Including a variable value in a string sent with FullDuplexSerial?
I would like to replace this (working) block of code:
VAR
BYTE VariableValue
PUB SendTheseBytes
FullDuplexSerial.tx ($01)
FullDuplexSerial..tx ($02)
FullDuplexSerial..tx ($03)
FullDuplexSerial..tx ($04)
FullDuplexSerial..tx (VariableValue)
FullDuplexSerial..tx ($FF)
...with a string-sending version:
PUB SendThisString
serial.str (@Str1)
DAT
Str1 BYTE $01, $02, $03, $04, "VariableValue", $FF, 0
...but cannot for the life of me figure out how to format it get it to include the "VariableValue" value in the string transmitted. Surely there is some way to do this?
VAR
BYTE VariableValue
PUB SendTheseBytes
PUB SendThisString
serial.str (@Str1)
DAT
Or you could do it this way:
sio.str(@str1) DAT Str1 byte 1,2,3,4 VariableValue byte 0-0 byte $ff,0One problem with the second way, is that VariableValue can never equal zero; otherwise the string would terminate prematurely.-Phil
I come from the world of Basic, where strings are a fundamental part of the language.
mystring = "Hello" + "World"
So I took Kye's very rich string object and added a few more , eg .str to convert a number to a string. There are also hex to string and a method to add strings together. So - build up the string first from all your values, and then send it out.
In your "main" program, create a few generic string arrays
declare your object
and here are some examples of using Kye's methods
'printstring(@lineoftext1) ' testing string functions 'str.left(@lineoftext1,@lineoftext2,3) ' find leftmost characters in a string 'printstring(@lineoftext2) 'str.trimstring(@lineoftext1) 'printstring(@lineoftext1) 'str.trimstring(@lineoftext1) 'str.mid(@lineoftext1,@lineoftext2,4,2) ' find middle characters in a string 'printstring(@lineoftext2) 'printstring(str.integertodecimal(str.len(@lineoftext2),5)) 'str.copy(string("hello"),@lineoftext1) ' copy fixed value into a string 'printstring(@lineoftext1) 'str.str(@lineoftext1,55) ' decimal to string with no leading zeros 'printstring(@lineoftext1) 'str.stringfill(@lineoftext1,10,65) 'printstring(@lineoftext1) 'str.str(@lineoftext1,1234)' convert to string 'str.str(@lineoftext1,str.decimaltointeger(@lineoftext1)) ' convert back 'printstring(@lineoftext1) ' str.left(@lineoftext1,@lineoftext2,str.len(@lineoftext1)-4) ' remove extension ' printstring(@lineoftext2) ' print it outand this is the object
{{ /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // ASCII0 String Engine // // Author: Kwabena W. Agyeman // Updated: 8/28/2010 // Designed For: P8X32A // Version: 1.2 // // Copyright (c) 2010 Kwabena W. Agyeman // See end of file for terms of use. // // Update History: // // v1.0 - Original release - 4/10/2009. // v1.1 - Made code faster - 8/18/2009. // v1.2 - Updated library functions, fixed bugs, and made code more robust against whitespace and capitalization - 7/27/2010. // // For each included copy of this object only one spin interpreter should access it at a time. // // Nyamekye, /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// }} VAR word tokenStringPointer byte decimalString[12], hexadecimalString[9], binaryString[33], characterToStringPointer, characterToString[255] PUB buildString(character) '' 4 Stack longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Builds a string from individual characters. Use "builtString" to get the address of the string. '' // '' // If the backspace character is put into the string it is automatically evaluated by removing the previous character. '' // '' // If 254 characters are put into the string all characters excluding backspace that are put into the string are ignored. '' // '' // Character - The next character to include in the string. Null will be ignored. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// ifnot(characterToStringPointer) bytefill(@characterToString, 0, 255) if(characterToStringPointer and (character == 8)) characterToString[--characterToStringPointer] := 0 elseif(character and (characterToStringPointer <> 254)) characterToString[characterToStringPointer++] := character PUB builtString(resetString) '' 4 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Returns the pointer to the string built from individual characters. '' // '' // Reset - If true the next call to "buildString" will begin building a new string and the old string will be destroyed. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// characterToStringPointer &= not(resetString) return @characterToString PUB builderNumber '' 3 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Returns the number of characters in the string builder buffer. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// return characterToStringPointer PUB builderFull '' 3 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Returns true if the string builder buffer is full and false if not. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// return (characterToStringPointer == 254) PUB stringCompareCS(characters, otherCharacters) '' 5 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Compares two strings case sensitively. '' // '' // Returns zero if the two strings are equal. '' // Returns a positive value if "characters" comes lexicographically after "otherCharacters". '' // Returns a negative value if "characters" comes lexicographically before "otherCharacters". '' // '' // Characters - A pointer to a string of characters. '' // OtherCharacters - A pointer to another string of characters. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat result := (byte[characters] - byte[otherCharacters++]) while(byte[characters++] and (not(result))) PUB stringCompareCI(characters, otherCharacters) '' 9 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Compares two strings case insensitively. '' // '' // Returns zero if the two strings are equal. '' // Returns a positive value if "characters" comes lexicographically after "otherCharacters". '' // Returns a negative value if "characters" comes lexicographically before "otherCharacters". '' // '' // Characters - A pointer to a string of characters. '' // OtherCharacters - A pointer to another string of characters. