Possible Solution to Damaged Reactors
I believe robotics must be a necessary part of nuclear reactor maintainance. Gamma rays are far too dangerous for organic tissue. Everything requires some maintainance including containment vessels and cooling pumps. The following link points to a possible solution; Robotic CNC for Nuclear Reactor Repair
(I apologize if I've missed current discussions, I've been working diligently on a project.)
There was no question in my mind – this is a Disaster on a big scale
And now the nuclear plant which was originally and quietly presented without ever mentioning how many reactors are on the site!
Now I am puzzled with “entertainment media” prizing Japan's technological know – how.
Really? What happened to ASIMO robot? Is it technological know – how or just a wiz-bang?
You comment is right on the money – why is ASIMO not fixing anything?
Vaclav
My point is that this behavior isn't unique to nuclear power, but the higher stakes make the penalties for doing it much higher. Or as Douglas Adams would say "People are the problem."
Yes, there's a reason nobody will insure against nuclear disasters. The insurance companies have crunched the numbers and read the tea leaves of common sense.
All things that we would do very easily but can't because of the radiation.
I read somewhere that the reason ASIMO is small is because people might feel threatened by a robot the same size as them (but stronger, and maybe more coordinated). Perhaps this will drive robotics research in a new direction?
I have to disagree with you (what else is new?) but I recall "robotic arm" sold by Radio Shack(?) about 25 years(!) ago. It was crude but pretty articulate. I bet if scaled up it could manipulate 2.5 inch fire hose better that I did in my volunteer firefighter days!
I think its non popularity was - it did not look like a robot!
But you are right - ASIMO is definitely a threat because it runs software build by engineering committees supervised by bean counters!
For reference – see A,Cooper “The inmates are running the asylum”.
Sadly, I think to an extent you can say the same about nuclear generating plants.
