Good question. The HM55B is discontinued in favor of a much better compass device, but Parallax usually keeps the webstore page available for reference. Attached is my copy of the HM55B documentation and sample programs.
Each one will have a wiring diagram and sample code for the bS2.· You will· need to adjust the codes to make them work together.
Dave
Dave Andreae
Parallax Tech Support·
first attempt probably needs adjustment
' -----[ Title ]--------------------------------------------------------------
' Smart Sensors and Applications - Ping)))Dar.bs2
' Display radar style object distance measurements in the Debug Terminal.
' as the Boe-Bot sweeps the Ping))) Mounting Bracket servo from right
' (0-degrees) to left (180-degrees).
' {$STAMP BS2} ' Target device = BASIC Stamp 2
' {$PBASIC 2.5} ' Language = PBASIC 2.5
' -----[ I/O Definitions ]----------------------------------------------------
PingServo PIN 14 ' Servo that directs Ping)))
Ping PIN 15 ' Ping))) sensor signal pin
DinDout PIN 10 ' P6 transceives to/from Din/Dout
Clk PIN 8 ' P5 sends pulses to HM55B's Clk
En PIN 9 ' P4 controls HM55B's /EN(ABLE)
Reset CON %0000 ' Reset command for HM55B
Measure CON %1000 ' Start measurement command
Report CON %1100 ' Get status/axis values command
Ready CON %1100 ' 11 -> Done, 00 -> no errors
NegMask CON %1111100000000000 ' For 11-bit negative to 16-bits
a VAR Word ' x-axis data
b VAR Word ' y-axis data
status VAR Nib ' Status flags
degree VAR Word ' Store angle measurement
' -----[ Constants ]----------------------------------------------------------
LimitLeft CON 1250 ' Bracket 90-degrees LimitLeft
LimitRight CON 250 ' Bracket 90-degrees LimitRight
PingDirToAngle CON 8454 ' Servo pulse -> angle with **
CmConstant CON 2260 ' Echo time -> cm with **
SinCosTo256 CON 517 ' For */ -127..127 -> -256..256
Increment CON 15 ' Servo PULSOUT increment value
Negative CON 1 ' Negative sign
Positive CON 0 ' Positive sign
' -----[ Variables ]----------------------------------------------------------
pingDir VAR Word ' Pulse duration -> direction
time VAR Word ' Ping))) echo time
distance VAR Time ' Object distance
x VAR Word ' x Debug cursor coordinate
y VAR Word ' y Debug cursor coordinate
angle VAR Byte ' Angle from LimitRight in brads
counter VAR angle ' Loop counter
sweepInc VAR Nib ' Sweep increment
sweepDir VAR Bit ' Increment/decrement pingDir
xSign VAR Bit ' x variable sign
ySign VAR xSign ' Stores sign of y variable
nsign VAR Bit ' Numerator sign
dsign VAR Bit ' Denominator sign
' -----[ Initialization ]-----------------------------------------------------
pingDir = LimitRight ' Start servo at 0-degrees
FOR counter = 1 TO 40 ' Initialize servo position
PULSOUT PingServo, pingDir
PAUSE 20
NEXT
sweepInc = Increment ' Set the sweep increment
' -----[ Main Routine ]-------------------------------------------------------
DO
GOSUB Compass_Get_Axes ' Get x, and y values
angle = x ATN -y ' Convert x and y to brads
angle = angle */ 360 ' Convert brads to degrees
DEBUG HOME, "x-axis N(-S) = ",SDEC x, ' Display axes and degrees
CLREOL, CR, "y-axis W(-E) = ",
SDEC y, CLREOL, CR, CR, "angle = ",
DEC angle, " degrees", CLREOL
PAUSE 150
IF pingDir <= LimitRight THEN ' Refresh display if far right
DEBUG CLS, CRSRXY, 50, 25, "X"
ENDIF
GOSUB Sweep_Increment ' Move servo by sweepInc
' Calculate angle from far right in brads.
angle = pingDir - LimitRight ** PingDirToAngle
GOSUB Get_Ping_Cm ' Get cm measurement
distance = distance MAX 100 / 4 ' Scale for Debug Terminal
GOSUB Polar_To_Cartesian ' distnace @ angle -> (x, y)
x = x * 2 ' 2 spaces for every 1 CR
DEBUG CRSRXY, 50 + x, 25 - y, "*" ' Display (x, y) coordinate
LOOP
' -----[ Subroutine - Get_Ping_Cm ]-------------------------------------------
' Gets Ping))) rangefinder measurement and converts time to centimeters.
' Distance may be declared as time to save variable space.
Get_Ping_Cm:
PULSOUT Ping, 5
PULSIN Ping, 1, time
distance = time ** CmConstant
RETURN
' -----[ Subroutine - Polar_To_Cartesian ]------------------------------------
' Calculates x and y (Cartesian coordinates) given distance and angle
' (polar coordinates).