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat result := (ignoreCase(byte[characters]) - ignoreCase(byte[otherCharacters++])) while(byte[characters++] and (not(result))) PUB stringCopy(whereToPut, whereToGet) '' 5 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Copies a string from one location to another. This method can corrupt memory. '' // '' // Returns a pointer to the new string. '' // '' // WhereToPut - Address of where to put the copied string. '' // WhereToGet - Address of where to get the string to copy. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// bytemove(whereToPut, whereToGet, (strsize(whereToGet) + 1)) return whereToPut PUB stringConcatenate(whereToPut, whereToGet) '' 5 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Concatenates a string onto the end of another. This method can corrupt memory. '' // '' // Returns a pointer to the new string. '' // '' // WhereToPut - Address of the string to concatenate a string to. '' // WhereToGet - Address of where to get the string to concatenate. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// bytemove((whereToPut + strsize(whereToPut)), whereToGet, (strsize(whereToGet) + 1)) return whereToPut PUB stringToLowerCase(characters) '' 4 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Demotes all upper case characters in the set of ("A","Z") to their lower case equivalents. '' // '' // Characters - A pointer to a string of characters to convert to lowercase. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat strsize(characters--) result := byte[++characters] if((result => "A") and (result =< "Z")) byte[characters] := (result + 32) PUB stringToUpperCase(characters) '' 4 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Promotes all lower case characters in the set of ("a","z") to their upper case equivalents. '' // '' // Characters - A pointer to a string of characters to convert to uppercase. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat strsize(characters--) result := byte[++characters] if((result => "a") and (result =< "z")) byte[characters] := (result - 32) PUB trimString(characters) '' 8 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Removes white space and new lines arround the outside of string of characters. '' // '' // Returns a pointer to the trimmed string of characters. '' // '' // Characters - A pointer to a string of characters to be trimmed. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// result := ignoreSpace(characters) characters := (result + ((strsize(result) - 1) #> 0)) repeat case byte[characters] 8 .. 13, 32, 127: byte[characters--] := 0 other: quit PUB tokenizeString(characters) '' 8 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Removes white space and new lines arround the inside of a string of characters. '' // '' // Returns a pointer to the tokenized string of characters, or an empty string when out of tokenized strings of characters. '' // '' // Characters - A pointer to a string of characters to be tokenized, or null to continue tokenizing a string of characters. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// if(characters) tokenStringPointer := characters result := tokenStringPointer := ignoreSpace(tokenStringPointer) repeat while(byte[tokenStringPointer]) case byte[tokenStringPointer++] 8 .. 13, 32, 127: byte[tokenStringPointer - 1] := 0 quit PUB findCharacter(stringToSearch, characterToFind) '' 5 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Searches a string of characters for the first occurence of the specified character. '' // '' // Returns the address of that character if found and zero if not found. '' // '' // StringToSearch - A pointer to the string of characters to search. '' // CharacterToFind - The character to find in the string of characters to search. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat strsize(stringToSearch--) if(byte[++stringToSearch] == characterToFind) return stringToSearch PUB replaceCharacter(stringToSearch, characterToReplace, characterToReplaceWith) '' 11 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Replaces the first occurence of the specified character in a string of characters with another character. '' // '' // Returns the address of the next character after the character replaced on success and zero on failure. '' // '' // StringToSearch - A pointer to the string of characters to search. '' // CharacterToReplace - The character to find in the string of characters to search. '' // CharacterToReplaceWith - The character to replace the character found in the string of characters to search. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// result := findCharacter(stringToSearch, characterToReplace) if(result) byte[result++] := characterToReplaceWith PUB replaceAllCharacters(stringToSearch, characterToReplace, characterToReplaceWith) '' 17 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Replaces all occurences of the specified character in a string of characters with another character. '' // '' // StringToSearch - A pointer to the string of characters to search. '' // CharacterToReplace - The character to find in the string of characters to search. '' // CharacterToReplaceWith - The character to replace the character found in the string of characters to search. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat while(stringToSearch) stringToSearch := replaceCharacter(stringToSearch, characterToReplace, characterToReplaceWith) PUB findString(stringToSearch, stringToFind) | index, size '' 7 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Searches a string of characters for the first occurence of the specified string of characters. '' // '' // Returns the address of that string of characters if found and zero if not found. '' // '' // StringToSearch - A pointer to the string of characters to search. '' // StringToFind - A pointer to the string of characters to find in the string of characters to search. