Prop powered Penguin
Just finished a brain transplant on one of my Penguins, I've wanted to use a Prop for a while now and finally got around to building the hardware. I've been working with my Prop powered Toddler for a while now so figured it was time to do the Penguin. I cut up a proto board for the prop parts and built the rest of the circuit on perf board for now. This is just a simple proof of concept to get everything worked out then I am planning on doing a real board set so I can add more sensors and toys to it. I have the hardware talking and everything works, now I'm working on the software to get her to waddle around. I should be able to modify the Toddler code for starters. Having a blast modifying Parallax robots to use the Prop, I just got a Hexcrawler off Ebay and that is next in line for an update. I'll post more as I get things working.
Curt
Great work by the way! Keep it up!!!
Paul
EDIT: here is a couple of videos
I knew I should have posted pictures of my prop-based penguin and you beat me to it
Paul, I finally was able to view your videos, those are great! I'm going to use a protoboard on mine or I may use this as an excuse to get a Propeller Platform.
Curt
http://www.imaging-resource.com/PRODS/T10/T10A.HTM
I thought the image stabilization gyro had gone crazy.
The lens is fixed but auto focus and the cover is manual slide.
Maybe it's the focus motor gone awry.
The Ping is a lot better for distance or total darkness vision compared
to IR, at least farther than a couple feet. It's rather accurate out to
9 feet. Here's a seeing eye dog program for Penguin with the ultrasonics
image converted to audible sound.
http://forums.parallax.com/showthread.php?103759-Penguin-Robot-Seeing-Eye-Dog
penguin_seeing_eye_dog.bpx
