Turbo Cad 12 - question
Beau Schwabe
Putting together a weekend project and using Turbo Cad to design and print out some templates for cutting later, I have stumbled across a most annoying key-stroke that I can't seem to undo.
In another CAD tool I use, I press CTRL+D to release all of the objects ... doing so in Turbo Cad (out of habit) places it in a weird mode resulting in a thin one pixel wide thin vertical line in the middle of the screen.
The Undo/Redo option seems to keep the design history, but not for the CTRL+D 'oops'
Just wondered if anyone has experienced this and if they knew of an undo for this.
I hope this isn't for a CNC maching of the die for Prop2. That could set it back another year.
http://www3.turbocadcommunity.com/tiki-index.php?page=SEKE's
Cntl+D = ViewCameraPlaceToDwgCenter = "Place camera to the drawing center"
Anyway, there's a bunch 'o TurboCAD cntl key descriptions on this site and many dedicated to "view camera".
Non-TurboCAD user,
DJ
... funny, but no. A weekend project I was working on for one of my daughters. ... not so funny.
Here is the latest Propeller II Blog ... Pad Frame was LVS/DRC on Friday 3-18-2011
http://forums.parallax.com/showthread.php?125543-Propeller-II-update-BLOG&p=985721&viewfull=1#post985721
davejames,
hmmm... camera view setting? ... still once it's set it won't let you go back to the original default view.
How about F5? "Redraw - redraw the active view".
I'm guessing here,
DJ
No, F5 just refreshes the current view.
Solution:
Under View, there is a tab for 'Previous View' ... there is no direct bind-key associated to it, but you can get there ... ALT+V, u, Enter
Seems like a very convoluted way to avoid or undo an accidental CTRL+D
You can try re-assigning the keystroke to the command you want. Go to System Preferences -> Keyboard -> Keyboard Shortcuts. Click the '+' button and add a shortcut for TurboCAD. Enter the exact menu item title from TurboCAD and set the shortcut to Ctrl+D.
If it's a well-behaved OS X program this will work. Unfortunately, I'd put the odds of TurboCAD being well-behaved at about 25%.
Edit: I don't know why I assumed you're on a Mac. Maybe because I have a version of TurboCAD.
Thanks! The version of TurboCAD that I'm using is for Windows.
Under ... Tools->Customize...->Keyboard ... I am able to change the CTRL+D to something else.
Actually my native boot is on a Linux based system with dual head monitors. I run VMWare to run Windows XP and assign that to one of the monitor heads.
