I think I burnt my Dongle!
Well at least one pin on it anyway.
In trying to make an infrared repeater and infrared keyboard it appears I have blow out pin one.
Things looked good at first until I moved my test into the TV room and then nothing but @#!&#.
Does any one have recommendations on the minimum value resistor that can be used on the prop to drive a infrared LED.
would such a burnout affect nearby pins?
Hubristic Perry
Hubristic Perry
What's the fear?
PE -- Assuming 1.5V (V_led) and 40mA, pushing the envelope...
drum roll, please...
47Ω
Put a 1k to the base to limit the drive current into the transistor, then use the 47 ohm resistor in series with the led as per PJ Allen. Two resistors, one transistor, total cost = about 10c.
I can't figure why it was not working yesterday, spent a lot of time checking the hardware.
I did have a diode in series with the infrared LED, hoping to keep things from burning.
I found a MPSA43 in my junk box and used that and the suggestions from PJ Allen and Dr_Acula to finish the project.
I had also wanted to put a little levity to the forum
Here is the code I have been trying out. (it's mostly code from Bob Belleville IR_KIT found in the OBEX
It's a combo IR_Keyboard and IR_Repeater
should be useful to automate IR functions of multiple remotes.
Ouch!
That has never happened to me, I guess I am just careful. :-)
I did sit on a hot curling iron once though.......
ADDIT
That sketch was a tribute to Ronnie Barker's "Four candles", He could twist every word, when he retired from TV he opened an antique shop not far from my parents house.
I hate it when that happens... Yikes, that's gonna leave a mark!
Mike B.
Good One Dr_Acula! That's full of laughs!
@Perry - sorry to hear about your Dongle problems. As PJ noted - a small resistor is good insurance for the other 31 pins.
Paul
Perry, it is never a good idea to have a processor drive large currents to a load. Processors
are designed to process, transistors are designed to drive large loads. 2N3904's and 2N2222's
are very inexpensive and will drive your Ir Led fine.