Polar_To_Cartesian:
' Calculate x coordinate.
x = COS angle ' Polar to Cartesian
xSign = x.BIT15 ' Store sign bit
x = ABS(x) */ SinCOsTo256 ' Polar to Cartesian continued
x = distance */ x
IF xSign = negative THEN x = -x ' Correct sign with sign bit
' Calculate y coordinate.
y = SIN angle ' Polar to Cartesian
ySign = y.BIT15 ' Store sign bit
y = ABS(y) */ SinCOsTo256 ' Polar to Cartesian continued
y = distance */ y
IF ySign = negative THEN y = -y ' Correct sign with sign bit
RETURN
' -----[ Subroutine - Sweep_Increment ]---------------------------------------
' Increment/decrement the position of the servo that directs the Ping)))
' rangefinder. When pingDir goes outside either LimitRight or LimitLeft,
' the sweep direction toggles.
Sweep_Increment:
' Change sweepDir for adding/subtracting increment if at rotation limit.
sweepDir = Positive
ELSEIF pingDir >= LimitLeft THEN
sweepDir = Negative
ENDIF
' Add/subtract increment to/from pingDir.
IF sweepDir = negative THEN
pingDir = pingDir - sweepInc
ELSEIF sweepDir = Positive THEN
pingDir = pingDir + sweepInc
ENDIF
' Send positioning pulse to Ping))) Mounting Bracket servo.
RETURN
' -----[ Subroutines - get axis ]-----------------------------
Compass_Get_Axes: ' Compass module subroutine
HIGH En: LOW En ' Send reset command to HM55B
SHIFTOUT DinDout,clk,MSBFIRST,[Reset\4]
HIGH En: LOW En ' HM55B start measurement command
SHIFTOUT DinDout,clk,MSBFIRST,[Measure\4]
status = 0 ' Clear previous status flags
DO ' Status flag checking loop
HIGH En: LOW En ' Measurement status command
SHIFTOUT DinDout,clk,MSBFIRST,[Report\4]
SHIFTIN DinDout,clk,MSBPOST,[Status\4] ' Get Status
LOOP UNTIL status = Ready ' Exit loop when status is ready
SHIFTIN DinDout,clk,MSBPOST,[x\11,y\11] ' Get x & y axis values
HIGH En ' Disable module
IF (b.BIT10 = 1) THEN b = b | NegMask ' Store 11-bits as signed word
IF (a.BIT10 = 1) THEN a = a | NegMask ' Repeat for other axis
RETURN
Howdy- what is this new compass device? Currently when I go to compass sensors absolutely none show up- it is all GPS. Can you direct me to this new compass? Thanks
http://www.parallax.com/Store/Sensors/CompassGPS/tabid/173/CategoryID/48/List/0/Level/a/ProductID/98/Default.aspx?SortField=ProductName%2cProductName
http://www.parallax.com/Store/Robots/RoboticAccessories/tabid/145/CategoryID/22/List/0/SortField/0/Level/a/ProductID/248/Default.aspx
Dave
Dave Andreae
P.S.: I just remember that the use of compass is only for data-log.
Post Edited (MichelB) : 6/22/2009 4:22:46 PM GMT
' -----[ Title ]-------------------------------------------------------------- ' Smart Sensors and Applications - Ping)))Dar.bs2 ' Display radar style object distance measurements in the Debug Terminal. ' as the Boe-Bot sweeps the Ping))) Mounting Bracket servo from right ' (0-degrees) to left (180-degrees). ' {$STAMP BS2} ' Target device = BASIC Stamp 2 ' {$PBASIC 2.5} ' Language = PBASIC 2.5 ' -----[ I/O Definitions ]---------------------------------------------------- PingServo PIN 14 ' Servo that directs Ping))) Ping PIN 15 ' Ping))) sensor signal pin DinDout PIN 10 ' P6 transceives to/from Din/Dout Clk PIN 8 ' P5 sends pulses to HM55B's Clk En PIN 9 ' P4 controls HM55B's /EN(ABLE) Reset CON %0000 ' Reset command for HM55B Measure CON %1000 ' Start measurement command Report CON %1100 ' Get status/axis values command Ready CON %1100 ' 11 -> Done, 00 -> no errors NegMask CON %1111100000000000 ' For 11-bit negative to 16-bits a VAR Word ' x-axis data b VAR Word ' y-axis data status VAR Nib ' Status flags degree VAR Word ' Store angle measurement ' -----[ Constants ]---------------------------------------------------------- LimitLeft CON 1250 ' Bracket 90-degrees LimitLeft LimitRight CON 250 ' Bracket 90-degrees LimitRight PingDirToAngle CON 8454 ' Servo pulse -> angle with ** CmConstant CON 2260 ' Echo time -> cm with ** SinCosTo256 CON 517 ' For */ -127..127 -> -256..256 Increment CON 15 ' Servo PULSOUT increment value Negative CON 1 ' Negative sign Positive CON 0 ' Positive sign ' -----[ Variables ]---------------------------------------------------------- pingDir VAR Word ' Pulse duration -> direction time VAR Word ' Ping))) echo time