BoeBot - add capacitor to smooth power draw of servos
John Kauffman
I vaguely recall reading somewhere that a capacitor parallel to the servos would smooth the power draw.
Perhaps it was in Gunther's SX book, I'm not sure.
Does anyone have experience with this? If it works, can you provide specifics, including cap size and description of circuit or schematic?
You can add capacitors across the servo's power leads, but the values needed would depend on what you're trying to solve. Typically you'd have some kind of electrolytic capacitor, perhaps 470uF or 1000uF to act as a power reserve for surges. You'd also have a 0.1uF ceramic capacitor to filter out high frequency noise.
Probably not important, but might help.
1000 uF electrolytic with NEG side connected to black lead of servo, other cap leg to red lead of servo
0.1 uF ceramic cap connected in parallel to above, polarity doesn't matter.
