Can't Press Start
I just picked up a HYDRA development kit. I've done game programming on other consoles before, but mostly from a software perspective and wanted to try to get my hands dirty with this kit. I loaded the console by doing this:
1.) Plugged in RCA jacks to an NTSC TV
2.) Plugged in the Nintendo-compatible controller that came w/ the kit
3.) Flipped the power switch
The game is running fine, but I cannot "Press Start" as it says. I do see a LED changing when I press buttons, but there is also a LED that is solid always near the controller port as well. The led that flashes is to the right and the one that stays solid is to the left of that.
Is something wrong?
Do I need to do something else before I can press start?
I tried unplugging the controller and plugging it back in, with no results.
Cheers,
Kris
P.S - Great work from what I can see so far. This looks like a lot of fun.
Is something wrong?
Cheers,
Kris
I don't think it's a full game. You ought to try one of the other games that are playable. (Some sort of blockout game (if I remember correctly).)
Duane
