Hi all, im looking for recommendations for a diy pcb etching kit, sources,etc. Also what are some opinions about the different processes for doing such.
It took me a few tries, but i noticed that if you run the photo paper through the printer a second time you get better results, make sure you line the paper up good or else it will be off which is not good. Also in the website they recommended the Staples "photo basic" "gloss" i didn't have much success with this as i did with Kodak paper i think the paper just needs to be glossy.
Mouser stocks mg chemicals photoresist boards. Photoresist is definitely the best way, I think. Get the inkjet transparencies. Double them rather than run them through twice.
I had good luck using the Laser Printer Toner Transfer Method even though its not a kit all the materiel is pretty easy to get.
I used the website that makemagazine suggested in their youtube video.
(Makemagazine youtube video)
http://www.youtube.com/watch?v=urv6jArKp6M
(Website)
http://fullnet.com/~tomg/gooteepc.htm
Hope this helped,
CameronM
