Propeller I semiconductor process technology? Is it 350nm or 180nm? — Parallax Forums
cdecde Posts: 37
edited 2011-03-15 14:24 in Propeller 1
Hi,
According to wikipedia, it's 180nm:
http://en.wikipedia.org/wiki/180_nanometer
But I think they may be referring to the Prop 2, as Beau said Prop 1 die photo is 350nm:
http://forums.parallax.com/archive/index.php/t-97773.html
In addition, 350nm only needs 3.3v whereas 180nm requires 1.8v, so this is consistent.
By the way, are all 3.3v chips made on a 350nm process? Or do they have some kind of voltage regulator inside?
  • AleAle Posts: 2,363
    edited 2011-03-15 06:45
    According to some earlier post by Beau or Chip it is 350 nm. The prop II will be 180 nm if I'm not mistaken. I do not think that all 350nm devices are 3.3V and some uC have a regulator inside (AVR32 for instance) but I do not know which process they are made on. What exactly do you want to know ? or Why do you ask this ?
  • cdecde Posts: 37
    edited 2011-03-15 13:14
    Ale wrote: »
    Out of sheer curiosity. ;)
    Hi,
    The Prop I uses a 350nm technology, where as the Prop II will have 180nm technology.
    There is no on-board-silicon regulator for the Propeller II design.
    The process usually defines the maximum operating 'core' voltage but with proper design this can
    vary widely.
