00000015, 0x00000014, 0x0000000c, 0x00000006, 0x00000005, 0x00000015, 0x0000000e, 0x00000004, 0x00000000,
                  0x00000c08,0x00000000, 0x00000030, 0x00000049, 0x00000032, 0x00000004, 0x00000008, 0x00000010, 0x00000026, 0x00000049, 0x00000006, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000008, 0x00000014, 0x00000014, 0x00000008, 0x00000008, 0x00000015, 0x00000012, 0x00000012, 0x0000000d, 0x00000000, 0x00000000,
                  0x00000c02,0x00000000, 0x00000001, 0x00000001, 0x00000001, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000001, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000001,
                  0x00000c03,0x00000000, 0x00000002, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000002,
                  0x00000c04,0x00000000, 0x00000005, 0x00000002, 0x00000005, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000004, 0x00000004, 0x0000001f, 0x00000004, 0x00000004, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000001, 0x00000002, 0x00000000,
                  0x00000c03,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000003, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000002, 0x00000000, 0x00000000,
                  0x00000c05,0x00000000, 0x00000001, 0x00000001, 0x00000001, 0x00000002, 0x00000002, 0x00000004, 0x00000004, 0x00000008, 0x00000008, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000000e, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000004, 0x0000001c, 0x00000004, 0x00000004, 0x00000004, 0x00000004, 0x00000004, 0x00000004, 0x00000004, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000000e, 0x00000011, 0x00000001, 0x00000001, 0x00000002, 0x00000004, 0x00000008, 0x00000010, 0x0000001f, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000000e, 0x00000011, 0x00000001, 0x00000001, 0x00000006, 0x00000001, 0x00000001, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000002, 0x00000006, 0x00000006, 0x0000000a, 0x0000000a, 0x00000012, 0x0000001f, 0x00000002, 0x00000002, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000001f, 0x00000010, 0x00000010, 0x0000001e, 0x00000011, 0x00000001, 0x00000001, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000000e, 0x00000011, 0x00000010, 0x00000010, 0x0000001e, 0x00000011, 0x00000011, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000001f, 0x00000001, 0x00000002, 0x00000002, 0x00000004, 0x00000004, 0x00000008, 0x00000008, 0x00000008, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000000e, 0x00000011, 0x00000011, 0x00000011, 0x0000000e, 0x00000011, 0x00000011, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000000e, 0x00000011, 0x00000011, 0x00000011, 0x0000000f, 0x00000001, 0x00000001, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000002, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000002, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000001, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000001, 0x00000002, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000002, 0x00000004, 0x00000008, 0x00000010, 0x00000008, 0x00000004, 0x00000002, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000001f, 0x00000000, 0x0000001f, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000010, 0x00000008, 0x00000004, 0x00000002, 0x00000004, 0x00000008, 0x00000010, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000000e, 0x00000011, 0x00000001, 0x00000001, 0x00000002, 0x00000004, 0x00000004, 0x00000000, 0x00000004, 0x00000000, 0x00000000,
                  0x00000c0b,0x00000000, 0x00000078, 0x00000186, 0x00000102, 0x00000239, 0x00000249, 0x00000249, 0x00000237, 0x00000100, 0x00000180, 0x0000007c, 0x00000000,
                  0x00000c07,0x00000000, 0x00000008, 0x00000008, 0x00000014, 0x00000014, 0x00000022, 0x00000022, 0x0000003e, 0x00000041, 0x00000041, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x0000003c, 0x00000022, 0x00000022, 0x00000022, 0x0000003c, 0x00000022, 0x00000022, 0x00000022, 0x0000003c, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x0000001e, 0x00000021, 0x00000020, 0x00000020, 0x00000020, 0x00000020, 0x00000020, 0x00000021, 0x0000001e, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x00000078, 0x00000044, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000044, 0x00000078, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x0000003e, 0x00000020, 0x00000020, 0x00000020, 0x0000003c, 0x00000020, 0x00000020, 0x00000020, 0x0000003e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x0000001f, 0x00000010, 0x00000010, 0x00000010, 0x0000001e, 0x00000010, 0x00000010, 0x00000010, 0x00000010, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x0000003c, 0x00000042, 0x00000040, 0x00000040, 0x0000004e, 0x00000042, 0x00000042, 0x00000046, 0x0000003a, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x0000007e, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000000, 0x00000000,
                  0x00000c05,0x00000000, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000012, 0x00000012, 0x0000000c, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x00000022, 0x00000024, 0x00000028, 0x00000030, 0x00000030, 0x00000028, 0x00000024, 0x00000022, 0x00000021, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000010, 0x00000010, 0x00000010, 0x00000010, 0x00000010, 0x00000010, 0x00000010, 0x00000010, 0x0000001f, 0x00000000, 0x00000000,
