DS1307 - Time running too behind?
Hello there,
I'm ready to finish prototyping my project on the breadboard - but I bumped into one funny issue.
I have an RTC inside the project and when I disconnect the main supply, the RTC keeps the time, but it's like minutes and then hours behind afterwards.
I have a new CR2032, so it isn't the battery running out, and rest of the connections aren't short circuited.
By the way, before that it seems to keep the time well and good, but not after yesterday.
Should I even need to transfer them to the real circuit board? Because I heard that the breadboard isn't too friendly for the DS1307 and the crystal.
Thanks for the opinions.
Unfortunately I do not have much information about the brand of the watch crystal. Currently, ground lines from the LCD panel and the LM35 are nearby the crystal.
I will solder the thing on the veroboard if possible.
edit: Previously, the battery is on another breadboard due to lack of space on the main breadboard (microcontroller + LCD + ds1307).
After much squeezing back the battery on the main breadboard, (don't ask me how I do it, it's like a nasty and hasty brain surgery!) it retains the time well and good. But I had to test it for an hour to see whether it's acting up or not.
