ZOG: GCC C/C++ Project in Google Code (propeller-zpu-vm)
I've been working with jazzed and Heater on a version of Heater's ZOG virtual machine. Originally this was a version for the Parallax C3 board but it has expanded to include support for jazzed's SDRAM board for the Propeller Platform and also Dr_Acula's Dracblade board. It would be relatively easy to expand it to support other external memory interfaces as well as small programs running directly from hub memory.
I've recently created a project for this in Google Code. This will allow us to continue developing it using the SVN version control system and will also make the code available to everyone.
For those who haven't been following ZOG development here is a summary of what ZOG provides in Heater's words:
Features:
Can run programs with up to 1MB of code and 64K of data on the Parallax C3
Can run programs with up to 32MB of code/data on the Gadget Gangster SDRAM board
Can run programs with up to 512K of code/data on the Dracblade
Loader features:
Can load compiled ZOG programs through a serial connection directly to Propeller external memory
Can load compiled ZOG programs to an SD card attached to the Propeller board
Can write a bootloader to EEPROM to facilitate serial downloads
Can write a bootloader to EEPROM to boot ZOG programs from an SD card
Can write a bootloader to EEPROM to boot a ZOG program from SPI flash on the Parallax C3
You can find ZOG in Google Code here:
http://code.google.com/p/propeller-zpu-vm/
Anyone can download the sources but you need to create a free Google account to commit changes. The PC-based loader can be built under Linux or under Windows using Cygwin. Building the Spin code requires the use of Brad's Spin Tool (BST, BSTC). I also have a project that will allow zogload, the PC-based loader program, to be built under Microsoft Visual C++.
The version of GCC that generates code for the ZPU can be found here:
http://opensource.zylin.com/zpudownload.html
The PDF for the manual is attached to this message.
Heater. wrote:Zog enables running C and C++ programs compiled with GCC, the GNU Compiler Collection, on the Propeller multi-core micro-controller from Parallax Inc.
There is no Propeller architecture target for GCC. To overcome this Zog provides a virtual machine implementing the instruction set of a CPU architecture for which there is a GCC target, namely the Zylin CPU (ZPU) from Zylin Consulting. The ZPU architecture provides a 32-bit processor with a very minimal instruction set, each ZPU instruction is a single byte, it is therefore a perfect candidate for emulation on the Propeller as the entire bytecode interpreter can be implemented in PASM within a single COG. Hence the name ZOG, ZPU in a Cog. Further, as each instruction is a single byte the ZPU is a good match for Propeller systems having external RAM or ROM that is connected over an 8 bit data bus.
Zog can be used to run compiled C, C++ binaries on a bare Propeller where the binaries are located within the Propellers HUB RAM space. This limits the binary size to a little less than 32KBytes. Fortunately there are Propeller systems available that provide memory external to the Propeller chip and Zog can also make use of such memory expansion from which it can execute much larger binaries and deal with much larger data sets. Up to 32MBytes currently!
Features:
Loader features:
#include <stdint.h> int8_t index; uint8_t code[1] = { 0xff }; uint8_t *pc = code; index = *(int8_t *)pc++; printf("%d\n", index);
If I run this code the printf ends up printing 255 when I expect it to print -1. Any idea why this might be happening? It seems like the int8_t variable "index" should be sign extended into an integer before being passed to printf but this doesn't seem to be happening.
I had:
typedef char int8_t;
when I should have had:
typedef signed char int8_t;
I guess I neglected to mention in my original post that I created the version of stdint.h that I've been using since none came with the ZPU tool chain. I guess I got that definition wrong. This is the first compiler I've ever seen that defined char as unsigned but I guess it's allowed by the ANSI standard.Anyway, fixing this bug makes my VM work correctly.
Oh yes, signed/unsigned char has bitten me in the past. Turns out this is not so much a compiler issue as a platform issue. After all we are using GCC everywhere and it can change from platform to platform. From the book An Introduction to GCC - for the GNU compilers gcc and g++
"Most systems, including x86 GNU/Linux and Microsoft Windows, use signed char, but those based on PowerPC and ARM processors typically use unsigned char."
Of course it probably does more than PUSH and POP values. The SP must be loaded when making calls to clear space for local variables.
The stack is also accessed by loads and stores so I hope the push/pops are actually going to the same locations as other memory read/writes.
I follow the ZOG-Posts since a longer period. There is one idea which drives me since the beginning: Wouldn't it be easy to convert the ZPU in a multi-thread ( or pseudo multi core virtual machine )? I mean the ZPU is a stack based architecture, so one has simply to implement multiple stack pointers and switch for every thread between this pointers.
The result would be, that you can run more than one ZPU program in one COG.
I surmised that. Often it takes more time to get things running than suspected at the beginning.
In the documentation I saw that only TV output is supported. I have only VGA displays.
BTW: is there a ZPU simulator for PC which has the same interfaces like ZOG so one can run the same binaries on PC as on a propeller board?
chris