                  0x00000c09,0x00000000, 0x00000082, 0x00000082, 0x000000c6, 0x000000c6, 0x000000aa, 0x000000aa, 0x00000092, 0x00000092, 0x00000082, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x00000042, 0x00000062, 0x00000062, 0x00000052, 0x00000052, 0x0000004a, 0x00000046, 0x00000046, 0x00000042, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x0000003c, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x0000003c, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x0000003e, 0x00000021, 0x00000021, 0x00000021, 0x0000003e, 0x00000020, 0x00000020, 0x00000020, 0x00000020, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x0000003c, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x0000004a, 0x00000046, 0x0000003c, 0x00000002, 0x00000000,
                  0x00000c08,0x00000000, 0x0000007c, 0x00000042, 0x00000042, 0x00000042, 0x0000007c, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x0000001c, 0x00000022, 0x00000020, 0x00000020, 0x0000001c, 0x00000002, 0x00000002, 0x00000022, 0x0000001c, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x0000003e, 0x00000008, 0x00000008, 0x00000008, 0x00000008, 0x00000008, 0x00000008, 0x00000008, 0x00000008, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x00000042, 0x0000003c, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x00000041, 0x00000041, 0x00000022, 0x00000022, 0x00000022, 0x00000014, 0x00000014, 0x00000008, 0x00000008, 0x00000000, 0x00000000,
                  0x00000c0b,0x00000000, 0x00000401, 0x00000401, 0x00000222, 0x00000222, 0x00000222, 0x00000154, 0x00000154, 0x00000088, 0x00000088, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x00000041, 0x00000041, 0x00000022, 0x00000014, 0x00000008, 0x00000014, 0x00000022, 0x00000041, 0x00000041, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x00000041, 0x00000041, 0x00000022, 0x00000014, 0x00000008, 0x00000008, 0x00000008, 0x00000008, 0x00000008, 0x00000000, 0x00000000,
                  0x00000c07,0x00000000, 0x0000007f, 0x00000001, 0x00000002, 0x00000004, 0x00000008, 0x00000010, 0x00000020, 0x00000040, 0x0000007f, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000003, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000003,
                  0x00000c05,0x00000000, 0x00000008, 0x00000008, 0x00000008, 0x00000004, 0x00000004, 0x00000002, 0x00000002, 0x00000001, 0x00000001, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000003, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000003,
                  0x00000c06,0x00000004, 0x0000000a, 0x00000011, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000003f,
                  0x00000c03,0x00000000, 0x00000002, 0x00000001, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000000e, 0x00000001, 0x0000000f, 0x00000011, 0x00000011, 0x0000000f, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000010, 0x00000010, 0x00000010, 0x0000001e, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x0000001e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000000e, 0x00000011, 0x00000010, 0x00000010, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000001, 0x00000001, 0x00000001, 0x0000000f, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x0000000f, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000000e, 0x00000011, 0x0000001f, 0x00000010, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000001, 0x00000002, 0x00000002, 0x00000003, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000000f, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x0000000f, 0x00000001, 0x0000001e,
                  0x00000c06,0x00000000, 0x00000010, 0x00000010, 0x00000010, 0x00000016, 0x00000019, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x00000000, 0x00000000,
                  0x00000c02,0x00000000, 0x00000001, 0x00000000, 0x00000000, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000000, 0x00000000,
                  0x00000c02,0x00000000, 0x00000001, 0x00000000, 0x00000000, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001,
                  0x00000c06,0x00000000, 0x00000010, 0x00000010, 0x00000010, 0x00000012, 0x00000014, 0x00000018, 0x00000014, 0x00000012, 0x00000011, 0x00000000, 0x00000000,
                  0x00000c02,0x00000000, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000076, 0x00000049, 0x00000049, 0x00000049, 0x00000049, 0x00000049, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000016, 0x00000019, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000000e, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x0000000e, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000001e, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x0000001e, 0x00000010, 0x00000010,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000000f, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x0000000f, 0x00000001, 0x00000001,
                  0x00000c03,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000003, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000000, 0x00000000,
                  0x00000c05,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000006, 0x00000009, 0x00000004, 0x00000002, 0x00000009, 0x00000006, 0x00000000, 0x00000000,