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// size := strsize(stringToFind) if(size--) repeat strsize(stringToSearch--) if(byte[++stringToSearch] == byte[stringToFind]) repeat index from 0 to size if(byte[stringToSearch][index] <> byte[stringToFind][index]) result := true quit ifnot(result~) return stringToSearch PUB replaceString(stringToSearch, stringToReplace, stringToReplaceWith) '' 13 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Replaces the first occurence of the specified string of characters in a string of characters with another string of '' // characters. Will not enlarge or shrink a string of characters. '' // '' // Returns the address of the next character after the string of characters replaced on success and zero on failure. '' // '' // StringToSearch - A pointer to the string of characters to search. '' // StringToReplace - A pointer to the string of characters to find in the string of characters to search. '' // StringToReplaceWith - A pointer to the string of characters that will replace the string of characters found in the '' // string of characters to search. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// result := findString(stringToSearch, stringToReplace) if(result) repeat (strsize(stringToReplaceWith) <# strsize(stringToReplace)) byte[result++] := byte[stringToReplaceWith++] PUB replaceAllStrings(stringToSearch, stringToReplace, stringToReplaceWith) '' 19 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Replaces all occurences of the specified string of characters in a string of characters with another string of '' // characters. Will not enlarge or shrink a string of characters. '' // '' // StringToSearch - A pointer to the string of characters to search. '' // StringToReplace - A pointer to the string of characters to find in the string of characters to search. '' // StringToReplaceWith - A pointer to the string of characters that will replace the string of characters found in the '' // string of characters to search. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat while(stringToSearch) stringToSearch := replaceString(stringToSearch, stringToReplace, stringToReplaceWith) PUB integerToDecimal(number, length) '' 5 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Converts an integer number to the decimal string of that number padded with zeros. '' // '' // Returns a pointer to the converted string. '' // '' // Number - A 32 bit signed integer number to be converted to a string. '' // Length - The length of the converted string, "+" or "-" will be concatenated onto the head of converted string. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// length := (10 - ((length <# 10) #> 0)) decimalString := "+" if(number < 0) decimalString := "-" if(number == negx) bytemove(@decimalString, string("-2147483648KA"), 11) else repeat result from 10 to 1 decimalString[result] := ((||(number // 10)) + "0") number /= 10 decimalString[length] := decimalString return @decimalString[length] PUB integerToHexadecimal(number, length) '' 5 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Converts an integer number to the hexadecimal string of that number padded with zeros. '' // '' // Returns a pointer to the converted string. '' // '' // Number - A 32 bit signed integer number to be converted to a string. '' // Length - The length of the converted string, negative numbers need a length of 8 for sign extension. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat result from 7 to 0 hexadecimalString[result] := lookupz((number & $F): "0".."9", "A".."F") number >>= 4 return @hexadecimalString[8 - ((length <# 8) #> 0)] PUB integerToBinary(number, length) '' 5 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Converts an integer number to the binary string of that number padded with zeros. '' // '' // Returns a pointer to the converted string. '' // '' // Number - A 32 bit signed integer number to be converted to a string. '' // Length - The length of the converted string, negative numbers need a length of 32 for sign extension. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// repeat result from 31 to 0 binaryString[result] := ((number & 1) + "0") number >>= 1 return @binaryString[32 - ((length <# 32) #> 0)] PUB decimalToInteger(characters) | sign '' 10 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Converts a decimal string into an integer number. Expects a string with only "+-0123456789" characters. '' // '' // If the string has a "-" sign as its leading character the converted integer returned will be negated. '' // '' // If the string has a "+" sign as its leading character the converted integer returned will not be negated. '' // '' // Returns the converted integer. By default the number returned is positive and the "+" sign is unnecessary. '' // '' // Characters - A pointer to the decimal string to convert. The number returned will be 2's complement compatible. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// characters := checkSign(ignoreSpace(characters), @sign) repeat (strsize(characters) <# 10) ifnot(checkDigit(characters, "0", "9")) quit result := ((result * 10) + (byte[characters++] & $F)) result *= sign PUB hexadecimalToInteger(characters) | sign '' 10 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Converts a hexadecimal string into an integer number. Expects a string with only "+-0123456789ABCDEFabdcef" characters. '' // '' // If the string has a "-" sign as its leading character the converted integer returned will be negated. '' // '' // If the string has a "+" sign as its leading character the converted integer returned will not be negated. '' // '' // Returns the converted integer. By default the number returned is positive and the "+" sign is unnecessary. '' // '' // Characters - A pointer to the hexadecimal string to convert. The number returned will be 2's complement compatible. