propeller IDE and programming through RS232
I need a little confirmation about something.
Right now, all dev boards I have seen for Propeller use a FTDI (xx232) chip to program Propeller through USB.
What I need to know is how the propeller IDE handle programming? does it look for the FTDI chip or does it look blindly to a COM port and use comport signals to program?
The idea is that I want to use my own chip to handle the USB bridge and I need a confirmation about that.
Regards
Regards
I'm working on a small dev board for Propeller, and I want to use an MCU as an USB bridge instead of FTDI chip. the mcu will be in charge of programming the propeller, acting as a com through usb uart for the propeller, and it will also handle some usb host devices (USB key and USB keyb/mouse).
This is why I needed such confirmation
Regards