                  0x00000c03,0x00000000, 0x00000000, 0x00000002, 0x00000002, 0x00000003, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000001, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000011, 0x00000011, 0x00000011, 0x00000011, 0x00000013, 0x0000000d, 0x00000000, 0x00000000,
                  0x00000c06,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000011, 0x00000011, 0x0000000a, 0x0000000a, 0x00000004, 0x00000004, 0x00000000, 0x00000000,
                  0x00000c08,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000049, 0x00000049, 0x00000055, 0x00000055, 0x00000022, 0x00000022, 0x00000000, 0x00000000,
                  0x00000c05,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000009, 0x00000009, 0x00000006, 0x00000006, 0x00000009, 0x00000009, 0x00000000, 0x00000000,
                  0x00000c05,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000009, 0x00000009, 0x00000009, 0x00000009, 0x00000006, 0x00000004, 0x00000004, 0x00000018,
                  0x00000c05,0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000000f, 0x00000001, 0x00000002, 0x00000004, 0x00000008, 0x0000000f, 0x00000000, 0x00000000,
                  0x00000c04,0x00000001, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000004, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000001, 0x00000000,
                  0x00000c02,0x00000000, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000001, 0x00000000,
                  0x00000c04,0x00000004, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000001, 0x00000002, 0x00000002, 0x00000002, 0x00000002, 0x00000004, 0x00000000,
                  0x00000c07,0x00000000, 0x00000000, 0x00000019, 0x00000026, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
           int i;
           for (i=0;i<40;i++)
    	int i;
    	for(i=0;i<512;i++)
      	ungetc(c,stream);
      	return status;
    	int i;
    	FILE *FP1;
    	i = 0;
    		exit(1);
      	fseek(FP1,0,0);
    	for(i=0;i<24;i++)
    	i = 0;
    		i+=1;
    	if(FP1)
         		FP1=NULL;
    	int i;
    	int i;
    	FILE *FP1;
    	i = 0;
      	fseek(FP1,0,0);
         	FP1=NULL;
    	int i;
    	screen[4] = 1;
    	for(i=0;i<32;i++)
    			screen[4] += 1;
    	int x;
    	int c;
    	x = 0;
    	for (c=0;c<64;c++)
    		x++;
    	int col;
    	int row;
    	int col;
    	int i;
    	for(i=0;i<4800;i++)
    	unsigned long i;
    int gray_printf(unsigned long screen[],int startx, int starty, char lineoftext[])
    	int height = sans_serif_font[0] >> 8;			// read from the font data the height
    	int width,ascii,a,x,y,i,curx;
    	unsigned long font;
    	curx=startx;							// cursor
    	for(i=0;i<strlen(lineoftext);i++)				// get each letter in the string
    		ascii=lineoftext[i];
    		a=ascii * 13;						// calculate the address of the character
    		width = sans_serif_font[a] & 0x000000FF;		// mask out the height
    		for(y=0;y<height;y++)				// one row at a time
    			font=sans_serif_font[a+y+1];		// get the font long
    			for(x=0;x<width;x++)				// do each pixel
    				if((font & 0x00000001) == 1)	// test if a 1
    					gray_pixel(screen,curx+(width-1-x),starty+y,0x00);
    				font = font >> 1;			// shift in the next bit
    		curx += width;					// move cursor along by width amount
    	return curx-startx;						// return the width of all the text
    void gray_horizontal_line(unsigned long screen[], int startx, int starty, int sizex, char color)
    	int col;
    	for(col=startx;col <= startx+sizex ;col++)
    void gray_vertical_line(unsigned long screen[], int startx, int starty, int sizey, char color)
    	int row;
    	for(row=starty;row <= starty+sizey;row++)
    		gray_pixel(screen,startx,row,color);			// vertical line
    void gray_box_fill(unsigned long screen[], int startx, int starty, int sizex, int sizey, char color)
    	int row,col;
    	for(row =starty;row <= starty+sizey; row++)
    		for(col=startx;col <= startx+sizex; col++)
    			gray_pixel(screen,col,row,color);			// fill in pixels
    void gray_groupbox(unsigned long screen[], int startx, int starty, int sizex, int sizey, char lineoftext[])
    	int textwidth;
    	gray_horizontal_line(screen,startx,starty,10,0x1);						// dark gray horizontal line
    	gray_horizontal_line(screen,startx+1,starty+1,9,0x3);						// white horizontal line
    	gray_vertical_line(screen,startx,starty,sizey,0x1);						// dark gray vertical
    	gray_vertical_line(screen,startx+1,starty+1,sizey-1,0x3);					// white vertical
    	gray_horizontal_line(screen,startx,starty+sizey,sizex,0x1);					// dark gray horizontal line
    	gray_horizontal_line(screen,startx,starty+sizey+1,sizex+1,0x3);				// white horizontal line
    	gray_vertical_line(screen,startx+sizex,starty,sizey,0x1);					// dark gray vertical
    	gray_vertical_line(screen,startx+sizex+1,starty,sizey,0x3);					// white vertical
    	textwidth = gray_printf(screen, startx+14,starty-4,lineoftext);				// print the frame title
    	gray_horizontal_line(screen,startx+18+textwidth,starty,sizex-textwidth-18,0x1);		// dark gray horizontal line
    	gray_horizontal_line(screen,startx+18+textwidth,starty+1,sizex-textwidth-19,0x3);		// white horizontal line
