How do you send ( And receive ) LONGS via FullDuplexSerial?
HI
Using FullDuplexSerial, I need to send ( and Receive) a LONG as 4 BYTES ( to keep my "Packet" Compact as possible).
but I don't believe this can be done because there is no "clean" Way to specify the end of the data as The default delimiter in Serial is a comma ",".
Having said that, any of my individual "byte values" could be that of the delimiter, which would confuse the reading of the values at the receiving end?
Also, What happens if my long value is zero , I would then be sending 4 bytes of zero! All of these are string terminating values.
The only thing I can see is to send each byte of the 4 bytes ( of the LONG) as 4 Hex values, Which I believe are really 8 bytes ( 2 bytes for each hex value) + a delimiter character, which will make 9 bytes overall.
What I can see sending everything as HEX is that the PACKETS will always be DOUBLE the amount of bytes really needed.
How can this be done?
Dave
Dave
If you want to avoid special characters, what about encoding (e.g. UTF-8 which sends 1..6 bytes depending on your 32 bit value)? Of course sending it as hex string counts as encoding as well. Up to you really.
As for sending a raw long:
repeat 4 serial.tx(value) value ->= 8 ' or repeat n from 0 to 3 serial.tx(value.byte[n])
Thanks for the reply, I can see what you are saying, My problem is that ( I am using this for RS485 ) my TRANSMITTING device ( MASTER )may send data faster than the receiving device ( SLAVE) can process it.
for example I am wanting to BROADCAST TIMECODE. my time code is basically the time represented in milliseconds. I will be broadcasting as fast as I can by doing this in a cog with minimum overhead.
I have a 128 byte buffer ( in my modified FullDuplex serial object), so how does my receiver know when one packet finishes and the other starts. If the receiver does not read every packet, there will be an overflow. Some how I need to receive a packet and if its not used, then discard it so that I only have the most current value in the buffer before it gets read. remember this is broadcasting so no addressing or return messages are required.
On my receiving side , my MAIN LOOP code checks for data coming in ( this is about 10 cycles per second) and processes this, it then checks the timecode arrived with the timer in my system and adjusts according.
Dave M
In case the MASTER sends faster than 10 packets/sec (i.e. faster than you intend to read) then you need some form of marker to distinguish the packets or some layer at the bottom should only keep the last e.g. 4 bytes or something (whatever size the packet is). Don't really know much about the protocol involved.
Come to think of it my packet size will be different depending on the way my devices will be working.
I basically have 2 modes.
1) SETUP MODE, where each slave will be asked by the ONE Master unit, what its status is, This may include uploading data to the SLAVE, Getting other data back from the slave to the master etc.
2) SYNCHRONISING TIMECLOCKS across all slaves to match the master time clock, If possible I need this to be accurate to 1 millisecond. This process MAY take place on a one by one slave basis, or using BROADCAST TIMECODE each slave can SYNC themselves ( somehow).
So The first PROCESS, involves one to one, and each PACKET may be different in length, but the advantage here is that the TIME of processing is not crucial to operations. So If I need to send any LONGS I can just transmit all data as strings as this may be complicated.
2) At the end of the day, I need to synchronise all slaves to a millisecond clock ( to the master clock) , Do I need to broadcast at millisecond intervals to achieve this or could I broadcast at say 10hz? and the slave clock can work out what to do, if this is the case, then i can send the time code as HEX values. AND I then need to make sure that the transmitted data is read in a timely manner.
I am thinking though, that I need to specify the PACKET LENGTH as suggested by you in another post of mine,
Dave M
thats a good idea, I could offset the value if I know the time it takes to receive and process the time data, and ASSUMING that processing time is consistent.
But Also,
I just did a simple test to send master time as STRING VALUE of a long, The number gets to the slave ok, But if my MASTER device is sending data FASTER than my SLAVE can read it, It gets all mucked up.
So I need to .
1) Make sure that the SLAVE device can read FASTER than the MASTER device ( slow down the intervals of the master), OR
2) Somehow I need to clear the buffer FLUSH it, if its not used, I guess this receiving data routine needs to work in its own cog, which should solve both issues,
thanks
Dave M
regarding a Faster Slave, This would be the best option, Its a shame that the whole serial object has a lot of SPIN code to manipulate the data, If this could be converted to PASM so its all in one , this would make it faster I wonder how much IDLE time the ASM cog has?.
The issue of the receiver being slower than the transmitter has me worried, I believe I have had strange issues with other programs because of corrupt data, form ( overflowed buffers?? )
I generally transmit and receive from my MAIN LOOP, which is about 10 HZ, Need to make better use of cogs!
This curent project is using 7 cogs already,
Can you tell me..
Q1) What happens if the RX Buffer is Full and another message is sent to it?
Q2) There is a FLUSH BUFFER command, Could this be used to clear the BUFFER , if a previous message has not been read?, and I guess that it should store only one message at a at a time.
thanks
Dave M
You mean rxflush? Yes.
I think I understand what you are saying, So because I am in "BROADCAST" Mode the MASTER should not try to send any data if ANY of the SLAVES are READING Data, Each slave has a 100 ms time out in reading, but they will try to read even if there is not data, and if I have many slaves, I doubt they there would be e time that is completely void of reads, But are you suggesting this could all be synchronised (readings) some how?
My SLAVEs are PERIODICALLY READING, i.e I pull the RE line LOW to enable the receiver ( I am using the MAX3535ECWI Chip)!, How can the MASTER check this?
I have already built my circuit!
regards
Dave M
It would need to be a situation where you have a Propeller on both ends and the Propeller's themselves would be generating/receiving the differential signal, not the MAX3535ECW.
My suggestion was a means for the Server to detect if there were any Clients lagging without necessarily the need for the Clients to broadcast. .... basically the Clients listen, and when they receive something, they hold the line until they have finished processing what they have received... This in effect throttles the Server, preventing data from being missed. At best in a scenario that there is no throttling, the Clients might receive data from the Server on every other transmission.
HI kuroneko,
hmmm, If the buffer gets wiped when its full then how about this idea....
I modify the PASM code to make a specific sized buffer, Say 16 bytes, ( which is original size, but mine is currently 128 bytes )
And then I need to make sure that all my BROADCAST Messages are exactly 16 bytes, That way if a message is NOT READ, its is completely replaced by a new message, therefore there will be only one complete message in the buffer at a time.
which bring me to my next question..
What happens if I am reading the buffer, and a new message comes in DURING this time? Does this happen? or is there some kind of lock?
What Do you think?
Dave M
