BS2 power consumption
Britannicus
Hi there.
I'm contemplating a project for my BOE to water my plants on holiday. I'm intending running the BOE on a standard 9v battery - leaving the stamp to tick away time over the days. Then on a daily basis to switch a small pump to water the plants daily.
The pump has it's own power supply 12v battery, so I'm only using power to switch it for 2 mins a day (5V 10Ma draw). My question is, how long will a BS2 stamp run on a duracell 9 volt battery before flattening it? - I've no measure, as in the past I've always run servos etc off the battery and so it's not lasted very long.
If I simply use it as a timer - how long before the battery dies from just the power drawn by the stamp and the LED in the BOE ? is there any way to prolongue battery life? I'd run it from a wall socket, but there isn't one available .
Cheers Chaps
Cheers Chaps
@5V 3 mA Run; 50uA Sleep
An alkaline battery is 400 to 600 mAh. So 600/3 is 200 hours.
Solar power, sleep at night or the day, get a battery with more capacity, use a real time clock, run off the pump power.
The SLEEP command is pretty accurate at long time intervals, certainly adequate for a holiday, and what does the plant care about that accuracy anyway?
For two minutes a day it would be,
DO HIGH watering PAUSE 120 ' 2 minutes, could even use SLEEP 120 here if the pump can tolerate 2 second glitches LOW watering SLEEP 43200 ' 12 hours SLEEP 43080 ' 12 hours minus 2 minutes LOOPAt 50 µA for 86280 seconds and 10 mA for 120 seconds, the average power drain is approx.:
(0.05 * 86280 + 10 * 120)/86400
= 64 µA
And that 500mAh batttery should last for 500 / 0.64 = 7812 hours = 325 days. Better come home from holiday now!
Be sure to put unused Stamp pins in definite states so that they don't float--bad for power drain.
Thanks for pointing me at the Sleep instruction - must've missed that one !
