Trimpot drift
Is it common for a trimpot to drift over a short period of time, say 30 minutes?
I'm using a 200 k trimpot to drop 120 V RMS to a more manageable ~3 V p-p. But I found I have to calibrate it when the circuit is warm, because the the output drifts around 30 % from cold to hot, dropping more voltage when warm. The pot isn't getting warm, just the transformer next to it, and it definitely isn't hot. What causes this? The screw doesn't appear to be moving. A quick search on the internet led me to believe they can drift over a long period of time, but I didn't see anything to indicate that it would happen so fast.
EDIT: in hindsight I realize I should have dropped most of the voltage with a single resistor, but I'm still curious about the drift.
Edit: After re-reading your pot value of 200K, you should be OK current-wise. Voltage rating OK on your unit? Some are only 50V.
Variable resistors have the additional hazard that one end is actually Zero ohms. Twisting the knob or screw too far may result in a disaster unless other resistance in series is limiting the circuit.
I think may have been it. Perhaps a voltage spike every time the circuit was unplugged. I cut a trace and added 300 k resistor in series, and the problem seems to have gone away.
Thanks everybody
