signed multiply/divide in assembly — Parallax Forums
Graham StablerGraham Stabler Posts: 2,510
edited 2011-03-04 04:35 in Propeller 1
Before I code it myself, is it already available?
Cheers,
Graham
  • max72max72 Posts: 1,155
    edited 2011-03-03 09:04
    There are samples on the wikispaces..
    http://propeller.wikispaces.com/MATH
    Massimo
  • BeanBean Posts: 8,129
    edited 2011-03-03 11:52
    Here is the code generated by PropBasic.
                      mov           __temp1,__param2             '  __param1 = __param2 * __param3
                      mov           __temp2,__param3
                      abs           __temp1,__temp1 WC
                      muxc          __temp3,#1
                      abs           __temp2,__temp2 WC, WZ
        IF_C          xor           __temp3,#1
                      mov           __temp4,#0
                      mov           __temp5,#32
                      shr           __temp1,#1 WC
    __L0001
        IF_C          add           __temp4,__temp2 WC
                      rcr           __temp4,#1 WC
                      rcr           __temp1,#1 WC
                      djnz          __temp5,#__L0001
                      test          __temp3,#1 WZ
        IF_NZ         neg           __temp4,__temp4
        IF_NZ         neg           __temp1,__temp1 WZ
        IF_NZ         sub           __temp4,#1
                      mov           __param1,__temp1
                      mov           __temp1,__param2             '  __param1 = __param2 / __param3
                      mov           __temp4,#0
                      muxc          __temp5,#1
        IF_Z          mov           __temp1,#0
        IF_Z          jmp           #__L0002
        IF_C          xor           __temp5,#1
                      mov           __temp3,#0
                      min           __temp2,#1
    __L0003
                      add           __temp3,#1
                      shl           __temp2,#1 WC
        IF_NC         jmp           #__L0003
                      rcr           __temp2,#1
    __L0004
                      cmpsub        __temp1,__temp2 WC
                      rcl           __temp4,#1
                      shr           __temp2,#1
                      djnz          __temp3,#__L0004
                      test          __temp5,#1 WZ
    __L0002
                      mov           __param1,__temp4
  • BRBR Posts: 92
    edited 2011-03-03 19:15
    See attached rabble of ASM snippets...lines 7-39. Also lines 398-449.
    Sorry about the thread links embedded in the comments, they're from the old forum. You'll have to use Phil's thread converter to see the original threads.
    I dunno why there isn't a nice sticky somewhere that compiles a bunch of useful ASM snippets in one place...
    edited 2011-03-04 01:45
    IIRC the spin interpreter is signed mult and divide. You can find the original code of the interpreter posted by Chip. There is a faster version in my spin interpreter (IIRC Chip provided the mult improvement - its noted in the code anyway).
    To find may faster spin interpreter, follow the Tools link in my signature.
  • Graham StablerGraham Stabler Posts: 2,510
    Thanks guys, I've not had a chance to follow up the leads but it looks really promising, I'll get back to you when I can, typically I have lots of paper work to do instead of coding :(
    Graham