    void gray_button(unsigned long screen[],int startx, int starty, int sizex, int sizey, char lineoftext[])
    	gray_vertical_line(screen, startx, starty, sizey, 0x3);					// white vertical line
    	gray_horizontal_line(screen, startx, starty, sizex, 0x3);					// white horizontal line
    	gray_vertical_line(screen, startx+sizex, starty+1, sizey-1, 0x1); 				// vertical dark gray line
    	gray_horizontal_line(screen, startx+1, starty+sizey, sizex, 0x1); 				// horizontal dark gray line
    	gray_vertical_line(screen, startx+sizex+1, starty, sizey+1, 0x0); 				// vertical black line
    	gray_horizontal_line(screen, startx, starty+sizey+1, sizex+1, 0x0); 				// horizontal black line
    	gray_printf(screen,startx+4,starty+4,lineoftext);						// print the button text
    void gray_text(unsigned long screen[], int startx, int starty, int sizex, int sizey, char lineoftext[])
    	gray_box_fill(screen, startx+1, starty+1, sizex-2, sizey-2,0x3);				// white centre
    	gray_vertical_line(screen, startx, starty, sizey-1, 0x0);					// black vertical line
    	gray_horizontal_line(screen, startx, starty, sizex-1,  0x0);					// black horizontal line
    	gray_vertical_line(screen, startx+sizex, starty+1, sizey,0x2); 				// vertical light gray line
    	gray_horizontal_line(screen, startx, starty+sizey, sizex, 0x2); 				// horizontal light gray line
    	gray_vertical_line(screen, startx-1, starty-1, sizey+1, 0x1);					// dark gray vertical line
    	gray_horizontal_line(screen, startx-1, starty-1, sizex+1, 0x1);					// dark gray horizontal line
    	gray_vertical_line(screen, startx+sizex+1, starty-1, sizey+2, 0x3);				// vertical whiteline
    	gray_horizontal_line(screen, startx-1, starty+sizey+1, sizex+1, 0x3);				// horizontal whiteline
    	gray_printf(screen,startx+2,starty+2,lineoftext);						// print the text
    void gray_radio(unsigned long screen[], int startx, int starty, char check,char lineoftext[])
    	int x;
    	int y;
    	int i = 0;
    	if(check !=0)
    	for(y=0;y<12;y++)
    		for(x=0;x<12;x++)
    			i++;
    	gray_printf(screen,startx+16,starty,lineoftext);			// print the text
    	int i;
    	int i;
    	screen[5] = 1;
    	for(i=0;i<32;i++)
    			screen[5] += 1;
    void main ()
    858 x 747 - 90K
  • jazzedjazzed Posts: 11,803
    edited 2011-04-13 07:36
    Dr_Acula wrote: »
    The PropGUI is starting to take shape ....
    Nice GUI picture. Why are all your functions called gray_* ?
    Eventually someone may like other colors which provide more shades than gray.
    edited 2011-04-13 16:13
    Good question. The gray graphics driver is 320x240 with 4 colors which is the maximum color depth (I think?) for 19200 bytes of hub ram. There are some other functions in there that start with "pix" - these are from Kye's 64 color driver which is 160x120 and "pix" is what Kye used in Spin.
    The demo program starts off with white on blue text 80x40, then changes to the 160x120 color and draws some boxes and a color bar, then switches to gray 320x240.
    I'd love to get some more colors!
    But I don't think the prop can do this... unless you can pull data in from external memory fast enough?
    At the moment what I am thinking is you have the color version for games, and things like the movie demo and icons, and then you have the higher resolution gray version for "work", eg a text editor, or a little calculator program.
    I did originally code the first few buttons in the color 160x120 version but it looks very chunky on a VGA screen. However, it might look a lot better on a smaller LCD TV screen, and hopefully this might be possible to port over to TV as well.
    Lots of scope for improvement here!
    BTW, could this run on your nifty 32meg board? I think Ross has catalina working now. I have a feeling this might end up a largish program - it is 128k already and might end up going over 512k so the extra memory could come in very handy.
    edited 2011-04-13 17:00
    Maybe some day you can use the full color driver for the GUI. One thing at a time :)
    Regarding SDRAM video: Ding-Batty has made some driver improvements that would let us read display lines straight from SDRAM. A similar approach could be used for 8xSPI SRAM. Guess I'll have to work on that soon.
    It's truly hard to beat any kind of synchronous RAM for buffer operations - one could use a video mode for driving 8 address bits on asynchronous SRAM, but the video mode startup time is quite slow. Synchronous -vs- asynchronous memory buffer speed would be like C3 cached -vs- uncached.
    edited 2011-04-13 18:39
    Okay, I finally had time to try compiling xbasic with Catalina 3.0 and it mostly works but I'm having some trouble with file I/O. I built xbasic with the same compiler switches you used in your C3 tutorial but Catalina either crashes (resets) or hangs when I try to load a file. I've attached my source code and makefile so you can see if I've done anything wrong in building the executable. I'm assuming that there isn't a special "build_all" argument needed to enable filesystem support, right?
    edited 2011-04-13 19:28
    Hi David,
    I'll check this out when I get home tonight.
