Modulations of signals .
RITESH KAKKAR
Hi, i want to know exactly why we use cos wave for generating carrier signals??
RITESH KAKKAR
The signal is sent using sine or cosine, but when receiving/detecting the signal the the I (In-phase) and Q (Out-Phase) are both looked at. The Q is always 90 Deg out of phase from I. The reason for this is so that you can still detect the presence of a signal by applying the Pythagorean theorem to I and Q. Doing so negates any Phase differences between the transmitter and receiver that there might be.
You can use sine or cosine... the only difference between them is that one is 90 Deg out of phase with the other. On the receiver/detector end there would be no difference.
Each point on the cosine wave occurs exactly 1/4 cycle earlier (90-Deg Phase difference) than the corresponding point on the sine wave, and it could be argued that therefore the propagation delay would be 1/4 cycle later if using Sine waves verses using Cosine wave when sending a signal, but in any case you need a complete period (usually several) of whatever frequency you are transmitting in order to get a valid detection on the receiver end.
You need to provide more information about your reference. An integrator can be used to demodulate the received signal, but since there are several different transmission methods (i.e. AM,FM, etc) there are also several demodulation methods making it difficult to answer where and why an integrator might be necessary.
The internet is full of sources of information including the Wikipedia. Perhaps you should start there since you're interested in relatively basic concepts. The Wikipedia has some excellent articles on a wide variety of basic electrical and electronics concepts. After carefully going through them and exploring the links provided, if you have specific questions, by all means ask here.
In my case I learned a bit about modulation from a series of 6 books, translations from the english, about electronics with plenty of diagrams and explanations. They were from the 50s or 60s. Basic but full of useful info.
Here is a link to one of these books, the English version... http://www.amazon.de/Basic-Electronics-3-Van-Valkenburgh/dp/B000UFRPXK/ref=sr_1_19?ie=UTF8&qid=1300358447&sr=8-19
Hi, please tell free download books for me it will be great.
thanks.
Is Google blocked in the country of India?
