I'm getting snubbed by my I2C device — Parallax Forums
CannibalRoboticsCannibalRobotics Posts: 535
edited 2011-04-05 21:00 in Propeller 1
I'm trying to communicate with a TI BQ32000 clock/cal chip.
For whatever reason, I'm getting no ack back.
The code is borrowed and slightly modified from Agyeman's EEPROM driver. My confusion is why there is no ack coming back in the 9th clock pulse.
The two scope captures attached show the first two then the first 6 bytes in the burst. Data is on top in blue, clock is below on bottom.
Any ideas - am I missing something really easy here?
Thanks in advance....
Jim-
RTClockData is called about every 5 seconds to load a buffer.
PRI RTClockData | i
  startDataTransfer
  transmitPacket(%1101_0000)    ' Slave Address, write
  transmitPacket(%0000_0000)    ' Sub-Address of starting register
  startDataTransfer             ' do start again per spec
  transmitPacket(%1101_0001)    ' Slave Address again read mode
  Repeat i from 0 to 7    ' Start reading the registers
    RT_Bytes[i] := receivePacket(7-i)    ' get the 8 bytes from the clock
  stopDataTransfer
PRI transmitPacket(value) ' 4 Stack Longs
  value := ((!value) >< 8)
  dira[RTClk]  := 0
  dira[RTDat]  := 0
  repeat 8
    dira[RTDat] := value
    dira[RTClk] := false
    dira[RTClk] := true
    value >>= 1
  dira[RTDat] := false
  result := not(ina[RTDat])
  dira[RTClk] := true
  dira[RTDat] := true
PRI receivePacket(aknowledge) ' 4 Stack Longs
  repeat 8
    result <<= 1
    result |= ina[RTDat]
    dira[RTClk] := true
  dira[RTDat] := (not(not(aknowledge)))
  dira[RTClk] := true
  dira[RTDat] := true
PRI startDataTransfer ' 3 Stack Longs
  outa[RTDat] := false
  outa[RTClk] := false
  dira[RTDat] := true
  dira[RTClk] := true
PRI stopDataTransfer ' 3 Stack Longs
    edited 2011-04-05 15:11
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2011-04-05 15:16
    Thanks Phil, I looked around for that as a feature on the new format but couldn't find it.
    I knew someone would pick it up quick.
    J-
  • pjvpjv Posts: 1,903
    edited 2011-04-05 15:32
    Hello J;
    Peeking at your first picture, it looks as if you are not sending a START bit...... or is this picture mid-stream after the start has already been sent ?
    Cheers,
    Peter (pjv)
    edited 2011-04-05 15:43
    pjv wrote: »
    Hello J;
    According to I2c specs, the Start condition is the falling edge of SLC while holding SDA low. That condition occurs below the trigger marker (down pointing white arrow) on the far left of the screen. I am not aware of a 'start bit' or maybe I'm missunderstanding.
    This is the very first communication from the prop about 10 seconds after everyone got powered up.
    J-
  • RaymanRayman Posts: 16,276
    edited 2011-04-05 15:49
    Don't know if it will help, but I have noticed that some devices require the i2c bus to be "initialized"...
    I think there's a driver by Mike Green in OBEX that has an example of this function...
    As I recall, it's just sending a lot of zeros...
    edited 2011-04-05 15:58
    I looked around for that but this is the total of information given in the TI spec for initiating communications...
    This device only operates only as a slave device.
    I2C communication is initiated by a master sending a start condition, a high-to-low transition on the SDA I/O while
    SCL is held high. After the start condition, the device address byte is sent, most-significant bit (MSB) first,
    including the data direction bit (R/W). After receiving a valid address byte, this device responds with an
    acknowledge, a low on the SDA I/O during the high of the acknowledge-related clock pulse. This device
    responds to the I2C slave address 11010000b for write commands and slave address 11010001b for read
    commands.
    This device does not respond to the general call address.
