Flip Flop Help
Hello and thank you all for this fantastic resource!
I am fumbling around with I suspect is an overly unwieldy amount of code for my application.
My application is as follows:
A set of 8 momentary buttons with an accompanying set of 8 LED's (namely they are illuminated momentary pushbuttons)
I need for each of them to latch; that is, for the corresponding output pin to go high and remain high until any other button is depressed, and for the latch to then shift to the next (random) button to be depressed.
Put very simply: There are 8 buttons, which when pressed, light up and stay lit up until a subsequent button is pressed.
This circuit would be used to control an adjacent system with it's own set of digital inputs and would serve purely as indicator of the last button to have been pressed.
I currently have a convoluted set of IFs, THENs and UNTILs in a big loop, however I suspect there must be a far more elegant way of monitoring a set of 8 dig inputs in one routine and latching a corresponding set of dig outs in another?
Any further guidance would be hugely appreciated.
Thanks again.
Dan
Thanks again.
Dan
People are gonna ask - would you post your code, please? There may be some things to be done there.
Also (my own curiosity), are you sold on using a Stamp for this rather than some latches?
DJ
Vaclav
Thanks. Yes, my existing version uses 74LS logic latches, however I am hoping to reduce my component list and use a micro.
This will also allow us to change the conditions later, if needed.
Thanks anyway.
What is the simplest code definition of "set / latch"?.
Thanks again.
leds VAR OUTL buttons VAR INH buttonsNow VAR Byte buttonsLast VAR Byte idx VAR Nib ' reusable work variable tmp VAR Byte ' resusable work variable Start: OUTS =%0000000000000000 ' all off DIRS = %0000000011111111 ' pins 0-7 outputs (leds), pins 8-15 inputs (buttons) PAUSE 100 ' let settle buttonsNow = buttons ' capture 8 button inputs to byte buttonsLast = buttonsNow ' seed as "last" Main: ' debounce buttons and capture if different.... tmp = buttons ' capture buttons to seed comparison FOR i = 0 TO 5 ' should be good for average debounce IF buttons <> tmp THEN EXIT ' if the current state of pins doesn't match, quit the loop NEXT IF i >= 5 THEN ' you are only here if the buttons remained stable... buttonsNow = tmp ' move it to "now" ENDIF IF buttonsNow <> buttonsLast THEN ' you had a change from the last time leds = buttonsNow ' move to leds ENDIF ' the nice thing is you can do other stuff here if you need to, and the leds will be fine and ' you won't miss human button presses... e.g. SEROUT x,y,z, [ tmp ] ' comm with some other device SERIN x,y,z, [ tmp ] ' comm with some other device ' do some other stuff buttonsLast = buttonsNow ' save as last -- do it last so you can "parse" state changes if you want... GOTO MainAnother nice thing about this setup is it lets you see if a button was "released" or "pressed", e.g.
IF buttonsNow.BIT4 = 1 AND buttonsLast.BIT4 = 0 THEN ' if button 4 is high and it was low, it was pressed... DEBUG "button 4 pressed!", CR ELSEIF buttonsNow.BIT4 = 0 AND buttonsLast.BIT4 = 1 THEN DEBUG "button 4 released", CR ELSEIF buttonsNow.BIT4 = 1 AND buttonsLast.BIT4 = 1 THEN DEBUG "let go of it already!", CR ENDIF ' or... FOR idx = 0 TO 7 IF buttonsNow.BIT0(idx) = 1 AND buttonsLast.BIT0(idx) = 0 THEN DEBUG "button ", DEC1 idx," pressed!", CR ELSEIF buttonsNow.BIT0(idx) = 0 AND buttonsLast.BIT0(idx) = 1 THEN DEBUG "button ", DEC1 idx," released!", CR ENDIF NEXTSo.... combining the two to latch only a "press"...
leds VAR OUTL buttons VAR INH buttonsNow VAR Byte buttonsLast VAR Byte idx VAR Nib ' reusable work variable tmp VAR Byte ' reusable work variable Start: OUTS =%0000000000000000 ' all off DIRS = %0000000011111111 ' pins 0-7 outputs (leds), pins 8-15 inputs (buttons) PAUSE 100 ' let settle buttonsNow = buttons ' capture 8 button inputs to byte buttonsLast = buttonsNow ' seed as "last" Main: ' debounce buttons and capture if different.... tmp = buttons ' capture buttons to seed comparison FOR i = 0 TO 5 ' should be good for average debounce IF buttons <> tmp THEN EXIT ' if the current state of pins doesn't match, quit the loop NEXT IF i >= 5 THEN ' you are only here if the buttons remained stable... buttonsNow = tmp ' move it to "now" ENDIF IF buttonsNow <> buttonsLast THEN ' you had a change from the last time, check for a press FOR idx = 0 TO 7 IF buttonsNow.BIT0(idx) = 1 AND buttonsLast.BIT0(idx) = 0 THEN leds = buttonsNow ' move to leds EXIT ENDIF NEXT ENDIF ' the nice thing is you can do other stuff here if you need to, and the leds will be fine and ' you won't miss human button presses... e.g. SEROUT x,y,z, [ tmp ] ' comm with some other device SERIN x,y,z, [ tmp ] ' comm with some other device ' do some other stuff buttonsLast = buttonsNow ' save as last -- do it last so you can "parse" state changes if you want... GOTO MainI imagined a solution exactly like yours, but was still very hazy with storing the button states as Byte's and the use of OUTS and DIRS.
This really helps me join the dots, so thanks again.
