Quadcopter Control Software
Hello,
I am an student going for an electronics major currently working on a quadcopter. The physical construction and electrical wiring is done and I am in the process of writing code. I have some experience working with command prompts and the Picaxe microcontroller, but this is the first major software endeavor I've undertaken. Working with Spin on the Propeller wasn't nearly as easy or fun as I would have liked it to have been.
That being said, I was hoping I could get some feedback and suggestions on the code I have written so far. It works some of the time to say the least. I'm using the Gadget Gangster Usb Propeller board. The input comes from the receiver module of a Vex. In theory the code takes the output value from the receiver module and puts it into a variable representing the magnitude of a vector along the X, Y, and Z axis'. Right now it simply takes those values and performs some basic operations that represent up/down, left/right movements and such. I plan to add a calculus based stabilizing algorithm I have worked out that will take the vector values along with input from a 3-axis accelerometer and a gyroscope out of a Wii MotionPlus to stabilize the quadcopter. I've looked at the output signals from the receiver module and the Propeller board on an oscilloscope and they look fine, so at this point it's safe to say any problem is likely to be software related.
Thanks.
Thanks.
Con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 NorthRotorPin = 24 EastRotorPin = 23 SouthRotorPin = 22 WestRotorPin = 21 Var Long Channel[5] 'Channel Array Long channelPtr Long MainStack[200] Long SecondStack[40] Long Xvector 'Vector Commands Long Yvector Long Zvector Long NorthRotor 'Output Vectors Long EastRotor Long SouthRotor Long WestRotor Obj VEX : "VEXDemux" SERVO: "servo4" ACCEL: "H48C Tri-Axis Accelerometer" PUB Main VEX.Start (16, @Channel, @channelPtr) '(pin input, @channel, @syncOutPtr) SERVO.start(1520,NorthRotorPin,1520,EastRotorPin,1520,SouthRotorPin,1520,WestRotorPin) waitcnt(clkfreq / 1 + cnt) 'required, possibly to allow other processes to initialize cognew(Control, @Mainstack) cognew(Calc, @Secondstack) PRI Control | Channel1,Channel2,Channel3,Channel4,Channel5,Channel6,SensitivityConstant 'Channel2, up/dowm 'Channel6, hover level up/down 'Channel4, left/right 'Channel3, forward/reverse 'Channel5, Stabilization on/off 'Channel1, Rotate, if it's possible to use Channel 2 'Main Loop Repeat if Channel[1] > 1550 or Channel[1] < 1490 'Channel2, up/dowm Channel2 := Channel[1] - 1550 else Channel2 := 0 if Channel[2] > 1550 or Channel[2] < 1490 'Channel4, left/right Channel3 := Channel[2] - 1550 else Channel3 := 0 if Channel[3] > 1550 or Channel[3] < 1490 'Channel3, forward/reverse Channel4 := Channel[3] - 1550 else Channel4 := 0 if Channel[5] > 1550 'Channel6, hover level up/down Channel6 ++ elseif Channel[5] < 1490 Channel6 -- if Channel[4] < 1550 or Channel[4] > 1490 'Channel5, Stabilization on/off Channel5 := 0 elseif Channel[4] > 1550 Channel5 := 1 elseif Channel[4] < 1490 Channel5 := -1 'Vectors represent the change in position desired, will be input for stability calculations. 'X Axis Vector Xvector := Channel4 'Y Axis Vector Yvector := Channel3 'Z Axis vector Zvector := Channel2 + Channel6 'Channel6 has a value that is incremented or decremented based on the input PRI Calc Repeat 'Z axis movement, (up/down) NorthRotor := 1520 + Zvector EastRotor := 1520 + Zvector SouthRotor := 1520 + Zvector WestRotor := 1520 + Zvector 'X axis movement, (left/right) EastRotor += Xvector 'Negation so rotors do the opposite of each other WestRotor -= Xvector 'Y axis movement, (forward/reverse) NorthRotor += Yvector SouthRotor -= Yvector SERVO.move_to(0,NorthRotor,2) 'Motor output commands SERVO.move_to(1,EastRotor,2) SERVO.move_to(2,SouthRotor,2) SERVO.move_to(3,WestRotor,2)
I do notice that you're not clipping your "rotor" values to be within the valid servo range. If you were to center the throttle and then push full forward right, you'd likely exceed the valid input range.
You might want to use parenthesis for your multiple if statements. I can't remember if Spin gives < > higher operator precedence than OR or not. If not, you'd be getting this:
if( ( (Channel[2] > 1550) or Channel[2] ) < 1440 )
which is a lot different than this:
if( (Channel[2] > 1550) or (Channel[2] < 1440) )
That may be a red herring though.
Also, depending on how fast your Control loop updates, the value of Channel6 could quickly get a very large absolute value, which again would cause you servo problems, since it's not clipped. You might want to put a waitcnt( constant(_clkfreq / 200 + cnt ) in there or something to keep the update rate in check.
The rotor values aren't clipped, at least not yet. The servo object does however limit the servo values to be within an acceptable range.
For good measure I replaced the multiple OR statements with this:
elseif Channel[1] < 1490
else
Channel2 := 0
Figured it was best just to play it on the safe side.
The Channel6 value did increase rather quickly. I put this in the loop:
waitcnt(clkfreq / 8 + cnt)
And then I stopped getting on output for Channel6, but the rest of the loop still worked fine. Until it seems to lock up...
And for the record, the waitcnt will need to be a lot smaller than clkfreq/8 - that's only 8 hz, which is not likely to be fast enough. Servos update at 50hz, so start there at the very least.
And I even got an extra Cog out of the deal.
Thanks.
