Array over serial transmission
Where can I find info on sending an array over a serial connection?
I'm using the FullDuplex module . I can send various variables in separate lines but is there a way to just send the entire array with one call?
to something like
and get the whole array sent?
comms.dec(arr[0])
comms.dec(arr[1])
comms.dec(arr[2])
to something like
comms.dec(arr[%])
repeat i from 0 to maxArr-2 comms.dec(arr[ i ]) comms.tx(" ") comms.dec(arr[ maxArr-1 ]) comms.tx(13)
This will send all the values, each separated from the other by a space and the whole set ended with a carriage return.Using the repeat for testing but I have to have an "if" wrapper based on array fill for the send function.
Reading about locks right now.
PUB runTest dira[19]~~ dira[22]~~ if comms.start(rxPin, txPin,2,9600) outa[19] := true waitcnt(30_000_000+cnt) repeat if trigger == 1 comms.dec(arr[0]) comms.tx(",") comms.dec(arr[1]) comms.tx(",") comms.hex(cnt,8) comms.tx(",") comms.dec(counter) comms.tx(",") comms.dec(arr[4]) comms.tx(13) trigger:= 0
With "trigger" being set elsewhere I seem to be getting a wiggle in the output.
In another cog, I set
trigger:= 1
once a threshold is hit. Happens to be a comparison of a 3202 return, check for trailing edge of a signal.What could be causing this sporadic variable?
I keep getting sporadic output unless I run the qualifier
if trigger ==1
to beyond 1.Like "2" or higher, then the random outputs to serial line quits.
With it (variable 'trigger') set as 0 or 1 , shouldn't it be one or the other?
Because I keep getting random data dumped on the serial out line with it checked on an if statement. If set the check number on the if statement higher I get no random data dumping. I labeled the if statement in bold.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 bits =12 chipDin =1 'to pin 5 chipClk =3 'to pin 7 chipSel =0 'to pin 1 chipDout=2 'to pin 6 BitsRead=12 rxPin = 5 txPin = 6 threshold = 95/100 ' devider for difference between squential reads VAR long Cog long stack2[10] long counter 'encoder accumulator long card 'card pulse accu byte detect 'card detect long val 'amplitude long arr[5] 'results long PotReading long DataRead byte input 'byte threshold long oldread byte trigger OBJ comms : "FullDuplexSerial" PUB start|Count text.start(16) cognew(Go,@stack2) cognew(runTest,2000) cognew(@entry,@arr[4]) cognew(@detecter,@detect) PUB Go DIRA[chipDin]~~ '19 data set up to the chip DIRA[chipClk]~~ '20 oscillates to read in data from internals DIRA[chipSel]~~ '21 osc once to set up 3202 DIRA[chipDout]~ '22 data from the chip to the Propeller repeat oldread:= DataRead DataRead:=0 'Clear out old data 'waitcnt(1000+cnt) 'Wait for things to settle down, but not needed outa[chipSel]~~ 'Chip select has to be high to start off outa[chipSel]~ 'Go low to start process outa[chipClk]~ 'Clock needs to be low to lead data outa[chipDin]~~ 'must start with Din low to set up 3202 outa[chipClk]~~ 'Clock low to read data in outa[chipClk]~ 'Low to load outa[chipDin]~~ 'High single mode outa[chipClk]~~ 'High to read outa[chipClk]~ 'Low to load outa[chipDin]~ 'Odd = channel 0 outa[chipClk]~~ 'High to read outa[chipClk]~ 'Low to load outa[chipDin]~~ 'msbf high = MSB first outa[chipClk]~~ 'High to read outa[chipDin]~ 'making line low for rest of cycle outa[chipClk]~ 'Low to load 'Read the null bit, we dont need to store it outa[chipClk]~~ 'High to read repeat BitsRead 'Reads the data into DataRead in 12 steps outa[chipClk]~ 'Low