Wiznet_Test, and most demos failing
I set up my Spinneret with +5V as shown, plug in the prop plug, and ethernet cord to back of my computer. I try runnind the UDP Demo's, and when they set any value such as IP, then the IP is read, is comes back as 0's. Same with Wiznet_Test.
The only one I've been able to echo the set IP address etc is W5100_UDP_Echo_Demo_Indirect. When using the recommended UDP tool, and sending the packet, the Spinneret never acknowledges it.
I am at a loss as to how I should fix this issue. As for the partially working udp indirect demo, maybe its a windows setting holding things back? As for the others though a failure doesn't make sense to me.
Know what I'm doing wrong?
Keith
Keith
Describe what you expect to happen and the result. Please be descriptive, for example what is the name of the recommended UPD tool? How did you set up the UDP tool? What does partially working mean?
No it's the standard cable that connects to internet or routers etc.
I expect it to set a mac address then repeat what its set to, not set a mac address then get 0's.
UDP Test Tool 2.5. I set it up the normal way. Partially working means the one out of many demos that partially works only can repeat the set addresses, but fails to echo any packets sent through the UDP Test Tool.
You should be able to rule out the need for a cross-over cable. The Wiznet supports auto-MDIX and most newer Ethernet cards do also. As long as one partner does, then the RX/TX pins should be resolved by the Ethernet hardware.
This thread I posted: http://forums.parallax.com/showthread.php?130308-Private-Networking-with-your-propeller has a working example config for the PC Ethernet port and the Spinneret.
The demos I tried did work when I first brought things up on my spinner.
My first test load was a .zip file called "Website_Modified"....I can't find the thread right now.
I haven't found any posted code yet that doesn't work....these guys seem very good about being careful with what they post.
Keep trying, it does work in your configuration once you get things set up.
Rick
It's most likely configuration. Sorry; I just don't understand default configuration and set up in the normal way. Here's is my configuration using "Brilldea W5100 UDP Echo Demo indirect Ver. 00.5" loaded in the Spinneret.
Ipconfig
Serial Terminal
UDP Console
I attached a simple UPD console application for Windows.
Keith
Is it a problem that I don't have an ethernet gateway? If so, how would I fix that? I know very little about networking.
Thanks for all the help!
Keith
That's assuming a static network. If your LAN uses DHCP, I'm not sure how to recover the gateway address, since all my connections are static.
If you have you Spinner plugged into the Ethernet port on you computer and with the above IP configurations, you'd want to configure your Spinner to be on the 169.254.11.x subnet that your computer's Ethernet adapter is on. You could give your Spinner an IP of 169.254.11.1 for example, a subnet mask of 255.255.0.0 and a default gateway of 169.254.11.190 (your PC) and you should be able to talk between them using the Ethernet connector and the 169.254.11.1 (Spinner) and 169.254.11.190 (PC) addresses.
As you have it now, you are putting your Spinner (192168.1.4) onto a 169.254.x.y network with a default gateway it can never reach. It's listening but because of the addressing, NOTHING is getting to it. I imagine the Wiznet TCP/IP stack is just burning all the traffic from the "WRONG" network.
Fix your addressing and I bet you can talk!
Let us know!
Rick
Rick
It was good advice, much better than the convoluted process I suggested to get the same info. Anyway, here's the result I got on my WinXP box from ipconfig:
Because he accidentally hit the delete button when he was editing it (and hadn't saved a copy).
It looks like Keith was already doing that anyway so I didn't bother to retype it.
Spinneret: 169.254.11.1
Gateway: 169.254.11.190
Subnet mask: 255.255.0.0
Port: 80 (later you might want to change to a non standard port)
You mean access the Internet or create a home network?
Are you wondering how to put an IP address into the config so it's seen as a Gateway address?
It's slightly different for all the various flavors of Windows but shoudl be somethign like:
Control Panel -> Network Connections -> right-click on the Ethernet adapter you want to change -> select properties
from the panel that is displayed, highlight "Internet Protocol(TCP/IP) and then click on properties. Again, depending on your Windows version, you may have two TCP/IP entires one for IPV4 and one for IPV6 - you want IPV4.
Select the button for "Use the following IP address:" and then you can enter the IP address, Subnet mask and Default Gateway. Plug agreeable numbers in (as outlined above) and you should be working.
As Mike said above, a gateway is a device that can provide a path to another network. As a device, if you can't resolve teh address you are trying to talk to on your local network, you have to pass it to the default gateway to see if it can be routed to a netowrk the gateway knows about.
I the example you are building, your PC will be on two networks. One it accesses through it's wireless interface - yoru network that leads to the internet through your Modem/Router (which is the gateway for that network segment). The other network is the one you just built between your PC and the Spinner on the Ethernet segment. For this one, the gateway doesn't really serve any purpose at this time.
Hope this helps more than confuses.
Rick
A gateway (in this case, an old term for what is now considered a router), connects two networks and provides a means to get traffic between networks. When we set up a Spinner on a laptop like this, we make the laptop a dual homed device. It exists on two networks. The one network is the one through the wireless card 192.168.1.xxx - this has a gateway in his DSL/Cable modem and provides access to the Internet. Any traffic sent out this connection that's not a 192.168.1.xxx address will be passed to this networks default gateway for routing.
The second network is the 169.254.xxx.yyy network we're trying to build between the laptop and the Spinner. At this time, we're calling the laptop the default gateway but there should really just be traffic between the laptop and the Spinner and not anything not destined for some device on this network.
Do I need 2 gateways in this case? So far I've been telling Spinneret the Wireless gateway since it's the only one I have an address for. As MindRobots says I think I do. I'll give that a try here real quick.
Every time I click send in the UDP tool, the Rx light on Spinneret flashes blue! However PST still reads waiting to recieve, and the UDP tool recieves no data back.
I plugged the Spinneret's RJ45 port directly into my Win7 Laptop's RJ45 connection (my laptop connects wireless to the Internet). I opened the network connections properties (right click), double clicked on Internet Protocol TCP/IP(v4).
Clicked the "Use the following IP address" radio button. Entered a unique IP for my network - 192.168.1.130; Subnet of 255.255.255.0; and default gateway given to me by my router; 192.168.1.1.
I did not change my Spinneret configuration.
Tested by entering http
