1 bit graphics.spin
I'm playing with Rays LCDs, and as usual the buffer size is eating so much memory.
There is a 1 bit working driver, and I would like to couple it to the graphics object.
Is there a 1 bit version of graphis?
I looked around in the forum but with no luck.
Massimo
Massimo
I seem to recall that Ariba did a bunch of drivers for the 4.3" including a mono graphics object.
The same thing could be done for the 3.5" display, but I don't recall right now if it has been done or not...
Massimo
I guess what you want doesn't exist yet...
Massimo
Also, I did recently adapt graphics.spin for my low-cost monchrome graphical LCDs, but I don't think I did anything special because memory wasn't a problem...
Thanks for the hint.
Massimo
Then, set your xtiles to be half the regular value...
would your external memory (Flash Point RamPage) or only the ram portion work as a buffer for video output?
After all one 23K256 SRAM chip should be enough for double buffering. Would it be fast enough?
Massimo
I think it will be relatively easy with the 3.5" and 4.3" LCDs and perhaps doable on TV too...
Moreover there would be space for array and variable storage.
Even a RAM only add on board would help a lot....
Massimo
