Hal Chamberlin's "Musical Applications of Microprocessors"
Hey there,
I recently acquired a used copy of the book. Although it's outdated, but there are many quick tricks and guides of making music on the microprocessor.
The thing is, the language in the program codes used is in some ASM, and a bit of Fortran and Basic. They can be "ported" to any newer microcontroller programming languages.
I'm reading about the inverse fast fourier transform in that book. I believe that any new dsPICs or higher end microcontrollers could do that quickly nowadays.
If we were really keen that algorithm could be split over 2 or 4 COGS for higher bandwidth.
With a bit of tweaking it can of course perform the inverse transform and be used for sound sysnthesis.
http://forums.parallax.com/showthread.php?128292-Heater-s-Fast-Fourier-Transform.&highlight=heater_fft
Mind you that is only good for about 10 bits per sample.
