Problem with IF...THEN statements
Thank You and Welcome.
I have a problem with my code at the level of the IF...THEN statements.
Even when timeout is negative, the Stamp executes the commands as if timeout was positive; so it does not follow the conditions that I imposed.
Down below is the code.
Please Help.
Thank You.
' {$STAMP BS2}
' {$PBASIC 2.5}
pattern VAR Nib
timeout VAR Word
control VAR Word
beginning:
pattern=IND
DEBUG ? pattern, CR
DO
pattern=IND
DEBUG ? pattern, CR
LOOP UNTIL pattern=8
PAUSE 10
IF pattern=0 THEN
GOTO intern1
ENDIF
intern1:
timeout=50
DO
pattern=IND
DEBUG ? pattern, CR
timeout=timeout-1
DEBUG SDEC ? timeout
PAUSE 10
IF ((timeout=0)|(timeout<0)) THEN
GOTO beginning
ENDIF
IF (timeout>0) THEN
GOTO intern2
ENDIF
LOOP UNTIL pattern=2
intern2:
DO
pattern=IND
timeout=timeout-1
DEBUG "*",CR
GOTO beginning
ENDIF
IF (timeout>0) THEN
GOTO intern4
ENDIF
intern4:
DO
pattern=IND
DEBUG ? pattern, CR
timeout=timeout-1
LOOP UNTIL pattern=1
DO
control=timeout
DEBUG SDEC ? control
IF ( timeout < 0) THEN
GOTO beginning
ENDIF
IF (timeout>0) THEN
GOTO intern3
ENDIF
LOOP UNTIL pattern=3
intern3:
HIGH 11
LOW 10
PAUSE 1000
LOW 11
LOW 10
Please Help.
Thank You.
' {$STAMP BS2}
' {$PBASIC 2.5}
pattern VAR Nib
timeout VAR Word
control VAR Word
beginning:
pattern=IND
DEBUG ? pattern, CR
DO
pattern=IND
DEBUG ? pattern, CR
PAUSE 10
IF pattern=0 THEN
GOTO intern1
ENDIF
intern1:
timeout=50
DO
pattern=IND
DEBUG ? pattern, CR
timeout=timeout-1
PAUSE 10
GOTO beginning
ENDIF
IF (timeout>0) THEN
GOTO intern2
ENDIF
intern2:
DO
pattern=IND
timeout=timeout-1
DEBUG "*",CR
GOTO beginning
ENDIF
IF (timeout>0) THEN
GOTO intern4
ENDIF
intern4:
DO
pattern=IND
DEBUG ? pattern, CR
timeout=timeout-1
DO
control=timeout
GOTO beginning
ENDIF
IF (timeout>0) THEN
GOTO intern3
ENDIF
intern3:
HIGH 11
LOW 10
PAUSE 1000
LOW 11
LOW 10
Plan accordingly. Sometimes it's safer to use 100 as your center "zero point" for a variable. Do all your math around that value, never letting it go below 0 or higher than 255 (for a BYTE variable). Then compare the final value to 100 and branch as needed.
Timeout is generally defined / used / evaluated as reaching a value.
For example 60 to timeout 0 - as you probably wanted to use it.
Why would you wanted to check for LESS than timeout value?
Vaclav
PS Your code is looking better.
I tested the code.
I used some debug statements to get the value of timeout at some point in the code.
It does give me the values of timeout that I expect; but can't do the right thing for that value of timeout, say, timeout is negative but it does what it should do when timeout is positive.
The code would work as I want; I just need to make those IF...THEN statements work.
So, my question is: why does the Stamp won't execute a simple conditional IF...THEN statement as that?
I do not get that.
Please Help.
I need to make that IF...THEN statement work; in fact, it should be working right?
Thank You
The IF statement evaluates from left to right , therefore if timeout = 0 is true the "or" will not even get evaluated.
Logically - if you subtract 1 from timeout it wiil reach 0 first anyway.
GOTO beginning
ENDIF
Please identify exactly which IF ... THEN is faling in your code..
Vaclav
The Minimum operator (MIN) limits a value to a specified 16-bit positive minimum. The syntax of MIN is:
Value MIN Limit
Where Value is a constant or variable value to perform the MIN function upon and Limit is the minimum Value that value is allowed to be. When used in a statement like result = Value MIN Limit, its logic is, 'if Value is less than Limit, then make result = Limit; if Value is greater than or equal to Limit, make result = Value.' MIN works in positive math only; its comparisons are not valid when used on twos complement negative numbers, since the positive-integer representation of a number like -1 ($FFFF in hexadecimal or 65535 in unsigned decimal) is larger than that of a number like 10 ($000A hexadecimal or 10 decimal). Use MIN only with unsigned integers. Because of the way fixed-size integers work, you should be careful when using an expression involving MIN 0. For example, result = 0 - 1 MIN 0 will result in 65535 because 0 - 1 = -1 (65535 in two's compliment math) and 65535 is greater the minimum boundary 0.
value1 VAR Word value2 VAR Word Main: FOR value1 = 100 TO 0 STEP 10 ' walk value1 from 100 to 0 value2 = value1 MIN 50 ' use MIN to clamp at 50 DEBUG DEC ? value2 MIN 50 ' show "clamped" value NEXT END[What's it going to take to get you to start Attaching your code instead of Posting it?]
IF timeout=0 OR timeout.bit15=1 THEN ...
instead of
IF ((timeout=0)|(timeout<0)) THEN...
and
IF (timeout.bit15 = 0) THEN...
instead of
IF (timeout>0) THEN...
I think that would work in your current framework.
Bit 15 indicates the status, 1 if negative, 0 if positive. In twos complement, the boundary between positive and negative occurs when that bit flips, between 32767=%0111111111111111 and -32768 = %1000000000000000.
The above is not the only way to do it, as others have explained. You do have to see how the Stamp handles numbers. You can use the SDEC modifier to display a twos complement number, but the Stamp's internal comparisons treat all numbers as positive integers.
IF ( a= 0 | a <0 ) THEN
IF (a= 0 OR a<0 ) THEN
accomplish same results.
Both statements evaluate to true or false.
If there is an error in coding logic, changing | to OR it will not resolve it.
Unless I missed it, the value a is only decremented by 1 , therefore will reach 0 and the statement
a<0 is immaterial as coded.
Of course one could write IF(a<0 | a= 0) THEN...
Maybe then the logical convolution would be more obvious.
Vaclav
The PBASIC syntax {IF a=b OR c=d THEN...} is documented, whereas the bitwise or "|" has to be used with caution. The Stamp evaluates {IF a=b | c=d THEN...} differently than {IF (a=b) | (c=d) THEN...} On the other hand, statements like, {IF a | b THEN...} or {IF a | b = c | d THEN...} are not problematic.
no problem.
Your post is just fine. I think this fellow is making progress and I was just trying to point out that both statements will work same - in this case.
I would not want to give an impression that it will solve the alleged problem.
Vaclav