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// characters := checkSign(ignoreSpace(characters), @sign) repeat (strsize(characters) <# 8) ifnot(checkDigit(characters, "0", "9")) ifnot(checkDigit(characters, "A", "F") or checkDigit(characters, "a", "f")) quit result += $90_00_00_00 result := ((result <- 4) + (byte[characters++] & $F)) result *= sign PUB binaryToInteger(characters) | sign '' 10 Stack Longs '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// '' // Converts a binary string into an integer number. Expects a string with only "+-01" characters. '' // '' // If the string has a "-" sign as its leading character the converted integer returned will be negated. '' // '' // If the string has a "+" sign as its leading character the converted integer returned will not be negated. '' // '' // Returns the converted integer. By default the number returned is positive and the "+" sign is unnecessary. '' // '' // Characters - A pointer to the binary string to convert. The number returned will be 2's complement compatible. '' //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// characters := checkSign(ignoreSpace(characters), @sign) repeat (strsize(characters) <# 32) ifnot(checkDigit(characters, "0", "1")) quit result := ((result << 1) + (byte[characters++] & 1)) result *= sign PRI ignoreCase(character) ' 4 Stack Longs result := character if((character => "a") and (character =< "z")) result -= 32 PRI ignoreSpace(characters) ' 4 Stack Longs result := characters repeat strsize(characters--) case byte[++characters] 8 .. 13, 32, 127: other: return characters PRI checkSign(characters, signAddress) ' 5 Stack Longs if(byte[characters] == "-") result := -1 if(byte[characters] == "+") result := 1 long[signAddress] := (result + ((not(result)) & 1)) return (characters + (||result)) PRI checkDigit(characters, low, high) ' 5 Stack Longs result := byte[characters] return ((low =< result) and (result =< high)) ' added commands J Moxham Jan 2010 PUB endsWithString(stringToSearch, stringToFind) '' 12 Stack Longs '' ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ '' │ Checks if the string of characters ends with the specified characters. │ '' │ │ '' │ Returns true if yes and false if no. │ '' │ │ '' │ StringToSearch - A pointer to the string of characters to search. │ '' │ StringToFind - A pointer to the string of characters to find in the string of characters to search. │ '' └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ return ((stringToSearch + strsize(stringToSearch) - strsize(stringToFind)) == findString(stringToSearch, stringToFind)) PUB Left(Source, Destination,Number) ' returns the left number of characters repeat Number byte[Destination] := byte[Source] Source++ Destination++ byte[Destination] :=0 ' add in the zero terminator PUB Len(Source) ' returns the length of the string return strsize(Source) PUB Mid(Source,Destination,Start,Number) ' returns strings starting at start with number characters Start-- ' so starts at the right position Source += Start ' position 1 is the first character repeat Number byte[Destination] := byte[Source] Source++ Destination++ byte[Destination] :=0 'add in the zero terminator PUB Copy(Source,Destination) ' reverse order to stringcopy. Can also use to create strings eg copy(string("test"),@lineoftext1) bytemove(Destination, Source, (strsize(Source) + 1)) PUB Str(Destination,Number) | n' convert a number to a string representation. Uses Basic syntax, ie leading character is a space if +ve, and is - if negative n := number ' temp store for at the end when add the + or - Destination += 10 byte[Destination] := 0 ' terminator Destination-- repeat result from 10 to 1 byte[Destination] := ((||(number // 10)) + "0") number /= 10 Destination-- destination++ ' points to start again repeat while byte[destination] == "0" ' while equal to zero remove this leading zero repeat result from 0 to 11 ' include the zero terminator as well bytemove(destination+result,destination+result+1,1)' shuffle to left repeat result from 11 to 1 bytemove(destination+result,destination+result-1,1) ' shuffle once to right - leading space or - byte[destination] :=" " ' leading space if positive. Can use trim to remove this if (n<0) byte[destination] := "-" PUB Stringfill(Destination, Number,AsciiValue)' fill string with a string, eg 3,65 is"AAA" and 2,32 is " " bytefill(destination,AsciiValue,Number) ' same as Basic "string$" function and can also replicate space$ byte[destination+number] :=0 ' zero terminator PUB Instr(Source,AsciiValue) | j ' find asciivalue in Source. Returns 0 if not found j := 0 repeat result from 0 to strsize(Source) if byte[source+result] == AsciiValue j := result + 1 ' basic format where 1 is the last first character of a string return j 'PUB Val(Source)' basic string to decimal value only works for integers not floating point, see DecimalToInteger above {{ /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // TERMS OF USE: MIT License /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation // files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, // modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the // Software is furnished to do so, subject to the following conditions: // // The above copyright notice and this permission notice shall be included in all copies or substantial portions of the // Software. // // THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE // WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR // COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, // ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// }}