    Ross.
  • Ding-BattyDing-Batty Posts: 305
    edited 2011-04-13 21:21
    jazzed wrote: »
    My ears were burning...
    I need update my timing estimates, but I don't think the caching SDRAM driver code would be a very good fit for reading video information -- there is a lot of unneeded overhead, and reading (and writing) video could better use a raw block I/O interface, especially with I/O request queueing. It seems to me that the most important thing to know is the maximum latency for the reads: what is the longest time the code has to wait for the data to be available after the data is requested...
    My timing rule-of-thumb for the SDRAM code: the inner loop for a block read uses 12 clocks per byte read, so the max. read speed will be less than 80/12 == 6.67MB/s at 80MHz, and 100/12 == 8.33 MB/s at 100 MHz. The caching SDRAM driver has somewhere in the 500 to 550 clocks of overhead for a block read (including a nearby refresh burst), which is about 40 to 45 bytes worth of overhead per block. So, reading 32-byte blocks will give (32/(40+32))*6.67 = 6.67*4/9 or about 3MB/s with an 80MHz clock. Reading 256-byte blocks will give 6.67 * (256/(256+40)) == 5.77 MB/s with an 80MHz clock. Of course, there will be some additional overhead setting up the requests and retrieving the data, but I believe a "raw" block driver will have speeds slightly better than that, due to elimination of the cache hit/miss calculation overhead.
    For latency in the caching SDRAM code, a refresh burst has 50 clocks of overhead, plus 8 clocks for each refresh it issues in the burst, which for a 256 byte block at 80MHz is about 7 refresh commands, totaling about 106 clocks. The clocks to read a 256-byte block are about 500 + 12*256 clocks. So in general, the maximum time from sending a read request for a 256 byte block until the data is available should be about 3678 system clocks, which is about 46 us.
    edited 2011-04-13 22:15
    Ding-Batty wrote: »
    I need update my timing estimates, but I don't think the caching SDRAM driver code would be a very good fit for reading video information ....
    I think your analysis is a little pessimistic. There is some look-ahead fetching that can be done while a current graphics line is being drawn. The cache granularity has to be a video line length. Refresh only happens periodically. I've actually been able to read and display data on TV from SDRAM cache before using the old driver which runs at about 4.7MB/s. I'll have to visit it again soon - I'm a little busy now though.
    edited 2011-04-13 22:41
    But what happens when you want to refresh your video from the external RAM and execute XMM code from it at the same time as it looks like Dr_A would like to do?
    edited 2011-04-13 23:10
    Heater. wrote: »
    It would be easy enough to suspend the kernel execution whenever the video display code needs access to the external RAM. Both the XMM kernel and the video driver could use a lock to synchronize access to the common resource (i.e. the XMM RAM).
    Of course, the end result would be that the kernel might only get a couple of instructions executed between each video refresh, so your C program would run really slowly!
    Ross.
    edited 2011-04-13 23:21
    That's what I thought.
    edited 2011-04-13 23:50
    Yes, good point.
    I just coded a mouse pointer. At the moment it is only working when aligned with the longs of the screen so it is a bit jumpy in the x direction. I'll need some extra code for when the pointer bridges two longs. For speed it is going to need to work directly with the longs in the screen buffer rather than painting pixels individually.
    void gray_mousepointer(unsigned long screen[],int x, int y) 			// 21 high, 13 wide = 1 long wide
    	unsigned long mask[21] = {							// mask 00=pixel, 11=transparant
    	0xfffffff0,0xffffffc0,0xffffff00,0xfffffc00,0xfffff000,0xffffc000,	// order is reversed in each long
    	0xffff0000,0xfffc0000,0xfff00000,0xffc00000,0xff000000,0xfc000000,
    	0xfffc0000,0xfffc0000,0xfff00300,0xfff003c0,0xffc00ff0,0xffc00fff,
    	0xff003fff,0xff003fff,0xffc0ffff
    	unsigned long icon[21] = {							// icon, 00, 01, 10 or 11=pixel, 00 = transparent if transparent above
    	0x00000004,0x00000010,0x0000004c,0x0000013c,0x000004fc,0x000013fc,
    	0x00004ffc,0x00013ffc,0x0004fffc,0x0013fffc,0x004ffffc,0x01003ffc,
    	0x00013cfc,0x00013c3c,0x0004f04c,0x0004f010,0x0013c004,0x0013c000,
    	0x004f0000,0x004f0000,0x00100000
    	// need to add in bitshifts to get the x exactly correct
    	int i,j,n,m;
    	n=0;
    	m=(y*20)+(x/20);									// get the screen long - 20 longs per row
    	for (i=0;i<21;i++)									// rows
    			screen[m] = screen[m] & mask[n];					// mask out pixel bits, ignore transparent bits
    			screen[m] = screen[m] | icon[n];					// draw the icon
    			n++;
    		m = m+20;									// next row
    Good to read that it might be possible to suspend Catalina. I've been pondering how to access the LCD display on the dracblade as it needs to take over the first 12 pins of the propeller. I have had an idea that maybe you set a cog going with the data to output, send an instruction to catalina "suspend", the cog detects that the catalina lock has changed so goes off and runs its code, then when finished, changes the catalina lock again?