  • JonnyMacJonnyMac Posts: 9,801
    edited 2011-04-05 16:06
    This may be the source of the problem, especially since it's one of those "everything but the kitchen sink" efforts (the I2C driver, that is). When learning new parts I always start with simplistic drivers first, just to make sure all the connections are good. If you can get things working with a simple driver, you can certainly get things going with a more sophisticated driver later.
    In racing school they used to tell us, "slow in, fast out" when referring to corners. I find the same rule applies to product development.
    I don't have that chip but I wrote and attached a really simple demo that I would start with if I did. Note that my driver follows the I2C rules and requires a pull-up on the clock pin.
    edited 2011-04-05 16:35
    Well, it worked! I modified your code with my port number's and it worked.
    Thanks Jon!
    Here is the final result with the code below.
    PRI RTClockData | i
      RTInit
      RTstart
      RTwrite(%1101_0000)    ' Slave Address, write
      RTwrite(%0000_0000)    ' Sub-Address of starting register
      RTstart             ' do start again
      RTwrite(%1101_0001)    ' Slave Address again read mode
        RT_Bytes[i] := RTread(0)
      RTstop
    PRI RTinit | okay
    '' Define I2C SCL (clock) and SDA (data) pins
      dira[RTDat] := 0                                                ' float buss pins
      dira[RTClk] := 0
    PRI RTwait(id) | ackbit,ACK
      ACK := 0
    '' Waits for I2C device to be ready for new command
      repeat
        RTstart
        ackbit := RTwrite(id & $FE)
      until ackbit == ACK
    PRI RTstart
    '' Create I2C start sequence
    '' -- will wait if I2C buss SDA pin is held low
      dira[RTDat] := 0                                                ' float SDA (1)
      dira[RTClk] := 0                                                ' float SCL (1)
      repeat while (ina[RTClk] == 0)                                  ' allow "clock stretching"
      outa[RTDat] := 0
      dira[RTDat] := 1                                                ' SDA low (0)
    PRI RTwrite(i2cbyte) | ackbit
    '' Write byte to I2C buss
      outa[RTClk] := 0
      dira[RTClk] := 1                                                ' SCL low
      i2cbyte <<= constant(32-8)                                    ' move msb (bit7) to bit31
      repeat 8                                                      ' output eight bits
        dira[RTDat] := ((i2cbyte <-= 1) ^ 1)                          ' send msb first
        dira[RTClk] := 0                                              ' SCL &#61570;  (float to p/u)
        dira[RTClk] := 1                                              ' SCL  &#61573;
      dira[RTDat] := 0                                                ' relase SDA to read ack bit
      ackbit := ina[RTDat]                                            ' read ack bit
      return (ackbit & 1)
    PRI RTread(ackbit) | i2cbyte
    '' Read byte from I2C buss
      outa[RTClk] := 0                                                ' prep to write low
      dira[RTDat] := 0                                                ' make input for read
      repeat 8
        i2cbyte := (i2cbyte << 1) | ina[RTDat]                        ' read the bit
      dira[RTDat] := !ackbit                                          ' output ack bit
      return (i2cbyte & $FF)
    PRI RTstop
    '' Create I2C stop sequence
      outa[RTDat] := 0
      repeat while (ina[RTClk] == 0)                                  ' hold for clock stretch
    640 x 480 - 140K
    edited 2011-04-05 17:37
    Glad you got things working. If you have more than one I2C device in your project those methods should be in their own object.
    If you look at the data sheet you'll see that the last byte in a multi-byte read gets a NAK, not ACK as you're doing. Here's the fix:
    PRI RTClockData | i
      RTInit
      RTstart
      repeat i from 0 to 6
        RT_Bytes[i] := RTread(0)                            ' ACK
    [B]  RT_Bytes[7] := RTread(1)                              ' NAK[/B]
      RTstop
    Hello J;
    Now your scope shot shows a proper START bit!
    Cheers,
    Peter (pjv)
