PROP to MIC4467 to Mosfet
Hello,
Has anyone used the MIC4467 with the Prop to drive Mosfets ? Looking through the datasheet is has the ability to drive N and P mosfets and It has 4 channels I have the need to drive three N and one P mosfets that will drive some solenoids due to the way the unit is wired.
Thanks Dan B
Thanks Dan B
I think you'll be happy with their performance in your app.
-- http://ww1.microchip.com/downloads/en/devicedoc/21422d.pdf
Thanks for the tip what gate supply voltage do you use?
I have some IR2110 drivers here but they only have two outputs but they interface nicely with 3.3 volt logic but I was really looking for more outputs in a single chip.
Very cool project!
The project I am working on right now is for an automobile and I have up to 14.5vdc to work with on my gate drives.Thanks for the info again.
Dan B