    Would this work? Or would it be easier to custom code the LCD as part of the memory driver?
    924 x 795 - 97K
    edited 2011-04-14 00:05
    Dr_Acula wrote: »
    I'm not sure. Do you need to constantly refresh your LCD? If not, you don't need to do anything special for this one - just make the LCD driver a plugin. The Catalina kernel is always suspended during a service call to a plugin, so provided you set the pins back the way Catalina expects them to be before returning from the service call, you can do whatever you like and Catalina will not be disturbed.
    Ross.
    edited 2011-04-14 01:11
    Ah, that sounds like the way to do things. No, it does not need to be refreshed, so this looks like an answer. The code is contained within a cog and when the cog finishes it can set a flag or something. I'll need to study plugins a bit more though. Thanks Ross
    edited 2011-04-14 05:00
    RossH wrote: »
    Hi David,
    Ross.
    Hi Ross,
    Did you ever have a chance to look at this file I/O problem?
    David
    edited 2011-04-14 06:07
    David Betz wrote: »
    David,
    Yes, there is definitely something odd. It is a memory initialization problem - but I'm not sure if it is your problem or mine. However, it is very reproducible, so it shouldn't be too hard to track down.
    Here are the commands I used (after unzipping xbasic into the main Catalina directory) to reproduce it:
    cd C:\Program Files\Catalina
    use_catalina
    cd utilities
    build_all C3 CACHED_4K FLASH SD
    payload -e flash_boot
    cd ..\xbasic
    make -f Makefile.cat clean
    payload XMM bin\xbasic.binary -t 1000
    Note that I compile and load the flash_boot utility just so that I don't have to keep reloading xbasic each time after the initial load - I just have to reset the Prop to restart it (This is the reason I add the SD parameter to the build_all script - so that flash_boot will load the SD card driver. If you don't use flash_boot then you don't need that parameter)
    When the xbasic prompt appears on the TV display, I try and load a file. It fails, and spits out some rubbish about "expecting a line number" in an infinite loop.
    I reset the Prop and try again. It fails again, and spits out different output (this time it's just rubbish).
    I reset the Prop and try again. This time I get no error messages or rubbish, but when I list the file I just loaded it is empty.
    I reset the Prop and try again. This time it succeeds. I can list the file I just loaded. I can run it.
    From now on, everything appears to work correctly. It will continue to run correctly now on every reboot.
    But I can make it fail again just by loading and running the ram test program, then reloading the xbasic binary. I then have to go through another three reboots to get it working again.
    Obviously the problem is that some memory is being used without being initialized first. Perhaps some memory that your program is expecting to be initialized to zero is not being initialzed by Catalina.
    Can you check your program to see if it is dependent on some specific memory initialization? Perhaps you are relying on some initialization that other compilers do but Catalina does not (of course, this might be Catalina's fault - there are some things in C that are always supposed to be initialized, but perhaps I am not doing this correctly in all cases).
    Ross.
    edited 2011-04-14 06:39
    Thanks for the analysis. It could very well be that I have some sort of memory issue. This code runs fine under Linux or Mac OS X but, as you say, they may do something different in terms of memory initialization. I spent a fair amount of time trying to reduce the RAM usage of xbasic and I may have over-optimized in some critical place. I'll look over my code before I bother you again! :-)
    edited 2011-04-14 07:10
    Hi Ross,
    I hope you don't mind multitasking with two threads running in parallel here?
    Anyway
    I have read through the Catalina reference manual, plugin section, and also the Getting Started with Plugins.
    Some of this is quite logical. Some is a bit too complex for me (eg page 7 of the plugin manual, I don't know what all those arrows actually mean) but I am getting some idea how plugins work.
    As you know, I have kind of bypassed the entire plugin/registry system with cogjects. I define an array in C, pass that array location to the cog code and then interact with that cog via the array. I guess for me this is more flexible in that for one cog, I might want to interact with one byte, but the next one might need to interact with 20 kilobytes. I know that plugins can pass the location via registry of another array, but that is a double step. I also have found it easier to interact with cogs using one array and one array only, because that is how many Obex spin objects have been written. Also, some obex code almost fills up the pasm part and there is no room left for the generic plugin code, so we are sometimes stuck with arrays that start at "par".
    Anyway, in all the reading of the plugin manuals, I am still a bit unclear about when Catalina shuts down and when Catalina keeps running. There is mention of a service request, and the spin code contains this
        ' wait for the service request to complete
        common.WaitForRequest(cog)
    but I'm not sure where this spin code is used - whether it is internal to catalina or whether that is a demo plugin?