to load DataRead:=DataRead+ina[chipDout] 'Xfer the data from pin chipDout outa[chipClk]~~ 'High to read DataRead <<= 1 'Move data by shifting left 1 bit. Ready for next bit outa[chipSel]~~ 'Put chip to sleep, low power DataRead >>= 1 'Shift data right 1 bit to cancel last "bad" shift PotReading:=DataRead 'Finished data read for display arr[4]:= DataRead if oldread > DataRead * threshold trigger:= 1 arr[4]:= oldread PUB runTest dira[19]~~ dira[22]~~ if comms.start(rxPin, txPin,2,230400) outa[19] := true waitcnt(30_000_000+cnt) repeat if arr[4] > 1 if trigger == 1 [B]<-- here, if I set this number higher it stops dumping data[/B] comms.dec(arr[0]) comms.tx(",") comms.dec(arr[1]) comms.tx(",") comms.hex(cnt,8) comms.tx(",") comms.dec(counter) comms.tx(",") comms.dec(arr[4]) comms.tx(13) trigger:= 0 'waitcnt(100_000+cnt) DAT org 0 entry waitpeq ina, SENSE_PIN ' wait for high nop waitpne ina, SENSE_PIN ' wait for low rdlong mycount, par ' get count from hub add mycount, #1 ' increment wrlong mycount, par ' put it back jmp #entry SENSE_PIN long 1 << 4 ' p4 mycount res 1 org 0 detecter waitpeq ina, dectectPin wrbyte n1,par ' wait for high waitpne ina, dectectPin ' wait for low wrbyte n2,par ' put it back jmp #detecter dectectPin long 1 << 6 ' p4 n1 long 1 n2 long 0 meddct res 1 org 0 cardmes waitpeq ina, cardPin ' wait for high waitpne ina, cardPin ' wait for low rdlong cardct, par ' get count from hub add cardct, #1 ' increment wrlong cardct, par ' put it back jmp #cardmes cardPin long 1 << 1 ' p4 cardct res 1 org 0 asm mov dira,asm_dira 'make pins 8 (ADC) and 0 (DAC) outputs movs ctra,#5 'POS W/FEEDBACK mode for CTRA movd ctra,#3 movi ctra,#%01001_000 mov frqa,#1 mov asm_cnt,cnt 'prepare for WAITCNT loop add asm_cnt,asm_cycles :spot waitcnt asm_cnt,asm_cycles 'wait for next CNT value (timing is determinant after WAITCNT) mov asm_sample,phsa 'capture PHSA and get difference sub asm_sample,asm_old add asm_old,asm_sample wrlong asm_sample, par jmp #:spot 'wait for next sample period asm_cycles long |< bits - 1 'sample time asm_dira long |< 3 'output mask asm_cnt res 1 asm_old res 1 asm_sample res 1 org 0 arrasm
cognew(Go,@stack2) cognew(@entry,@arr[4]) cognew(@detecter,@detect) runtest
But that sets the threshold constant to zero, because Spin uses integer math. So later, when you say:if oldread > DataRead * threshold trigger:= 1 arr[4]:= oldread
the value of oldread will probably be greater than DataRead * 0 almost all the time.You might have to do something like this:
CON threshold_numerator = 95 threshold_denominator = 100 ... and later... if oldread > (DataRead * threshold_numerator) / threshold_denominator
Also
cognew(runTest,@stack3)
Took care of most of the random failures.
I can get fairly steady output now but anything faster than 115200 baud and it starts getting sporadic data over serial to a terminal.
Is there a way to get clean outputs at higher serial line rates?
Also, is there a way to pass multiple variables to a cog in ASM?
Like
cognew(@detecter,@detect,[B]detect2[/B])
.Or if I pass it a variable array , how do I interact with the variables in ASM.
Like
cognew(@detecter,@detect[2]) DAT detecter waitpeq ina, dectectPin wrbyte n1,par ' wait for high [B]<-- here I'm calling par for the passed variable[/B] waitpne ina, dectectPin ' wait for low wrbyte n2,par ' put it back jmp #detecter dectectPin long 1 << 7 ' p4 n1 long 1 n2 long 0
What would I use in the ASM side to interact with the different variables in the array?