distance VAR Time ' Object distance x VAR Word ' x Debug cursor coordinate y VAR Word ' y Debug cursor coordinate angle VAR Byte ' Angle from LimitRight in brads counter VAR angle ' Loop counter sweepInc VAR Nib ' Sweep increment sweepDir VAR Bit ' Increment/decrement pingDir xSign VAR Bit ' x variable sign ySign VAR xSign ' Stores sign of y variable nsign VAR Bit ' Numerator sign dsign VAR Bit ' Denominator sign ' -----[ Initialization ]----------------------------------------------------- pingDir = LimitRight ' Start servo at 0-degrees FOR counter = 1 TO 40 ' Initialize servo position PULSOUT PingServo, pingDir PAUSE 20 NEXT sweepInc = Increment ' Set the sweep increment ' -----[ Main Routine ]------------------------------------------------------- DO GOSUB Compass_Get_Axes ' Get x, and y values angle = x ATN -y ' Convert x and y to brads angle = angle */ 360 ' Convert brads to degrees DEBUG HOME, "x-axis N(-S) = ",SDEC x, ' Display axes and degrees CLREOL, CR, "y-axis W(-E) = ", SDEC y, CLREOL, CR, CR, "angle = ", DEC angle, " degrees", CLREOL PAUSE 150 IF pingDir <= LimitRight THEN ' Refresh display if far right DEBUG CLS, CRSRXY, 50, 25, "X" ENDIF GOSUB Sweep_Increment ' Move servo by sweepInc ' Calculate angle from far right in brads. angle = pingDir - LimitRight ** PingDirToAngle GOSUB Get_Ping_Cm ' Get cm measurement distance = distance MAX 100 / 4 ' Scale for Debug Terminal GOSUB Polar_To_Cartesian ' distnace @ angle -> (x, y) x = x * 2 ' 2 spaces for every 1 CR DEBUG CRSRXY, 50 + x, 25 - y, "*" ' Display (x, y) coordinate LOOP ' -----[ Subroutine - Get_Ping_Cm ]------------------------------------------- ' Gets Ping))) rangefinder measurement and converts time to centimeters. ' Distance may be declared as time to save variable space. Get_Ping_Cm: PULSOUT Ping, 5 PULSIN Ping, 1, time distance = time ** CmConstant RETURN ' -----[ Subroutine - Polar_To_Cartesian ]------------------------------------ ' Calculates x and y (Cartesian coordinates) given distance and angle ' (polar coordinates). Polar_To_Cartesian: ' Calculate x coordinate. x = COS angle ' Polar to Cartesian xSign = x.BIT15 ' Store sign bit x = ABS(x) */ SinCOsTo256 ' Polar to Cartesian continued x = distance */ x IF xSign = negative THEN x = -x ' Correct sign with sign bit ' Calculate y coordinate. y = SIN angle ' Polar to Cartesian ySign = y.BIT15 ' Store sign bit y = ABS(y) */ SinCOsTo256 ' Polar to Cartesian continued y = distance */ y IF ySign = negative THEN y = -y ' Correct sign with sign bit RETURN ' -----[ Subroutine - Sweep_Increment ]--------------------------------------- ' Increment/decrement the position of the servo that directs the Ping))) ' rangefinder. When pingDir goes outside either LimitRight or LimitLeft, ' the sweep direction toggles. Sweep_Increment: ' Change sweepDir for adding/subtracting increment if at rotation limit. IF pingDir <= LimitRight THEN sweepDir = Positive ELSEIF pingDir >= LimitLeft THEN sweepDir = Negative ENDIF ' Add/subtract increment to/from pingDir. IF sweepDir = negative THEN pingDir = pingDir - sweepInc ELSEIF sweepDir = Positive THEN pingDir = pingDir + sweepInc ENDIF ' Send positioning pulse to Ping))) Mounting Bracket servo. PULSOUT PingServo, pingDir RETURN ' -----[ Subroutines - get axis ]----------------------------- Compass_Get_Axes: ' Compass module subroutine HIGH En: LOW En ' Send reset command to HM55B SHIFTOUT DinDout,clk,MSBFIRST,[Reset\4] HIGH En: LOW En ' HM55B start measurement command SHIFTOUT DinDout,clk,MSBFIRST,[Measure\4] status = 0 ' Clear previous status flags DO ' Status flag checking loop HIGH En: LOW En ' Measurement status command SHIFTOUT DinDout,clk,MSBFIRST,[Report\4] SHIFTIN DinDout,clk,MSBPOST,[Status\4] ' Get Status LOOP UNTIL status = Ready ' Exit loop when status is ready SHIFTIN DinDout,clk,MSBPOST,[x\11,y\11] ' Get x & y axis values HIGH En ' Disable module IF (b.BIT10 = 1) THEN b = b | NegMask ' Store 11-bits as signed word IF (a.BIT10 = 1) THEN a = a | NegMask ' Repeat for other axis RETURNHowdy- what is this new compass device? Currently when I go to compass sensors absolutely none show up- it is all GPS. Can you direct me to this new compass? Thanks