    I still haven't quite found all the bits needed to load and run a plugin. I think the bit I am missing is the example code in C. Particularly the C code that i) sets a cog running and keeps C running and ii) the code that sets a cog running and pauses C until the cog returns something.
    (Cogjects always keep running C, but do plugin requests *always* stop C, or only sometimes?)
    So - let's say I create an array and run an LCD cogject. I'll do this the way I understand it, but maybe there is a plugin way that works in a similar fashion.
    The first item I pass to my LCD cogject is the address of the registry. There is a C function to obtain this.
    Then I load up my array with some data (I'll pass a group of bytes)
    Then I set a flag to say there is some fresh data
    Then I (re)start the cog. (I know which cog this is running in.)
    The cog code collects the registry pointer, and determines that catalina is still running so the cog holds for the moment.
    Now I issue a C command to catalina to tell it to suspend. What is this command? Is it a "service call"? And which registry value does it alter?
    Then the cog detects that catalina has stopped. It processes the data.
    It then sends a message back to catalina to tell catalina to restart. This is presumably some sort of flag in the registry? If it is a flag, what is its location offset from the start of the registry?
    I think some of this is explained in Catalina_Plugin.spin in this block of code
                  cogid     t1                      ' get ...
                  shl       t1,#2                   ' ... our ...
                  add       t1,par                  ' ... registry block
                  rdlong    rqstptr,t1              ' register ...
                  and       rqstptr,low_24          ' ... this ...
                  wrlong    zero,rqstptr            ' ... plugin ...
                  mov       t2,#PTYPE               ' ... as ...
                  shl       t2,#24                  ' ... the ...
                  or        t2,rqstptr              ' ... appropriate ...
                  wrlong    t2,t1                   ' ... type
    Have you by any chance got a C program that demonstrates loading and interacting with Catalina_Plugin?
    edited 2011-04-14 07:57
    Dr_Acula wrote: »
    Actually, I like this method of doing things as well. This is basically the approach I took with ZOG. When a ZOG program is started, the only COGs that are running are the COG running the ZOG VM and the COG running the external memory cache interface. Any other COGs that are needed by the application are loaded by C code. It seems like this makes for a much easier to configure system. You don't have to mess around with Spin code to get the right plug-ins loaded and you have full freedom to use any of the remaining COGs in any way you want. What exactly happens when a Catalina code starts? What does the crt0 startup code do and what does it expect for its environment? Is it possible to bypass all of the HMI stuff and just leave it to the C code to initialize its own drivers? In my ZOG runtime I took the approach that the C runtime code called through a set of function pointers to do low-level things like terminal I/O and file open/close. Those functions by default were stubbed out so that they just returned error codes. Then, the user's C initialization code could setup either keyboard/TV/VGA terminal I/O or serial terminal I/O as needed. Similarly, the file I/O support was loaded by the user's initialization code rather than being controlled by which library was linked. The linker takes care that code isn't linked in that isn't referenced so the file I/O support is just left out of the executable if it is not used.
    Is there something similar that can be done with Catalina? Can we have alternate C startup code that simply sets up the stack and calls the user's main() letting it do everything else? Actually, ZOG is a bit more sophisticated than that. The C startup code first calls _initIO() and then calls main(). This has the advantage that _initIO() can be used to do any Propeller-specific setup before main() is called allowing the main() code to be generic and not tied to the Propeller. I think adopting this sort of model in Catalina along with the cogjects approach to loading drivers would be useful at least as an alternative to the current approach.
    edited 2011-04-14 16:26
    Dr_Acula wrote: »
    Hi Ross,
    Nope - people are always telling me I have a cog or two to spare! :smile:
    Dr_Acula wrote: »
    The arrows are pointers, showing that the lower 24 bits of each registry entry is set up to point to your allocated "request" block. Each pre-allocated request block is two longs, and is used by the registry functions as a request long and a response long. However, you are free to allocate another (larger) comms block if you need to, and update the registry with its address - Catalina doesn't care. However, I have never found a need to do. Mostly, I just use the registry to pass another data block when I have a need to do so, because its much easier.
    Dr_Acula wrote: »
    That's fine - but you will be unable to use all the built-in kernel support for your cogjects,which is really just making life difficult for yourself, and is why you are now going to have to reproduce much of that functionality yourself.
    Dr_Acula wrote: »
    When I need to do this in Catalina, I use the request block to pass the address of another data block. This is a "long request" as opposed to a "short request" where all data is entirely contained in the request block itself.
    Dr_Acula wrote: »
    If that bothers you, just do it once on startup - some plugins have an "initialization" service that is used to pass them the address of another data block on startup, and thereafter they do not use the registry - so there is not really a "double step" at run time
    Dr_Acula wrote: »
    True - but such cases are rare. Usually the PASM code does some initialization itself (since pasm programs rarely stand alone) which can be replaced by the Catalina "plugin" style inialization at little or no cost. You may also notice that some plugins are registered by the SPIN startup code, not in the PASM code - this reduces the overhead required to turn a PASM program into a plugin into just a few instructions.
