Prop controlling variable current for LED driver?
I have been working on the project for awhile, but running into too many walls. Taking a step back, I am looking to drive 9 or so LED's from a prop. They are high power LED's that require about 700mA of constant current. (see link below for specs)
From my trial and error, I am guessing I will need to run about 3 in series, and limit the current to 700mA per array of 3.
My final project will have 12-800mA (red), 9-800mA (green), 9-700mA (blue), 6-700mA (white), in which I will try to use a prop to control the brightness of each color...
MY QUESTION- Does anyone know if there is a digital to variable current driver IC available? Something that might be I2C in, and variable variable current out? Am I more concerned with current then voltage? Does anyone know any good information I can read on this?
THANKS IN ADVANCE!
http://cgi.ebay.com/3W-High-Power-Blue-Led-Without-AL-Base-Board-48pcs-/380317571478?pt=LH_DefaultDomain_0&hash=item588cb19996
THANKS IN ADVANCE!
allegro has various LED-driver-chips.
most of them are for current of 150 to 350 mA.
http://www.allegromicro.com/en/Products/Part_Numbers/6210/index.asp
You need 700mA.
Brightness of LEDs depends mostly on the current.
Your powersupply should provide the voltage like written in the specs of the LED
Current can be easily controlled through PWM.
For creating PWM there is an object in the obex which can create different independent PWM-signals
for ALL 32 IO-pins. So 9 IOpins is a piece of cake.
If 9 IO-pins is too much you could use a shiftregister like the 74HC595 which requires 3 IO-pins (there is a PWM object for this chip too in the obex)
You could use a simple I2C IO-expander too. Then you need a PASM-driver to be fast enough to do the on/off-switching of the IO-expander-outputs
All of the above suggestions would need a FET (Field-effect-transistor) as the powerswitching element.
You have to choose the FET carefully that the FET can be driven directly from 3.3V (or maybe 5V through a 3.3V/5V-buffer
(Gate to Threshold Voltage less than 5V)
With a quick look I found this type BUZ10 and IRF510
Some months ago somebody mentioned a "well suited" FET for the prop but I can't remember the type-number
Another suggestion is to use a LED-driver-chip for small currents which creates PWM at the outputs himself and feed the PWM into MOS-FETs (Metal Oxide Semiconductor Field Effect Transistors)
best regards
Stefan
http://www.mouser.com/Semiconductors/Drivers/LED-Drivers/_/N-7zhqfZscv7?P=1yzvmmbZ1yzu5uaZ1yzu5u9Z1yzufvzZ1z0wt49Z1z0ws57&Ns=Pricing%7c0
They probably all support PWM dimming.
I guess I am liking the idea of an actual driver IC because I am going to be making a large quanity of these, that it will be less components. I was looking at the following link I found thru the mouser link...
http://www.diodes.com/datasheets/AL8805.pdf
MY QUESTION - If I use the above unit, looking at the specs, could I run 3 LED's in series, per driver IC? So I would basically have 700mA @ 12v going to the LED? Or does each LED draw 700mA, and putting them in series would make it 2.1A?
If I look at the data sheet correctly, I could hook a prop pin thru a 1k resistor to the control pin on the driver IC and use PWM for dimming?
THANKS!
http://www.mouser.com/ProductDetail/Texas-Instruments/TPS61500PWP/?qs=QZKT0uTfj2LCtVhZh7Wjpw%3d%3d
btw the leds on ebay are not mounted on aluminum back plates, they will overheat.
if you design the pcb to act as giant heatsink, it may work
Treat these leds like they are a computer processor, because they will heat up just as much, and they do not have internal protections, with exposure to high heat the leds will deteriorate until they don't work or emit very little light.
All manufacturers of these leds boast high lumen output, large current capability, but they all hide the fact that you will need a massive heatsink, fans, and possibly even an air-conditioned air supply depending on how many leds your working with in an enclosed space(enclosure)
You need to keep the leds ROOM temperature to keep them from burning out within 2 years. (another claim that these manufactures boast is 10 year life span, but they fail to mention that they use active air-conditioned cooling for their testing)
http://www.st.com/stonline/products/literature/ds/13968/stcs2.pdf
