Flasher Dasher
This is a project I did in my truck. I posted it in Savage.circuits v1.0 so I think I'll repost it here. It uses a BS1 and some really bright blue LEDs.
This is the panel from the dash that I modified. The row of LEDs across the top and a potentiometer in the middle. It's a multi-turn, if that's the right word, pot - perhaps too many turns to change the rate of flash. You almost have to spin it, but it allows for fine tuning of the flash rate.
A toggle switch for power control. Neat little face plate I salvaged from something, I don't recall.
Another view of the front. I'm not sure the LEDs are perfectly strait.
A view of the back. The BS1 is shown here on the small perf-board. The BS1 uController directly drives the LEDs and inputs for the potentiometer. Power is through a fuse box that is hot when ignition is on.
Better angle on the board. The black, round component behind the red wires is the Pot. I love the giant ceramic capacitor I dug out of my junk box!
This is supposed to show the heat shrink around the LED leads. It also shows the hot-glue I used on the LEDs and circuit board. That was fun (messy).
From the right side.
From the bottom view. Minimal soldering here.
And the top view. See the common cathode connections below the heat shrink covered anodes?
