How would you charge a dozen AA cells with a 12V 5W solar panel?
Hi,
A friend of mine asked me how you might go about charging cells with solar power. He is planning on using this solar panel: http://www.northerntool.com/shop/tools/product_200422047_200422047
However, he wants to charge a dozen or so cells without converting from DC to AC then back. Is there a solution or chain of solutions that allows this to be done? It would need to be compatible with the connector(s) shown.
Microcontrolled
P.S. You'll notice I put "cells" instead of "batteries" so that those persnickety forum users out there don't give me several posts describing the difference between the two. :-)
Microcontrolled
http://www.northerntool.com/shop/tools/product_200422043_200422043
I had a cheap ICP 7amp which couldn't do any better than 5amp
Granted there's probably better ways to do this but it will get you started, no doubt the smarter people here will give you a better suggestion.
-dan
easy to do this...and it's cheap.
I think if the voltage from the solar panel was higher it would be easier
to use a single 7800 to charge all the cells together. The 7800 should be
able to take at least 30v input. Perhaps your friend could find two smaller
panels and hook them together for 24v or so?
There are websites that have 7800 constant current calculators on them..
Just google for them :-)
There solar pannels very good I have a 15 watt one
NiCds are more forgiving then NiMh .
Just last night i made a LM7805 based drop in charger with a lifting diode on the Common terminal on the reg to lif it just enough to give a 50mA charge( at like 5.6V) to the cells in the FRS radio I use a for NOAA ( as it has the ALERT mode on it ) .
It uses 4 600mAH AAAs ( in side the radio I added a Shottkey Diode In series with the added pins on the bottom to keep them from shorting the pack from the outside .
the radio is on standby most of the time so all the charger does is offset Cell losses and run the radio at the same time
( draw is 40mA or so )
I preferr C/30 trickel for NiCds AA size and smaller .
or C/40 NiMh .
I plan on a 5 H charge cycle for Solar based chargers .
this suits most cells with in reason
Peter
