SPI / I2C pin sharing?
What would be the consequences of having SPI data/clock share I2C data/clock pins?
Would the SPI protocol ever cause and I2C device to respond?
Haven't looked at this in detail, but it seems to have been a sub-topic in a thread last year.
The I2C pull-up resistor on SDA would cause some problems for SPI if it was too strong.
Why not use the Props I2C port as is, and use four other I/O pins for the SPI ?
Still, I've pretty much settled on sharing the SCL pin. That way people don't get in trouble using any old SPI driver.