    Dr_Acula wrote: »
    That SPIN code is only used during initialization. For all plugins that accept service requests (and not all do) then the Catalina kernel is suspended from the time it sets up the request (in the request long) until the time the plugin sets that long back to zero. Then catalina reads the result (from the result long) and resumes executon of the kernel.
    This means that plugins can be written to simply accept a reqest and release the kernel immediately (i.e. before processing the request), or to suspend the kernel until the entire request is completed. Which mechanism you use depends on what the request has to do. If (for example) you need to access external RAM, then you have to leave the kernel suspended until you have finished. On the other hand, if you are sending a byte to a serial port, you can let the kernel resume as soon as you have the byte to send, and then go off and send it while the kernel carries on with something else.
    Dr_Acula wrote: »
    There is no specific example because there are examples all through Catalina - for example, the TV or LoRes VGA HMI plugins (but not the HiRes VGA one) accept service requests, and while there is no request outstanding, they spends their time flashing the cursor. The graphics plugin accepts a request, then releases the kernel immediately before it goes off and executes the request. The SD plugin always leaves the kernel suspended for the entire time it takes to perform the SD operation (on many platforms it has to use the same pins as are used for other purposes).
    Dr_Acula wrote: »
    Plugin requests always stop the kernel that made them (and only that kernel, if there are multiple kernels running) until the plugin says it can proceed - which (as I described above) may be immediately, or it may be sometime later.
    Dr_Acula wrote: »
    There are plugins that work in every possible fashion - for your purposes, maybe the graphics plugin might be a good model to use.
    Dr_Acula wrote: »
    That is an incredibly complex way to do things. It should all be much, much easier than this. Why not just write an LCD plugin that runs constantly, monitoring its request block for new service requests. When it gets one it performs the requested function, writing a zero back into the request long when it is ready to let the kernel proceed.
    Dr_Acula wrote: »
                  cogid     t1                      ' get ...
    The code you quote simply registers the plugin - this can be done either in PASM or SPIN. As to examples of prorgams interacting with plugins, nearly all Catalina programs do this. The simplest ones are the ones that use the low-level HMI functions - each of these functions is just a trivial wrapper around a plugin request. For example, here is the entire C code for the t_char function:
    int t_char (unsigned curs, unsigned ch) {
        return _short_plugin_request(HMI, 22, ((curs&1)<<23) + ch);
    As you can see, all this code does is call short_plugin_request. Here is that function in full:
    int _short_plugin_request (long plugin_type, long code, long param) {
        return _sys_plugin (plugin_type, (code<<24) + (param & 0x00FFFFFF));
    This code actually executes the _sys_plugin service request that stops the kernel until the plugin says it can proceed again. I don't think you can come up with a mechanism that is much simpler than this - and it is flexible enough to do anything you might need to do. If a short request is not enough (short requests can only include 24 bits of data) then use a long request (long requests can include 32 bits of data). If that's not enough, make the parameter to the long request the address of another data block (which can be any size you like).
    Ross.
  • RossHRossH Posts: 5,642
    edited 2011-04-14 16:29
    David Betz wrote: »
    David,
    Don't assume your code is at fault. It could well be a Catalina issue. When I get time I'l check out all the cases where a C compiler is supposed to guarantee memory is initialized to zero. But if you do find clue, please let me know!
    Ross.
    edited 2011-04-14 16:40
    David Betz wrote: »
    With Catalina you are free to do whatever you want. You can create your own target directory that doesn't load any plugins at all if you want to - for example the custom target directory is a fairly minimalist one. It loads only one plugin (intended as an example). You could use something like that to start your C program, and load everything else you need to do from within C if you want to (e.g. using Dr_A's cogjects).
    However, Catalina is primarily designed to provide users with a complete ANSI C compliant environment. This means all the things mandated by the ANSI C standard (e.g. stdin/stdout/stderr support - which in Catalina means HMI drivers, file system support - which in Catalina means an SD card driver, real-time clock support, floating point support etc) are all there on any platform capable of suporting them - all without you having to write a single line of code.
    People like us might like messing about with LCD drivers and file systems - but Catalina is also intended for people who just want to write programs!
    Ross.
    edited 2011-04-14 16:41
    Hi Ross,
    Thanks for all that. I think I am getting closer to a solution.
    I'd like to think about an absolute minimalist plugin. All it does is tells Catalina that it can keep running. To do this I understand it needs to write a zero somewhere. If the plugin knows the location of the registry, and it is running in cog 7, what is the location of the long in which to write that zero?
    I am guessing here, but is it one of registry+7, or registry-7, or registry+14, or registry-14, or registry+15, or registry-15, or some other location?
