Heat Sink adhesive??
RobotWorkshop
I have a Propeller USB protoboard where the 5V regulator is getting a bit warmer than I'd like. When I went through my spare Heat sink drawer I found some small .5"x.5" heat sinks that were normally held on with adhesive. I'd like to glue one of these to the top of the 5V regulator on the board to help keep it cool.
Anyone have suggestions as to what adhesives would work well and help move the heat to the heat sink??
Robert
Robert
but the commonly available JB-Weld has "metal bits" in it.
Robert
Or, You could always glue a Penny on top..
I did use a penny once with JB weld. In a pinch. I was installing equipment in Mongolia, and an soic-8 VR was getting hot due to a higher load than originally planned. I was afraid the hotel (if you can call it that) manager would come in and freak out about the heat cure acceleration going on above the table lamp. I wonder if the penny really helped. In any case, it came loose after some time and it is a miracle it didn't fall and short something out. The circuit kept working though. The thing about epoxy and smooth surfaces is that it does not hold up well to extreme thermal cycling.
It's even more thrifty when You consider shipping charges. :thumb:
The Paper Clip has some merit.. Quad Paper clips... hmmm
The Secretary passes those out for free...:cool:
from Aavid http://www.aavidthermalloy.com/products/options/theragrip.shtml
John Abshier
Now just a bit more wiring on my 2nd Propeller board and I can start getting everything together and focus on programming......
Robert
This is the first time I've ever had to use a glue on heatsink and I used what I had on hand. It certainly seems to help. If I'm going to be doing more heat sinks like this I'll definitely look at getting some of the Loctite or Arctic Silver for gluing them on. May check into the tape as well.
Thanks to everyone for the suggestions!
Robert
Perhaps drill a hole in the penny and use a small bolt to secure
it to the regulator. A tiny dab of that white goo that is used on
PC processors could make heat transfer better.
A nickle might work even better?
I'm trying to think of some other small bits of metal that could
be commonly found around a house and be drilled and used as
a heat sink.... I wonder if a lid from a tin can could be folded
in such a way as to make a compact but efficient heat sink
for something larger, like a large power transistor maybe.
For this reason, I gravitated to using silicone rubber (RTV) to afix transistor and regulator tabs to heatsinks. RTV is not as conductive as metal-filled epoxy, but my calculations show that for a layer about 0.001" thick, the difference in thermal conductivity is minor.
Joints that thin are relatively easy to obtain: First make sure the heatsink and tab are flat, smooth, and clean. Second, press the device firmly and work it around a bit to squeeze out every bit of RTV you can. Then bank up the excess against the sides of the tab (helping facilitate a suction cup effect).
No device I've ever mounted this way has fallen off. YMMV.
Now that I have the Heat sink installed it seems to help and so far hasn't been that hot. With it installed I hope to avoid the 'Extreme' thermal cycling so it shouldn't be a problem on this board.
For anything that I'm building I usually use the TO-220 case parts so I just bolt on the Heat sink.
What would conduct the heat even better would be a pre 1965 silver dime, but at $2.70+ each now, I wouldn't waste it on that.
Thanks for the JB weld tip. My Arctic Silver epoxy went hard after few years, but I have plenty of JBWeld arround.
I am defiantly keeping this in mind next time I need a light duty heat sink. This is some great outside the box thinking imo, the idea is simple and very doable without much cost at all.
P.S. I use super glue and so far no major problems.
-browz
I didn't want your kind offer to pass unnoticed. Had you written on Apr. 1st, I might have thought you were fooling! Please ask Phil if how long (in his opinion) it takes for the fishy aroma to dissipate.
I had occasion to look up recommendations on using PCB copper area as a heat sink. The thermal spreading resistance is quite high for 1oz copper, so extending the area beyond a certain point gives diminishing returns. However, it is such a convenient option for surface mount parts.
ST AN1703 Guidelines for Using ST's Mosfet SMD Packages
Micrel AH-17 Designing P.C. Board Heat Sinks
-browz
sink for a TO220 but I have no access to a vice just now to try it out.
Fold the lid in half, then fold again to get a flattened 1/4 circle, then fold
in a section from one corner just wide enough to drill a hole and attach
the TO220 device. Then bend out the can flaps like little wings and spread
the metal out at the top with a screwdriver blade to allow heat transfer
to the air. Should work.
I want to try this with a 7800 regulator and see if it can keep the
regulator cool enough to work at 1 - 1.5 amps
If anyone tries this please post a picture...and send in to Hack-A-Day
as a tip for the frugal :-)
Looking at the post I noticed that all the posts above mine
were from moderators....a string of moderators with the little
green moderator tag.
Your mission is to photoshop an image that looks just like the
Moderator tag and add it to the top of your avatar image. It should look just
the same as the tag put up by the forum software but change the tag to
say something funny like.
[Troublemaker]
[Weak Minded]
[Spelling Cop]
[Busybody]
[Genius]
[Troll]
LoL..... I'm a hopeless practical joker always thinking of something silly to do.
It would have been a great April fool prank for everyone to be a Moderator when
the Parallax staff looked at the board.... ha :-)
