SparkFun Serial 7-Segment Serial Display
I just got a couple of these four digit, 7-segment LED display modules from SparkFun.
They can be driven by TTL Serial or SPI and come in several colors.
I am using a BS2 at 9600 baud in the video. The characters look whitish in the video, but are actually bright blue. There are commands to set the brightness, change the baud rate and control individual segments and decimal points/colon.
I am really pleased with them!
Well done!
Mike B.
I didn't record any audio so I used the YouTube AudioSwap feature and stumbled on this background music - I don't even recall the name, but it does almost appear like it is synched to the display's "animation"...
' {$STAMP BS2} ' {$PBASIC 2.5} DecPts CON $77 ' "w" Decimal point command Brightness CON $7A ' "z" Brightness command 0(bright) - 254(dim) setBaud CON $7F ' DEL 0=2400, 1=4800, 2=9600, 3=1440, 4=19200, 5=38400, 6=57600 ClearScr CON $76 ' "v" clear display and set position to 1st digit Digit1 CON $7B ' "{" set individual segments for digit one Digit2 CON $7C ' "|" set individual segments for digit two Digit3 CON $7D ' "}" set individual segments for digit three Digit4 CON $7E ' "~" set individual segments for digit four #SELECT $STAMP ' Select Baud constants #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 #ENDSELECT Inverted CON $4000 'Value for inverted serial format Baud CON T9600 '+ Inverted 8,N,1 inverted LED7 CON 0 'msg DATA "0123456789AbCcDEeFGHhIJLnOoPqrStUuy-'_" msg DATA " Scroll test - ABCDEF_0123456789 " msgend DATA 0 msglen VAR Byte msgAddr VAR Word disp VAR Byte(4) i VAR Byte j VAR Byte k VAR Byte patt VAR Byte nxt VAR Byte Main: msglen = msgend - msg 'calc length of data string ' DEBUG CLS SEROUT LED7,Baud,[ClearScr] PAUSE 100 SEROUT LED7,Baud,[Brightness, 16] '0] PAUSE 100 patt = 0 SEROUT LED7,Baud,[Decpts, patt] DO SEROUT LED7,Baud,[ClearScr] FOR j= 0 TO 5 GOSUB Chase NEXT GOSUB AllChars PAUSE 500 FOR j = 0 TO 3 GOSUB DecPoints NEXT PAUSE 500 LOOP STOP AllChars: msgAddr = msg 'set to start of scroll string k = 0 DO FOR i = 0 TO 3 READ k, nxt IF nxt = 0 THEN disp(i) = " " ELSE disp(i) = nxt k = k + 1 ENDIF NEXT SEROUT LED7,Baud,[disp(0), disp(1), disp(2), disp(3)] ' DEBUG disp(0), disp(1), disp(2), disp(3), " ", DEC k, CR IF k >= msgend THEN EXIT ELSE k = k - 3 PAUSE 200 ENDIF LOOP RETURN Chase: patt = %00000001 FOR i=0 TO 5 SEROUT LED7,Baud,[Digit1, patt] SEROUT LED7,Baud,[Digit2, patt] SEROUT LED7,Baud,[Digit3, patt] SEROUT LED7,Baud,[Digit4, patt] patt = patt << 1 PAUSE 80 NEXT RETURN DecPoints: SEROUT LED7,Baud,[Digit1, %01001001] SEROUT LED7,Baud,[Digit2, %01000110] SEROUT LED7,Baud,[Digit3, %01110000] SEROUT LED7,Baud,[Digit4, %01100100] patt = %00000001 FOR i=0 TO 6 SEROUT LED7,Baud,[Decpts, patt] ' SEROUT LED7,Baud,[Brightness, (i * 20)] patt = patt << 1 PAUSE 150 NEXT RETURNI modified the object that comes with the Parallax Laser Range Finder to take continuous readings and display the distance (in mm) to the display.
Here's the modified display method:
PRI LRFDisplayRange(range, type) ' Print the range result { if (type == cam#ResultBinary) ' Send 4-byte long in binary corresponding to the actual range value ser.Tx(range.BYTE[3]) ser.Tx(range.BYTE[2]) ser.Tx(range.BYTE[1]) ser.Tx(range.BYTE[0]) else } ' Default to printable ASCII output 'ser.Tx(NL) 'ser.Str(String("D = ")) [B] if range <> oldRange ser.Tx("v") ser.Tx("0" + range / 1000) ' Add leading zeros so we always send a 4-character value ser.Tx("0" + (range // 1000) / 100) ser.Tx("0" + (range // 100) / 10) ser.Tx("0" + (range // 10)) [/B] 'ser.Str(String(" mm ")) [B]oldRange := range [/B]I had make a couple other modifications to the code. I'm attaching the modified archive.
