help passing arrays to modules
It's always the easy things that give me problems.
I'm trying to pass an byte array of integers to a module
output looks like this
first dec array print
192.168.2.237
no @ no byte no [0] : 192.103809041.166594724.0
yes @ no byte no [0] : 1584.103809041.166594724.0
no @ yes byte no [0] : 192.103809041.166594724.0
no @ no byte yes [0] : 192.103809041.166594724.0
no @ no byte yes [0] : 1584.103809041.166594724.0
no @ yes byte yes [0] : 192.103809041.166594724.0
two @ no byte no [0] : 208.103809041.166594724.0
I tried passing it by reference every way I could think of. Now I have a headache.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
debug : "Parallax Serial Terminal"
DAT
VAR
byte decarray[4]
pub main
debug.start(115200)
waitcnt((clkfreq*4)+cnt)
debug.home
debug.clear
decarray[0]:=192
decarray[1]:=168
decarray[2]:=2
decarray[3]:=237
debug.str(string("first dec array print",13))
debug.dec(decarray[0])
debug.str(string("."))
debug.dec(decarray[1])
debug.dec(decarray[2])
debug.dec(decarray[3])
debug.str(string(13))
TestIt(string("no @ no byte no [0] : "),decarray)
TestIt(string("yes @ no byte no [0] : "),@decarray)
TestIt(string("no @ yes byte no [0] : "),@byte[decarray])
TestIt(string("no @ no byte yes [0] : "),decarray[0])
TestIt(string("no @ no byte yes [0] : "),@decarray[0])
TestIt(string("no @ yes byte yes [0] : "),@byte[decarray][0])
TestIt(string("two @ no byte no [0] : "),@@decarray)
pub TestIt(descr,testarray)
debug.str(descr)
debug.dec(testarray[0])
debug.dec(testarray[1])
debug.dec(testarray[2])
debug.dec(testarray[3])
192.168.2.237
pub TestIt(descr,testarray) debug.str(descr) debug.dec([COLOR="red"]byte[testarray][0][/COLOR]) debug.str(string(".")) debug.dec([COLOR="red"]byte[testarray][1][/COLOR]) debug.str(string(".")) debug.dec([COLOR="red"]byte[testarray][2][/COLOR]) debug.str(string(".")) debug.dec([COLOR="red"]byte[testarray][3][/COLOR]) debug.str(string(13))Subsequently you should use @decarray or @decarray[0].I could have sworn I tried that at one point or another. Guess I was looking at it for to long <grin>.
FYI, when you're only sending one character to the terminal you can use the char method.
debug.char(".")
You can also use the ASCII number for the character. This is equivalent to the above statement.
debug.char(46)
Less typing and the program would run a little faster (I doubt it would be noticeable).
Another FYI while I'm on the topic. The char method goes by a variety of names depending on the serial object. FullDuplexSerial uses "tx." There's others that use "out."
Happy Spinning.
Duane
