S2 Ramp Code
I wrote my own ramp up and down code like this
but the S2's movement stop momentarily at each speed change. This makes the movement jerky.
How do I ramp smoothly?
PRI ramp_forward(Dist) if Dist < 1000 ' minimum dist s2.set_speed(7) s2.go_forward(Dist) return s2.set_speed(5) ' Ramp Up 500 s2.go_forward(100) s2.set_speed(10) s2.go_forward(400) s2.set_speed(15) ' Full speed ahead s2.go_Forward(Dist-1000) s2.set_speed(10) ' Ramp Down 500 s2.go_forward(400) s2.set_speed(5) s2.go_forward(100)
But I am thinking that since the S2 object works at such a higher level of abstraction you don't need to ramp by hand.
